{"name":"Minuteman UPS","description":"Uninterruptable Power Supplies","url":"https:\/\/minutemanups.com","home":"https:\/\/minutemanups.com\/es\/","gmt_offset":"0","timezone_string":"","page_for_posts":0,"page_on_front":4483,"show_on_front":"page","namespaces":["oembed\/1.0","jetpack\/v4","wpml\/v1","ultimate-vc\/v1","uavc\/v1","calltrk\/v1","bsf-custom-fonts\/v1","custom-fonts\/v1","ninjatables\/v2","sliderrevolution","tablesome\/v1","wpf\/v1","wc\/v3","wc\/v1","woocommerce","wc\/pos\/v1\/catalog","wordfence-login-security\/v1","wordfence\/v1","yoast\/v1","yoast\/v1\/myyoast","wpml\/st\/v1","flexible-shipping\/v1","tribe\/event-aggregator\/v1","tribe\/events\/v1","tribe\/views\/v2","tec\/v2\/onboarding","tec\/v1","wpml\/tm\/v1","wpml\/ate\/v1","jetpack\/v4\/stats-app","complianz\/v1","popup-maker\/v2","pum\/v1","metaslider\/v1","ultimate-blocks\/v1","wc-site-health\/v1","wc-admin","wc-analytics","wc\/store","wc\/store\/v1","wc\/private","wp-smush\/v1","hub-connector\/v1","wc\/v2","spc\/v1","the7\/v1","jetpack\/v4\/blaze-app","jetpack\/v4\/blaze","woocommerce-analytics\/v1","google-site-kit\/v1","wc-admin-email","wc-push-notifications","wc-telemetry","wccom-site\/v3","otgs\/installer\/v1","nps-survey\/v1","wpcom\/v2","jetpack-boost\/v1","my-jetpack\/v1","jetpack\/v4\/explat","wpcom\/v3","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del recurso del que recuperar los datos oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del recurso del que recuperar los datos oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"El formato oEmbed a utilizar.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"La anchura m\u00e1xima del marco de incrustaci\u00f3n en p\u00edxeles.","type":"integer","default":600,"required":false},"maxheight":{"description":"La altura m\u00e1xima del marco de incrustaci\u00f3n en p\u00edxeles.","type":"integer","required":false},"discover":{"description":"Si se realizar\u00e1 una petici\u00f3n de descubrimiento de oEmbed para proveedores no sancionados.","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/oembed\/1.0\/proxy"}]}},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/backup-helper-script":{"namespace":"jetpack\/v4","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"helper":{"description":"El cuerpo del script de ayuda de la copia de seguridad se ha codificado en base64.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"path":{"description":"Ruta de acceso al script de ayuda de la copia de seguridad","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/backup-helper-script"}]}},"\/jetpack\/v4\/database-object\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"object_type":{"description":"Tipo de objeto que quieras recuperar de la base de datos","required":true},"object_id":{"description":"ID del objeto de la base de datos que quieras recuperar","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/database-object\/backup"}]}},"\/jetpack\/v4\/options\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Uno o varios nombres de opciones que quieras incluir en la copia de seguridad","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/options\/backup"}]}},"\/jetpack\/v4\/comments\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/posts\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/terms\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/users\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/site\/backup\/undo-event":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/backup\/undo-event"}]}},"\/jetpack\/v4\/orders\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/site\/backup\/preflight":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/backup\/preflight"}]}},"\/jetpack\/v4\/site\/cache\/flush":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/cache\/flush"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/ultimate-vc\/v1":{"namespace":"ultimate-vc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ultimate-vc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1"}]}},"\/ultimate-vc\/v1\/smooth-scroll-settings":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/smooth-scroll-settings"}]}},"\/ultimate-vc\/v1\/smooth-scroll-status":{"namespace":"ultimate-vc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/smooth-scroll-status"}]}},"\/ultimate-vc\/v1\/smooth-scroll-options":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/smooth-scroll-options"}]}},"\/ultimate-vc\/v1\/combined-css":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/combined-css"}]}},"\/ultimate-vc\/v1\/combined-js":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/combined-js"}]}},"\/ultimate-vc\/v1\/analytics-optin":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/analytics-optin"}]}},"\/ultimate-vc\/v1\/map-key":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/map-key"}]}},"\/ultimate-vc\/v1\/map-key\/validate":{"namespace":"ultimate-vc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/map-key\/validate"}]}},"\/ultimate-vc\/v1\/create-page":{"namespace":"ultimate-vc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/create-page"}]}},"\/uavc\/v1":{"namespace":"uavc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"uavc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/uavc\/v1"}]}},"\/uavc\/v1\/modules":{"namespace":"uavc\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/uavc\/v1\/modules"}]}},"\/uavc\/v1\/envato-activation":{"namespace":"uavc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/uavc\/v1\/envato-activation"}]}},"\/uavc\/v1\/license-status":{"namespace":"uavc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/uavc\/v1\/license-status"}]}},"\/uavc\/v1\/license-deactivate":{"namespace":"uavc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/uavc\/v1\/license-deactivate"}]}},"\/ultimate-vc\/v1\/icon-fonts":{"namespace":"ultimate-vc\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"font":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/icon-fonts"}]}},"\/ultimate-vc\/v1\/google-fonts":{"namespace":"ultimate-vc\/v1","methods":["GET","POST","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"start":{"default":0,"required":false},"fetch":{"default":20,"required":false},"search":{"default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"font_name":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/google-fonts"}]}},"\/ultimate-vc\/v1\/google-fonts\/refresh":{"namespace":"ultimate-vc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/google-fonts\/refresh"}]}},"\/ultimate-vc\/v1\/google-fonts\/variants":{"namespace":"ultimate-vc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"font_name":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/google-fonts\/variants"}]}},"\/ultimate-vc\/v1\/debug-options":{"namespace":"ultimate-vc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-vc\/v1\/debug-options"}]}},"\/calltrk\/v1":{"namespace":"calltrk\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"calltrk\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/calltrk\/v1"}]}},"\/calltrk\/v1\/store":{"namespace":"calltrk\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/calltrk\/v1\/store"}]}},"\/bsf-custom-fonts\/v1":{"namespace":"bsf-custom-fonts\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"bsf-custom-fonts\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/bsf-custom-fonts\/v1"}]}},"\/bsf-custom-fonts\/v1\/admin\/settings":{"namespace":"bsf-custom-fonts\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/bsf-custom-fonts\/v1\/admin\/settings"}]}},"\/custom-fonts\/v1":{"namespace":"custom-fonts\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"custom-fonts\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/custom-fonts\/v1"}]}},"\/custom-fonts\/v1\/get-tracking-status":{"namespace":"custom-fonts\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/custom-fonts\/v1\/get-tracking-status"}]}},"\/custom-fonts\/v1\/update-tracking-status":{"namespace":"custom-fonts\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/custom-fonts\/v1\/update-tracking-status"}]}},"\/jetpack\/v4\/jetpack-ai-jwt":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/jetpack-ai-jwt"}]}},"\/jetpack\/v4\/plans":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/plans"}]}},"\/jetpack\/v4\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/products"}]}},"\/jetpack\/v4\/marketing\/survey":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/marketing\/survey"}]}},"\/jetpack\/v4\/rewind":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/rewind"}]}},"\/jetpack\/v4\/scan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/scan"}]}},"\/jetpack\/v4\/connection\/url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"from":{"type":"string","required":false},"redirect":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/url"}]}},"\/jetpack\/v4\/tracking\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"tracks_opt_out":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/tracking\/settings"}]}},"\/jetpack\/v4\/site\/features":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/features"}]}},"\/jetpack\/v4\/site\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/products"}]}},"\/jetpack\/v4\/site\/purchases":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/purchases"}]}},"\/jetpack\/v4\/site\/benefits":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/benefits"}]}},"\/jetpack\/v4\/site\/activity":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/activity"}]}},"\/jetpack\/v4\/module\/all":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/module\/all"}]}},"\/jetpack\/v4\/module\/all\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"default":"","type":"array","items":{"type":"string"},"required":true},"active":{"default":true,"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/module\/all\/active"}]}},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Los bloques de Jetpack est\u00e1n desactivados.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Esquema de color.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Mostrar los datos meta de foto (<a href=\"https:\/\/es.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) en el carrusel, cuando est\u00e9n disponibles.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Mostrar el \u00e1rea de comentarios en el carrusel","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Texto de bienvenida","type":"string","default":"Deja un comentario","required":false},"jetpack_comment_form_color_scheme":{"description":"Esquema de color","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"jetpack_portfolio":{"description":"Activar o desactivar el tipo de entrada Portfolio de Jetpack.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"N\u00famero de entradas m\u00e1ximo a mostrar en la p\u00e1ginas de Portfolio.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Activar o desactivar el tipo de contenido recomendaci\u00f3n de Jetpack.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"N\u00famero de entradas a mostrar como mucho en las p\u00e1ginas de recomendaciones.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Activar reglas autom\u00e1ticas: utiliza las reglas de seguridad autom\u00e1ticas para proteger tu sitio contra fuentes de tr\u00e1fico no fiables.","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Lista de bloqueados: bloquea una IP de solicitud concreta.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Direcciones IP bloqueadas","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Lista de permitidos: permite una IP de solicitud concreta.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"Direcciones IP siempre permitidas","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Comparte datos b\u00e1sicos con Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Comparte datos detallados con Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Mostrar todas las fotos de tu galer\u00eda en un mosaico moderno.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Muestra los perfiles de la gente cuando pasas el rat\u00f3n por encima de sus gravatares","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Hasta el infinito y m\u00e1s all\u00e1","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Utiliza Google Analytics con scroll infinito","type":"boolean","default":0,"required":false},"wpl_default":{"description":"Los \u00abMe gusta\u00bb de WordPress.com est\u00e1n","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Enviar un aviso por correo electr\u00f3nico cuando a alguien le gusta una entrada","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Usar Markdown en los comentarios.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Usar Markdown en las entradas.","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Recibe avisos por correo electr\u00f3nico del supervisor.","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"Direcci\u00f3n de correo electr\u00f3nico","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Clave de API de Protect","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Proteger la lista de IP permitidas global","type":"string","default":"","required":false},"sharing_services":{"description":"Los servicios que est\u00e1n activos y los que est\u00e1n ocultos tras un bot\u00f3n","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Estilo del bot\u00f3n","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"Etiqueta de Compartir","type":"string","default":"","required":false},"show":{"description":"Ver donde se muestran los botones","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"El nombre de usuario de Twitter del due\u00f1o del dominio de este sitio.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Desactiva CSS y JS","type":"boolean","default":0,"required":false},"custom":{"description":"Servicios de compartir personalizados a\u00f1adidos por el usuario.","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Borrar servicio de compartir personalizado.","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"La autentificaci\u00f3n en dos pasos es obligatoria","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Correspondencia por correo electr\u00f3nico","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Mostrar la opci\u00f3n &lt;em&gt;\u00abseguir el blog\u00bb&lt;\/em&gt; en el formulario de comentarios","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Mostrar la opci\u00f3n &lt;em&gt;\u00abseguir los comentarios\u00bb&lt;\/em&gt; en el formulario de comentarios","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Array de identificadores de categor\u00edas de entradas que se marcan como categor\u00edas de newsletter","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Si las categor\u00edas de la newsletter est\u00e1n activadas o no","type":"boolean","default":0,"required":false},"wpcom_newsletter_send_default":{"description":"Si se deben enviar correos electr\u00f3nicos del bolet\u00edn por defecto al publicar una entrada","type":"boolean","default":1,"required":false},"wpcom_featured_image_in_email":{"description":"Si incluir o no la imagen destacada en el correo electr\u00f3nico","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Mostrar o no el avatar del autor en el encabezamiento del correo electr\u00f3nico","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Mostrar o no el nombre del autor en el encabezamiento del correo electr\u00f3nico","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Mostrar o no la fecha en el encabezamiento del correo electr\u00f3nico","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Si usar o no el resumen en el correo electr\u00f3nico","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Comportamiento de respuesta al correo electr\u00f3nico para los correos electr\u00f3nicos de la newsletter","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Nombre del remitente en los correos electr\u00f3nicos de newsletters","type":"string","default":"","required":false},"sm_enabled":{"description":"Muestra una ventana emergente modal de suscripci\u00f3n a los lectores.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Muestra la superposici\u00f3n de suscripci\u00f3n en la p\u00e1gina de inicio.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Muestra un bot\u00f3n de suscripci\u00f3n flotante.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"A\u00f1ade el bloque de suscripci\u00f3n al final de cada entrada.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"A\u00f1ade el bloque Inicio de sesi\u00f3n de suscriptor a la navegaci\u00f3n.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"A\u00f1ade el bloque de suscripci\u00f3n a la navegaci\u00f3n.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"Enviar una notificaci\u00f3n por correo electr\u00f3nico cuando alguien se suscriba a mi blog","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Opciones utilizadas en las plantillas de correo electr\u00f3nico de suscripci\u00f3n y en el bloque Suscripci\u00f3n: &#039;invitation&#039;, &#039;welcome&#039;, &#039;comment_follow&#039;, &#039;subscribe_modal_heading&#039;, &#039;free_tier_description&#039; y &#039;hide_free_tier&#039;.","type":"object","default":{"invitation":"","welcome":"","comment_follow":"","subscribe_modal_heading":"","free_tier_description":"","hide_free_tier":false},"required":false},"show_headline":{"description":"Destacar contenido relacionado con un encabezado","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Mostrar una imagen en miniatura donde est\u00e9 disponible","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Activar b\u00fasqueda instant\u00e1nea","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Tiene una compra de producto de Jetpack Search","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"Lanza una configuraci\u00f3n autom\u00e1tica de b\u00fasqueda instant\u00e1nea","type":"boolean","default":0,"required":false},"google":{"description":"Consolas de Google Search","type":"string","default":"","required":false},"bing":{"description":"Centro de Webmaster de Bing","type":"string","default":"","required":false},"pinterest":{"description":"Verificaci\u00f3n de sitio de Pinterest","type":"string","default":"","required":false},"yandex":{"description":"Verificaci\u00f3n de sitio en Yandex","type":"string","default":"","required":false},"facebook":{"description":"Verificaci\u00f3n del dominio en Facebook","type":"string","default":"","required":false},"enable_header_ad":{"description":"Muestra un anuncio en la parte superior de cada p\u00e1gina.","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"\u00bfEst\u00e1 el sitio aprobado en WordAds?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"\u00bfMostrar un segundo anuncio bajo la entrada?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"\u00bfVisualizar el anuncio alineado con el contenido de la entrada?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"\u00bfMostrar anuncios en portada?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"\u00bfMostrar anuncios en las entradas?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"\u00bfMostrar anuncios en las p\u00e1ginas?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"\u00bfMostrar anuncios en las p\u00e1ginas de archivo?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":"Ads.txt personalizado","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Entradas en ads.txt personalizadas","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Activar compatibilidad con el acta de privacidad del consumidor de California","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL de pol\u00edtica de privacidad","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Activar banner de gesti\u00f3n de consentimiento del RGPD para WordAds","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"Incluye una peque\u00f1a gr\u00e1fica en tu barra de administraci\u00f3n con una captura del tr\u00e1fico de las \u00faltimas 48 horas.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Previsualiza la nueva experiencia de estad\u00edsticas de Jetpack (experimental).","type":"boolean","default":1,"required":false},"roles":{"description":"Selecciona los roles que podr&#225;n ver los informes de estad&#237;sticas.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Cuenta las p&#225;ginas vista de los usuarios registrados logueados.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"ID del blog.","type":"boolean","default":0,"required":false},"do_not_track":{"description":"No rastrear.","type":"boolean","default":1,"required":false},"version":{"description":"Versi\u00f3n.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Cerrar los avisos de actualizaci\u00f3n","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Mostrar vistas de entradas en el lector de WordPress.com.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Idioma principal del sitio.","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Descripci\u00f3n de metadatos de la p\u00e1gina de inicio.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"Estructuras de t\u00edtulos de p\u00e1gina de SEO.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"jetpack_seo_llms_txt_enabled":{"description":"Genera un archivo llms.txt para guiar a los asistentes de IA a trav\u00e9s de tu contenido.","type":"boolean","default":0,"required":false},"jetpack_seo_ai_crawler_overrides":{"description":"Anulaciones de permitir\/bloquear para rastreadores de IA.","type":"object","default":[],"required":false},"videopress_private_enabled_for_site":{"description":"Privacidad de v\u00eddeo: Restringe la visualizaci\u00f3n a los miembros de este sitio","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Genera autom\u00e1ticamente el t\u00edtulo SEO, la descripci\u00f3n SEO y el texto alternativo de la imagen para las nuevas entradas.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"ai":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"podcast":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sitemaps":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"active":{"default":true,"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"range":{"default":"day","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/module\/(?P<service>[a-z\\-]+)\/key\/check":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"api_key":{"default":"","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Los bloques de Jetpack est\u00e1n desactivados.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Esquema de color.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Mostrar los datos meta de foto (<a href=\"https:\/\/es.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) en el carrusel, cuando est\u00e9n disponibles.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Mostrar el \u00e1rea de comentarios en el carrusel","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Texto de bienvenida","type":"string","default":"Deja un comentario","required":false},"jetpack_comment_form_color_scheme":{"description":"Esquema de color","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"jetpack_portfolio":{"description":"Activar o desactivar el tipo de entrada Portfolio de Jetpack.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"N\u00famero de entradas m\u00e1ximo a mostrar en la p\u00e1ginas de Portfolio.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Activar o desactivar el tipo de contenido recomendaci\u00f3n de Jetpack.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"N\u00famero de entradas a mostrar como mucho en las p\u00e1ginas de recomendaciones.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Activar reglas autom\u00e1ticas: utiliza las reglas de seguridad autom\u00e1ticas para proteger tu sitio contra fuentes de tr\u00e1fico no fiables.","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Lista de bloqueados: bloquea una IP de solicitud concreta.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Direcciones IP bloqueadas","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Lista de permitidos: permite una IP de solicitud concreta.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"Direcciones IP siempre permitidas","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Comparte datos b\u00e1sicos con Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Comparte datos detallados con Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Mostrar todas las fotos de tu galer\u00eda en un mosaico moderno.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Muestra los perfiles de la gente cuando pasas el rat\u00f3n por encima de sus gravatares","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Hasta el infinito y m\u00e1s all\u00e1","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Utiliza Google Analytics con scroll infinito","type":"boolean","default":0,"required":false},"wpl_default":{"description":"Los \u00abMe gusta\u00bb de WordPress.com est\u00e1n","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Enviar un aviso por correo electr\u00f3nico cuando a alguien le gusta una entrada","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Usar Markdown en los comentarios.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Usar Markdown en las entradas.","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Recibe avisos por correo electr\u00f3nico del supervisor.","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"Direcci\u00f3n de correo electr\u00f3nico","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Clave de API de Protect","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Proteger la lista de IP permitidas global","type":"string","default":"","required":false},"sharing_services":{"description":"Los servicios que est\u00e1n activos y los que est\u00e1n ocultos tras un bot\u00f3n","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Estilo del bot\u00f3n","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"Etiqueta de Compartir","type":"string","default":"","required":false},"show":{"description":"Ver donde se muestran los botones","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"El nombre de usuario de Twitter del due\u00f1o del dominio de este sitio.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Desactiva CSS y JS","type":"boolean","default":0,"required":false},"custom":{"description":"Servicios de compartir personalizados a\u00f1adidos por el usuario.","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Borrar servicio de compartir personalizado.","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"La autentificaci\u00f3n en dos pasos es obligatoria","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Correspondencia por correo electr\u00f3nico","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Mostrar la opci\u00f3n &lt;em&gt;\u00abseguir el blog\u00bb&lt;\/em&gt; en el formulario de comentarios","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Mostrar la opci\u00f3n &lt;em&gt;\u00abseguir los comentarios\u00bb&lt;\/em&gt; en el formulario de comentarios","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Array de identificadores de categor\u00edas de entradas que se marcan como categor\u00edas de newsletter","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Si las categor\u00edas de la newsletter est\u00e1n activadas o no","type":"boolean","default":0,"required":false},"wpcom_newsletter_send_default":{"description":"Si se deben enviar correos electr\u00f3nicos del bolet\u00edn por defecto al publicar una entrada","type":"boolean","default":1,"required":false},"wpcom_featured_image_in_email":{"description":"Si incluir o no la imagen destacada en el correo electr\u00f3nico","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Mostrar o no el avatar del autor en el encabezamiento del correo electr\u00f3nico","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Mostrar o no el nombre del autor en el encabezamiento del correo electr\u00f3nico","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Mostrar o no la fecha en el encabezamiento del correo electr\u00f3nico","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Si usar o no el resumen en el correo electr\u00f3nico","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Comportamiento de respuesta al correo electr\u00f3nico para los correos electr\u00f3nicos de la newsletter","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Nombre del remitente en los correos electr\u00f3nicos de newsletters","type":"string","default":"","required":false},"sm_enabled":{"description":"Muestra una ventana emergente modal de suscripci\u00f3n a los lectores.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Muestra la superposici\u00f3n de suscripci\u00f3n en la p\u00e1gina de inicio.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Muestra un bot\u00f3n de suscripci\u00f3n flotante.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"A\u00f1ade el bloque de suscripci\u00f3n al final de cada entrada.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"A\u00f1ade el bloque Inicio de sesi\u00f3n de suscriptor a la navegaci\u00f3n.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"A\u00f1ade el bloque de suscripci\u00f3n a la navegaci\u00f3n.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"Enviar una notificaci\u00f3n por correo electr\u00f3nico cuando alguien se suscriba a mi blog","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Opciones utilizadas en las plantillas de correo electr\u00f3nico de suscripci\u00f3n y en el bloque Suscripci\u00f3n: &#039;invitation&#039;, &#039;welcome&#039;, &#039;comment_follow&#039;, &#039;subscribe_modal_heading&#039;, &#039;free_tier_description&#039; y &#039;hide_free_tier&#039;.","type":"object","default":{"invitation":"","welcome":"","comment_follow":"","subscribe_modal_heading":"","free_tier_description":"","hide_free_tier":false},"required":false},"show_headline":{"description":"Destacar contenido relacionado con un encabezado","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Mostrar una imagen en miniatura donde est\u00e9 disponible","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Activar b\u00fasqueda instant\u00e1nea","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Tiene una compra de producto de Jetpack Search","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"Lanza una configuraci\u00f3n autom\u00e1tica de b\u00fasqueda instant\u00e1nea","type":"boolean","default":0,"required":false},"google":{"description":"Consolas de Google Search","type":"string","default":"","required":false},"bing":{"description":"Centro de Webmaster de Bing","type":"string","default":"","required":false},"pinterest":{"description":"Verificaci\u00f3n de sitio de Pinterest","type":"string","default":"","required":false},"yandex":{"description":"Verificaci\u00f3n de sitio en Yandex","type":"string","default":"","required":false},"facebook":{"description":"Verificaci\u00f3n del dominio en Facebook","type":"string","default":"","required":false},"enable_header_ad":{"description":"Muestra un anuncio en la parte superior de cada p\u00e1gina.","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"\u00bfEst\u00e1 el sitio aprobado en WordAds?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"\u00bfMostrar un segundo anuncio bajo la entrada?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"\u00bfVisualizar el anuncio alineado con el contenido de la entrada?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"\u00bfMostrar anuncios en portada?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"\u00bfMostrar anuncios en las entradas?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"\u00bfMostrar anuncios en las p\u00e1ginas?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"\u00bfMostrar anuncios en las p\u00e1ginas de archivo?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":"Ads.txt personalizado","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Entradas en ads.txt personalizadas","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Activar compatibilidad con el acta de privacidad del consumidor de California","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL de pol\u00edtica de privacidad","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Activar banner de gesti\u00f3n de consentimiento del RGPD para WordAds","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"Incluye una peque\u00f1a gr\u00e1fica en tu barra de administraci\u00f3n con una captura del tr\u00e1fico de las \u00faltimas 48 horas.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Previsualiza la nueva experiencia de estad\u00edsticas de Jetpack (experimental).","type":"boolean","default":1,"required":false},"roles":{"description":"Selecciona los roles que podr&#225;n ver los informes de estad&#237;sticas.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Cuenta las p&#225;ginas vista de los usuarios registrados logueados.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"ID del blog.","type":"boolean","default":0,"required":false},"do_not_track":{"description":"No rastrear.","type":"boolean","default":1,"required":false},"version":{"description":"Versi\u00f3n.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Cerrar los avisos de actualizaci\u00f3n","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Mostrar vistas de entradas en el lector de WordPress.com.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Idioma principal del sitio.","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Descripci\u00f3n de metadatos de la p\u00e1gina de inicio.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"Estructuras de t\u00edtulos de p\u00e1gina de SEO.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"jetpack_seo_llms_txt_enabled":{"description":"Genera un archivo llms.txt para guiar a los asistentes de IA a trav\u00e9s de tu contenido.","type":"boolean","default":0,"required":false},"jetpack_seo_ai_crawler_overrides":{"description":"Anulaciones de permitir\/bloquear para rastreadores de IA.","type":"object","default":[],"required":false},"videopress_private_enabled_for_site":{"description":"Privacidad de v\u00eddeo: Restringe la visualizaci\u00f3n a los miembros de este sitio","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Genera autom\u00e1ticamente el t\u00edtulo SEO, la descripci\u00f3n SEO y el texto alternativo de la imagen para las nuevas entradas.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"ai":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"podcast":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sitemaps":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/settings"}]}},"\/jetpack\/v4\/settings\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/options\/(?P<options>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/updates\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/updates\/plugins"}]}},"\/jetpack\/v4\/notice\/(?P<notice>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/plugins":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug del plugin en el directorio WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Estado de activaci\u00f3n del plugin.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"source":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/plugins"}]}},"\/jetpack\/v4\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"type":"string","required":true},"source":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/plugin\/(?P<plugin>[a-z\\\/\\.\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/widgets\/(?P<id>[0-9a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"keyring_id":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)\/(?<keyring_id>[0-9]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/recommendations\/data":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/recommendations\/data"}]}},"\/jetpack\/v4\/recommendations\/step":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/recommendations\/step"}]}},"\/jetpack\/v4\/recommendations\/product-suggestions":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/recommendations\/product-suggestions"}]}},"\/jetpack\/v4\/recommendations\/upsell":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/recommendations\/upsell"}]}},"\/jetpack\/v4\/recommendations\/conditional":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/recommendations\/conditional"}]}},"\/jetpack\/v4\/site\/discount":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site\/discount"}]}},"\/jetpack\/v4\/jetpack_crm":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"extension":{"type":"text","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/jetpack_crm"}]}},"\/jetpack\/v4\/purchase-token":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/purchase-token"}]}},"\/jetpack\/v4\/seen-wc-connection-modal":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/seen-wc-connection-modal"}]}},"\/jetpack\/v4\/intro-offers":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/intro-offers"}]}},"\/jetpack\/v4\/subscribers\/auth":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"La URL para redirigir.","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/subscribers\/auth"}]}},"\/jetpack\/v4\/features\/available":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/features\/available"}]}},"\/jetpack\/v4\/features\/enabled":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/features\/enabled"}]}},"\/jetpack\/v4\/licensing\/error":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"error":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/licensing\/error"}]}},"\/jetpack\/v4\/licensing\/set-license":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"license":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/licensing\/set-license"}]}},"\/jetpack\/v4\/licensing\/user\/licenses":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/licensing\/user\/licenses"}]}},"\/jetpack\/v4\/licensing\/user\/counts":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/licensing\/user\/counts"}]}},"\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"last_detached_count":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss"}]}},"\/jetpack\/v4\/licensing\/attach-licenses":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"licenses":{"type":"array","items":{"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/licensing\/attach-licenses"}]}},"\/ninjatables\/v2":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ninjatables\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2"}]}},"\/ninjatables\/v2\/tables":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables"}]}},"\/ninjatables\/v2\/tables\/dismiss-fluent-suggest":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/dismiss-fluent-suggest"}]}},"\/ninjatables\/v2\/tables\/dismiss-welcome-banner":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/dismiss-welcome-banner"}]}},"\/ninjatables\/v2\/tables\/optin":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/optin"}]}},"\/ninjatables\/v2\/tables\/optin\/usage":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/optin\/usage"}]}},"\/ninjatables\/v2\/tables\/optin\/dismiss":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/optin\/dismiss"}]}},"\/ninjatables\/v2\/tables\/optin\/stop-emails":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/optin\/stop-emails"}]}},"\/ninjatables\/v2\/tables\/bulk-delete":{"namespace":"ninjatables\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/bulk-delete"}]}},"\/ninjatables\/v2\/tables\/bulk-restore":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/bulk-restore"}]}},"\/ninjatables\/v2\/tables\/tools\/default-settings":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/tools\/default-settings"}]}},"\/ninjatables\/v2\/tables\/tools\/permission":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/tools\/permission"}]}},"\/ninjatables\/v2\/tables\/tools\/global-settings":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/tools\/global-settings"}]}},"\/ninjatables\/v2\/tables\/tools\/clear-table-cache":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/tools\/clear-table-cache"}]}},"\/ninjatables\/v2\/tables\/tools\/clear-external-cache":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/tables\/tools\/clear-external-cache"}]}},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)":{"namespace":"ninjatables\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/bulk-delete-columns":{"namespace":"ninjatables\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/duplicate":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/table-inner-html":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/drag_and_drop_html":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/item":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/item\/update":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/tables\/(?P<id>[0-9]+)\/item\/delete":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/settings\/(?P<id>[0-9]+)":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/settings\/(?P<id>[0-9]+)\/button":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/settings\/(?P<id>[0-9]+)\/custom-styles":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/table-builder":{"namespace":"ninjatables\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/table-builder"}]}},"\/ninjatables\/v2\/table-builder\/(?P<id>[0-9]+)":{"namespace":"ninjatables\/v2","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/fluent-forms":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/fluent-forms"}]}},"\/ninjatables\/v2\/fluent-forms\/save":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/fluent-forms\/save"}]}},"\/ninjatables\/v2\/fluent-forms\/(?P<id>[0-9]+)":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/ninjatables\/v2\/wp-posts":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/wp-posts"}]}},"\/ninjatables\/v2\/wp-posts\/authors":{"namespace":"ninjatables\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/wp-posts\/authors"}]}},"\/ninjatables\/v2\/import\/default":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/default"}]}},"\/ninjatables\/v2\/import\/default-csv\/init":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/default-csv\/init"}]}},"\/ninjatables\/v2\/import\/default-csv\/process":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/default-csv\/process"}]}},"\/ninjatables\/v2\/import\/table-builder":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/table-builder"}]}},"\/ninjatables\/v2\/import\/get-tables-from-other-plugin":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/get-tables-from-other-plugin"}]}},"\/ninjatables\/v2\/import\/import-table-from-other-plugin":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/import-table-from-other-plugin"}]}},"\/ninjatables\/v2\/import\/upload-csv-in-existing-table":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/import\/upload-csv-in-existing-table"}]}},"\/ninjatables\/v2\/install\/fluent-forms":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/install\/fluent-forms"}]}},"\/ninjatables\/v2\/install\/ninja-charts":{"namespace":"ninjatables\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ninjatables\/v2\/install\/ninja-charts"}]}},"\/sliderrevolution":{"namespace":"sliderrevolution","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"sliderrevolution","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/sliderrevolution"}]}},"\/sliderrevolution\/sliders":{"namespace":"sliderrevolution","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/sliderrevolution\/sliders"}]}},"\/sliderrevolution\/sliders\/(?P<slider>[\\w\\-]+)":{"namespace":"sliderrevolution","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/sliderrevolution\/sliders\/slides\/(?P<id>\\d+)":{"namespace":"sliderrevolution","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/sliderrevolution\/sliders\/stream\/(?P<id>[0-9,]+)":{"namespace":"sliderrevolution","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/sliderrevolution\/sliders\/modal\/(?P<slider>[\\w\\-]+)":{"namespace":"sliderrevolution","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tablesome\/v1":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tablesome\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1"}]}},"\/tablesome\/v1\/tables\/import":{"namespace":"tablesome\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/tables\/import"}]}},"\/tablesome\/v1\/tables\/(?P<table_id>\\d+)\/export":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"table_id":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tablesome\/v1\/tables":{"namespace":"tablesome\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/tables"}]}},"\/tablesome\/v1\/tables\/(?P<table_id>\\d+)":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"table_id":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tablesome\/v1\/tables\/(?P<table_id>\\d+)\/records":{"namespace":"tablesome\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"table_id":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"table_id":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"table_id":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tablesome\/v1\/tablesome-api-keys":{"namespace":"tablesome\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/tablesome-api-keys"}]}},"\/tablesome\/v1\/workflow\/posts":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/posts"}]}},"\/tablesome\/v1\/workflow\/fields":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/fields"}]}},"\/tablesome\/v1\/workflow\/tags":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/tags"}]}},"\/tablesome\/v1\/workflow\/get-post-types":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-post-types"}]}},"\/tablesome\/v1\/workflow\/taxonomies":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/taxonomies"}]}},"\/tablesome\/v1\/workflow\/terms":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/terms"}]}},"\/tablesome\/v1\/workflow\/get-user-roles":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-user-roles"}]}},"\/tablesome\/v1\/workflow\/get-users":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-users"}]}},"\/tablesome\/v1\/workflow\/get-postmeta-keys":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-postmeta-keys"}]}},"\/tablesome\/v1\/workflow\/get-oauth-data":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-oauth-data"}]}},"\/tablesome\/v1\/workflow\/set-oauth-data":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/set-oauth-data"}]}},"\/tablesome\/v1\/workflow\/delete-oauth-data":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/delete-oauth-data"}]}},"\/tablesome\/v1\/workflow\/get-access-token":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-access-token"}]}},"\/tablesome\/v1\/workflow\/get-spreadsheets":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-spreadsheets"}]}},"\/tablesome\/v1\/workflow\/get-spreadsheet-data":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-spreadsheet-data"}]}},"\/tablesome\/v1\/workflow\/get-spreadsheet-records":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/get-spreadsheet-records"}]}},"\/tablesome\/v1\/workflow\/append-records-to-spreadsheet":{"namespace":"tablesome\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/workflow\/append-records-to-spreadsheet"}]}},"\/tablesome\/v1\/get-spreadsheet-row-count":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/get-spreadsheet-row-count"}]}},"\/tablesome\/v1\/spreadsheet-clear-rows":{"namespace":"tablesome\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/spreadsheet-clear-rows"}]}},"\/tablesome\/v1\/oauth\/status":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/oauth\/status"}]}},"\/tablesome\/v1\/oauth\/status\/(?P<integration>[a-z_]+)":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tablesome\/v1\/oauth\/refresh\/(?P<integration>[a-z_]+)":{"namespace":"tablesome\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tablesome\/v1\/oauth\/health-check":{"namespace":"tablesome\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tablesome\/v1\/oauth\/health-check"}]}},"\/wpf\/v1":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpf\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1"}]}},"\/wpf\/v1\/short-links":{"namespace":"wpf\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"url":{"type":"string","format":"uri","required":true},"filter_id":{"type":"integer","default":0,"minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/short-links"}]}},"\/wpf\/v1\/short-links\/(?P<slug>[a-z0-9_-]+)":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpf\/v1\/short-links\/(?P<slug>[a-z0-9_-]+)\/qr":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpf\/v1\/facets":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":["string","integer"],"description":"Category id or slug.","required":false},"tag":{"type":["string","integer"],"description":"Tag id or slug.","required":false},"brand":{"type":["string","integer"],"description":"Brand id or slug (WooCommerce Brands or Perfect Brands).","required":false},"attributes":{"type":"object","description":"taxonomy or attribute slug => list of term slugs or ids, e.g. {\"color\":[\"red\"],\"size\":[\"42\",\"43\"]}. Several values of one attribute are OR, attributes are AND.","additionalProperties":{"type":"array","items":{"type":["string","integer"]}},"required":false},"min_price":{"type":"number","minimum":0,"required":false},"max_price":{"type":"number","minimum":0,"required":false},"in_stock":{"type":"boolean","description":"Only products that can be bought now.","required":false},"on_sale":{"type":"boolean","required":false},"featured":{"type":"boolean","required":false},"min_rating":{"type":"integer","minimum":1,"maximum":5,"required":false},"search":{"type":"string","maxLength":200,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/facets"}]}},"\/wpf\/v1\/products":{"namespace":"wpf\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"category":{"type":["string","integer"],"description":"Category id or slug.","required":false},"tag":{"type":["string","integer"],"description":"Tag id or slug.","required":false},"brand":{"type":["string","integer"],"description":"Brand id or slug (WooCommerce Brands or Perfect Brands).","required":false},"attributes":{"type":"object","description":"taxonomy or attribute slug => list of term slugs or ids, e.g. {\"color\":[\"red\"],\"size\":[\"42\",\"43\"]}. Several values of one attribute are OR, attributes are AND.","additionalProperties":{"type":"array","items":{"type":["string","integer"]}},"required":false},"min_price":{"type":"number","minimum":0,"required":false},"max_price":{"type":"number","minimum":0,"required":false},"in_stock":{"type":"boolean","description":"Only products that can be bought now.","required":false},"on_sale":{"type":"boolean","required":false},"featured":{"type":"boolean","required":false},"min_rating":{"type":"integer","minimum":1,"maximum":5,"required":false},"search":{"type":"string","maxLength":200,"required":false},"per_page":{"type":"integer","minimum":1,"maximum":50,"default":20,"required":false},"page":{"type":"integer","minimum":1,"default":1,"required":false},"orderby":{"type":"string","enum":["default","price","price-desc","date","popularity","rating","title"],"default":"default","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/products"}]}},"\/wpf\/v1\/openapi":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/openapi"}]}},"\/wpf\/v1\/readiness":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/readiness"}]}},"\/wpf\/v1\/llms":{"namespace":"wpf\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/llms"}]}},"\/wpf\/v1\/mcp":{"namespace":"wpf\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/mcp"}]}},"\/wc\/v3":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v3","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3"}]}},"\/wc\/v3\/marketplace\/featured":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/featured"}]}},"\/wc\/v1":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1"}]}},"\/wc\/v1\/marketplace\/product-preview":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/marketplace\/product-preview"}]}},"\/wc\/v3\/marketplace\/refresh":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/refresh"}]}},"\/wc\/v3\/marketplace\/subscriptions":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions"}]}},"\/wc\/v3\/marketplace\/subscriptions\/connect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions\/connect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate-plugin":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate-plugin"}]}},"\/wc\/v3\/marketplace\/subscriptions\/disconnect":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions\/disconnect"}]}},"\/wc\/v3\/marketplace\/subscriptions\/activate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions\/activate"}]}},"\/wc\/v3\/marketplace\/subscriptions\/auto-update":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_key":{"type":"string","required":true},"enabled":{"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions\/auto-update"}]}},"\/wc\/v3\/marketplace\/subscriptions\/install-url":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/subscriptions\/install-url"}]}},"\/wc\/v3\/marketplace\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/marketplace\/create-order"}]}},"\/woocommerce":{"namespace":"woocommerce","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"woocommerce","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/woocommerce"}]}},"\/woocommerce\/mcp":{"namespace":"woocommerce","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/woocommerce\/mcp"}]}},"\/wc\/pos\/v1\/catalog":{"namespace":"wc\/pos\/v1\/catalog","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/pos\/v1\/catalog","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/pos\/v1\/catalog"}]}},"\/wc\/pos\/v1\/catalog\/create":{"namespace":"wc\/pos\/v1\/catalog","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"force":{"type":"boolean","default":false,"description":"Force regeneration of the feed. NOOP if generation is in progress.","required":false},"_product_fields":{"type":"string","description":"Comma-separated list of fields to include for non-variable products.","required":false},"_variation_fields":{"type":"string","description":"Comma-separated list of fields to include for variations.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/pos\/v1\/catalog\/create"}]}},"\/wordfence-login-security\/v1":{"namespace":"wordfence-login-security\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wordfence-login-security\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence-login-security\/v1"}]}},"\/wordfence-login-security\/v1\/internal\/passkey-login\/begin":{"namespace":"wordfence-login-security\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence-login-security\/v1\/internal\/passkey-login\/begin"}]}},"\/wordfence-login-security\/v1\/internal\/passkey-login\/finish":{"namespace":"wordfence-login-security\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence-login-security\/v1\/internal\/passkey-login\/finish"}]}},"\/wordfence\/v1":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wordfence\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1"}]}},"\/wordfence\/v1\/authenticate":{"namespace":"wordfence\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1\/authenticate"}]}},"\/wordfence\/v1\/config":{"namespace":"wordfence\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1\/config"}]}},"\/wordfence\/v1\/disconnect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1\/disconnect"}]}},"\/wordfence\/v1\/scan\/issues":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1\/scan\/issues"}]}},"\/wordfence\/v1\/scan":{"namespace":"wordfence\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1\/scan"}]}},"\/wordfence\/v1\/scan\/issue":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wordfence\/v1\/scan\/issue"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/configurator":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/configurator"}]}},"\/yoast\/v1\/reindex_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/reindex_posts"}]}},"\/yoast\/v1\/ryte":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/ryte"}]}},"\/yoast\/v1\/indexables\/(?P<object_type>\\w+)\/(?P<object_id>\\d+)":{"namespace":"yoast\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/myyoast":{"namespace":"yoast\/v1\/myyoast","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1\/myyoast","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/myyoast"}]}},"\/yoast\/v1\/myyoast\/connect":{"namespace":"yoast\/v1\/myyoast","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/myyoast\/connect"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Prefijo a a\u00f1adir antes de los identificadores de las estad\u00edsticas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/flexible-shipping\/v1":{"namespace":"flexible-shipping\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"flexible-shipping\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/flexible-shipping\/v1"}]}},"\/flexible-shipping\/v1\/free-shipping-notice":{"namespace":"flexible-shipping\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/flexible-shipping\/v1\/free-shipping-notice"}]}},"\/tribe\/event-aggregator\/v1":{"namespace":"tribe\/event-aggregator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tribe\/event-aggregator\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/event-aggregator\/v1"}]}},"\/tribe\/event-aggregator\/v1\/import\/(?P<import_id>\\w+)\/batch":{"namespace":"tribe\/event-aggregator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"import_id":{"type":"string","description":"El ID \u00fanico de importaci\u00f3n proporcionado por el servicio de Event Aggregator","required":true},"batch_hash":{"type":"string","description":"El hash del siguiente lote esperado, como lo proporcion\u00f3 previamente el cliente","required":true},"status":{"type":"object","description":"El estado actual de la importaci\u00f3n.","required":true},"percentage_complete":{"type":"integer","description":"El porcentaje de importaci\u00f3n completado.","required":true},"interval":{"type":"integer","description":"El intervalo actual, en segundos, entre el final de un proceso por lotes y el inicio de la siguiente; como se establece en el servidor.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/event-aggregator\/v1\/import\/(?P<import_id>\\w+)\/state":{"namespace":"tribe\/event-aggregator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"import_id":{"type":"string","description":"El ID \u00fanico de importaci\u00f3n proporcionado por el servicio de Event Aggregator","required":true},"batch_hash":{"type":"string","description":"El hash del siguiente lote esperado, como lo proporcion\u00f3 previamente el cliente","required":true},"status":{"type":"string","enum":["success","failed","pending"],"description":"El nuevo estado de la importaci\u00f3n.","required":true},"message":{"type":"string","description":"El nuevo mensaje de estado para el usuario, no localizado.","required":true},"message_slug":{"type":"string","description":"El nuevo slug de estado de mensaje, para permitir mensajes localizados.","required":true},"percentage_complete":{"type":"integer","description":"El porcentaje de importaci\u00f3n completado.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1":{"namespace":"tribe\/events\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tribe\/events\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1"}]}},"\/tribe\/events\/v1\/doc":{"namespace":"tribe\/events\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1\/doc"}]}},"\/tribe\/events\/v1\/events":{"namespace":"tribe\/events\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"default":1,"description":"La p\u00e1gina de archivo a devolver","type":"integer","required":false},"per_page":{"default":"10","description":"El n\u00famero de eventos que se mostrar\u00e1 en cada p\u00e1gina","type":"integer","required":false},"start_date":{"default":"2026-11-25 23:59:00","description":"Eventos que empiezan en la fecha especificada","required":false},"end_date":{"default":"2028-11-26 15:43:51","description":"Eventos que terminan en la fecha especificada","required":false},"starts_before":{"description":"Eventos que empiezan antes de la fecha especificada","required":false},"starts_after":{"description":"Eventos que empiezan despu\u00e9s de la fecha especificada","required":false},"ends_before":{"description":"Eventos que terminan antes de la fecha especificada","required":false},"ends_after":{"description":"Eventos que terminan despu\u00e9s de la fecha especificada","required":false},"strict_dates":{"default":"false","description":"Las fechas configuradas usando fecha de inicio\/fecha de fin, empieza el *\/termina el * empiezan en los horarios especificados. El comportamiento por defecto es incluir los d\u00edas completos.","required":false},"search":{"description":"Los eventos deben contener la cadena especificada en el t\u00edtulo o en la descripci\u00f3n","type":"string","required":false},"categories":{"description":"Se debe asignar a los eventos uno de los slugs o ID de las categor\u00edas especificadas","items":{"type":"integer"},"required":false},"tags":{"description":"Se debe asignar a los eventos uno de los slugs o ID de las etiquetas especificadas","items":{"type":"integer"},"required":false},"venue":{"description":"Se debe asignar a los eventos uno de los ID de recinto especificados","items":{"type":"integer"},"required":false},"organizer":{"description":"Se debe asignar a los eventos uno de los ID de organizadores especificados","items":{"type":"integer"},"required":false},"featured":{"type":"boolean","description":"Los eventos deben filtrarse por su estado de \u00abdestacado\u00bb","required":false},"status":{"format":"string","description":"Estado de la entrada del evento","required":false},"geoloc":{"type":"boolean","description":"Necesita Events Calendar Pro. Los eventos se deber\u00edan filtrar en funci\u00f3n de si su recinto tiene datos de geolocalizaci\u00f3n","required":false},"geoloc_lat":{"format":"double","description":"Necesita Events Calendar Pro. Los eventos se deber\u00edan filtrar por la latitud de la ubicaci\u00f3n del recinto, y deber\u00edan proveer geoloc_lng","required":false},"geoloc_lng":{"format":"double","description":"Necesita Events Calendar Pro. Los eventos se deber\u00edan filtrar por la longitud de la ubicaci\u00f3n del recinto, y deber\u00edan proveer geoloc_lat","required":false},"include":{"description":"Incluir eventos con uno de los ID de entrada especificados en el array de la lista CSV, los filtros de fecha se ignorar\u00e1n.","items":{"type":"integer"},"required":false},"post_parent":{"type":"integer","description":"Los eventos deben filtrarse por tener el post_parent especificado.","required":false},"ticketed":{"type":"boolean","description":"Filtrar eventos con o sin tickets.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"author":{"type":"integer","description":"ID del autor del evento","required":false},"date":{"type":"string","description":"Fecha de publicaci\u00f3n del evento","required":false},"date_utc":{"type":"string","description":"Fecha de publicaci\u00f3n del evento (Zona horaria UTC)","required":false},"title":{"type":"string","description":"Titulo del evento","required":true},"description":{"type":"string","description":"Descripci\u00f3n del evento","required":false},"slug":{"type":"string","description":"El slug del evento","required":false},"excerpt":{"type":"string","description":"Extracto del evento","required":false},"status":{"type":"string","description":"Estado de la entrada del evento","required":false},"timezone":{"type":"string","description":"Zona horaria del evento","required":false},"all_day":{"default":false,"type":"boolean","description":"Si el evento dura todo el d\u00eda , o no","required":false},"start_date":{"type":"string","description":"Fecha y hora de inicio del evento","required":true},"end_date":{"type":"string","description":"Fecha y hora de finalizaci\u00f3n del evento","required":true},"image":{"type":"string","description":"La URL o ID de la imagen destacada del evento","required":false},"cost":{"description":"Coste del evento","required":false},"website":{"default":null,"description":"URL del sitio web del evento","required":false},"show_map":{"type":"boolean","description":"Si el evento debe mostrar un mapa , o no","required":false},"show_map_link":{"type":"boolean","description":"Si el evento debe mostrar un enlace al mapa , o no","required":false},"hide_from_listings":{"type":"boolean","description":"Si los eventos deben ocultarse en la vista de calendario, o no","required":false},"sticky":{"type":"boolean","description":"Si el evento debe fijarse en la vista de calendario , o no","required":false},"featured":{"type":"boolean","description":"Si el evento debe aparecer destacado en el sitio , o no","required":false},"categories":{"default":null,"items":{"type":"integer"},"description":"El ID , o nombre de la categor\u00eda del evento","required":false},"tags":{"default":null,"items":{"type":"integer"},"description":"El ID , o nombre, de la etiqueta del evento","required":false},"venue":{"default":null,"items":{"type":"integer"},"description":"El ID o datos del recinto del evento","required":false},"organizer":{"default":null,"items":{"type":"integer"},"description":"ID o datos del organizador del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1\/events"}]}},"\/tribe\/events\/v1\/events\/(?P<id>\\d+)":{"namespace":"tribe\/events\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"ID de la entrada del evento","required":true},"password":{"type":"string","description":"La contrase\u00f1a del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"ID de la entrada del evento","required":true},"password":{"type":"string","description":"La contrase\u00f1a del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"ID de la entrada del evento","required":true},"password":{"type":"string","description":"La contrase\u00f1a del evento","required":false},"author":{"type":"integer","description":"ID del autor del evento","required":false},"date":{"type":"string","description":"Fecha de publicaci\u00f3n del evento","required":false},"date_utc":{"type":"string","description":"Fecha de publicaci\u00f3n del evento (Zona horaria UTC)","required":false},"title":{"type":"string","description":"Titulo del evento","required":false},"description":{"type":"string","description":"Descripci\u00f3n del evento","required":false},"slug":{"type":"string","description":"El slug del evento","required":false},"excerpt":{"type":"string","description":"Extracto del evento","required":false},"status":{"type":"string","description":"Estado de la entrada del evento","required":false},"timezone":{"type":"string","description":"Zona horaria del evento","required":false},"all_day":{"default":false,"type":"boolean","description":"Si el evento dura todo el d\u00eda , o no","required":false},"start_date":{"type":"string","description":"Fecha y hora de inicio del evento","required":false},"end_date":{"type":"string","description":"Fecha y hora de finalizaci\u00f3n del evento","required":false},"image":{"type":"string","description":"La URL o ID de la imagen destacada del evento","required":false},"cost":{"description":"Coste del evento","required":false},"website":{"default":null,"description":"URL del sitio web del evento","required":false},"show_map":{"type":"boolean","description":"Si el evento debe mostrar un mapa , o no","required":false},"show_map_link":{"type":"boolean","description":"Si el evento debe mostrar un enlace al mapa , o no","required":false},"hide_from_listings":{"type":"boolean","description":"Si los eventos deben ocultarse en la vista de calendario, o no","required":false},"sticky":{"type":"boolean","description":"Si el evento debe fijarse en la vista de calendario , o no","required":false},"featured":{"type":"boolean","description":"Si el evento debe aparecer destacado en el sitio , o no","required":false},"categories":{"default":null,"items":{"type":"integer"},"description":"El ID , o nombre de la categor\u00eda del evento","required":false},"tags":{"default":null,"items":{"type":"integer"},"description":"El ID , o nombre, de la etiqueta del evento","required":false},"venue":{"default":null,"items":{"type":"integer"},"description":"El ID o datos del recinto del evento","required":false},"organizer":{"default":null,"items":{"type":"integer"},"description":"ID o datos del organizador del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/events\/by-slug\/(?P<slug>[^\/]+)":{"namespace":"tribe\/events\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"nombre de la entrada del evento","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"type":"string","description":"nombre de la entrada del evento","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"El slug del evento","required":false},"author":{"type":"integer","description":"ID del autor del evento","required":false},"date":{"type":"string","description":"Fecha de publicaci\u00f3n del evento","required":false},"date_utc":{"type":"string","description":"Fecha de publicaci\u00f3n del evento (Zona horaria UTC)","required":false},"title":{"type":"string","description":"Titulo del evento","required":false},"description":{"type":"string","description":"Descripci\u00f3n del evento","required":false},"excerpt":{"type":"string","description":"Extracto del evento","required":false},"status":{"type":"string","description":"Estado de la entrada del evento","required":false},"timezone":{"type":"string","description":"Zona horaria del evento","required":false},"all_day":{"default":false,"type":"boolean","description":"Si el evento dura todo el d\u00eda , o no","required":false},"start_date":{"type":"string","description":"Fecha y hora de inicio del evento","required":false},"end_date":{"type":"string","description":"Fecha y hora de finalizaci\u00f3n del evento","required":false},"image":{"type":"string","description":"La URL o ID de la imagen destacada del evento","required":false},"cost":{"description":"Coste del evento","required":false},"website":{"default":null,"description":"URL del sitio web del evento","required":false},"show_map":{"type":"boolean","description":"Si el evento debe mostrar un mapa , o no","required":false},"show_map_link":{"type":"boolean","description":"Si el evento debe mostrar un enlace al mapa , o no","required":false},"hide_from_listings":{"type":"boolean","description":"Si los eventos deben ocultarse en la vista de calendario, o no","required":false},"sticky":{"type":"boolean","description":"Si el evento debe fijarse en la vista de calendario , o no","required":false},"featured":{"type":"boolean","description":"Si el evento debe aparecer destacado en el sitio , o no","required":false},"categories":{"default":null,"items":{"type":"integer"},"description":"El ID , o nombre de la categor\u00eda del evento","required":false},"tags":{"default":null,"items":{"type":"integer"},"description":"El ID , o nombre, de la etiqueta del evento","required":false},"venue":{"default":null,"items":{"type":"integer"},"description":"El ID o datos del recinto del evento","required":false},"organizer":{"default":null,"items":{"type":"integer"},"description":"ID o datos del organizador del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/venues":{"namespace":"tribe\/events\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"default":1,"description":"La p\u00e1gina de archivo a devolver","type":"integer","required":false},"per_page":{"default":"10","description":"El n\u00famero de recintos que se mostrar\u00e1 en cada p\u00e1gina","type":"integer","required":false},"search":{"description":"Los recintos deben contener la cadena especificada en el t\u00edtulo, la descripci\u00f3n o en los campos personalizados","type":"string","required":false},"event":{"description":"Los recintos deben estar relacionados con este evento","type":"integer","required":false},"has_events":{"description":"Los recintos deben tener eventos asociados","required":false},"only_with_upcoming":{"description":"Los recintos deben tener eventos pr\u00f3ximos asociados","default":false,"required":false},"status":{"format":"string","description":"Estado de la entrada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"author":{"type":"integer","description":"El ID de autor del recinto","required":false},"date":{"type":"string","description":"Fecha de publicaci\u00f3n del recinto","required":false},"date_utc":{"type":"string","description":"Fecha de publicaci\u00f3n del recinto (zona horaria UTC)","required":false},"venue":{"type":"string","description":"Nombre del recinto","required":true},"description":{"type":"string","default":null,"description":"La descripci\u00f3n del recinto","required":false},"status":{"type":"string","description":"El estado de la entrada del recinto","required":false},"show_map":{"type":"string","default":null,"description":"Si los eventos enlazados al recinto deber\u00edan mostrar un mapa, o no","required":false},"show_map_link":{"type":"string","default":null,"description":"Si los eventos enlazados al recinto deber\u00edan mostrar un enlace al mapa , o no","required":false},"address":{"type":"string","default":null,"description":"Direcci\u00f3n del recinto","required":false},"city":{"type":"string","default":null,"description":"Poblaci\u00f3n del recinto","required":false},"country":{"type":"string","default":null,"description":"Pa\u00eds del recinto","required":false},"province":{"type":"string","default":null,"description":"Provincia del recinto","required":false},"state":{"type":"string","default":null,"description":"Estado del recinto","required":false},"zip":{"type":"string","default":null,"description":"C\u00f3digo postal del recinto","required":false},"phone":{"type":"string","default":null,"description":"N\u00famero de tel\u00e9fono del recinto","required":false},"stateprovince":{"type":"string","default":null,"description":"Estado y provincia del recinto","required":false},"website":{"type":"string","default":null,"description":"URL del sitio web del recinto","required":false},"image":{"type":"string","default":null,"description":"ID o URL de la imagen destacada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1\/venues"}]}},"\/tribe\/events\/v1\/venues\/(?P<id>\\d+)":{"namespace":"tribe\/events\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"ID de la entrada del recinto","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"ID de la entrada del recinto","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"ID de la entrada del recinto","required":true},"author":{"type":"integer","description":"El ID de autor del recinto","required":false},"date":{"type":"string","description":"Fecha de publicaci\u00f3n del recinto","required":false},"date_utc":{"type":"string","description":"Fecha de publicaci\u00f3n del recinto (zona horaria UTC)","required":false},"venue":{"type":"string","description":"Nombre del recinto","required":false},"description":{"type":"string","default":null,"description":"La descripci\u00f3n del recinto","required":false},"status":{"type":"string","description":"El estado de la entrada del recinto","required":false},"show_map":{"type":"string","default":null,"description":"Si los eventos enlazados al recinto deber\u00edan mostrar un mapa, o no","required":false},"show_map_link":{"type":"string","default":null,"description":"Si los eventos enlazados al recinto deber\u00edan mostrar un enlace al mapa , o no","required":false},"address":{"type":"string","default":null,"description":"Direcci\u00f3n del recinto","required":false},"city":{"type":"string","default":null,"description":"Poblaci\u00f3n del recinto","required":false},"country":{"type":"string","default":null,"description":"Pa\u00eds del recinto","required":false},"province":{"type":"string","default":null,"description":"Provincia del recinto","required":false},"state":{"type":"string","default":null,"description":"Estado del recinto","required":false},"zip":{"type":"string","default":null,"description":"C\u00f3digo postal del recinto","required":false},"phone":{"type":"string","default":null,"description":"N\u00famero de tel\u00e9fono del recinto","required":false},"stateprovince":{"type":"string","default":null,"description":"Estado y provincia del recinto","required":false},"website":{"type":"string","default":null,"description":"URL del sitio web del recinto","required":false},"image":{"type":"string","default":null,"description":"ID o URL de la imagen destacada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/venues\/by-slug\/(?P<slug>[^\/]+)":{"namespace":"tribe\/events\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"el nombre de la entrada del recinto","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"type":"string","description":"el nombre de la entrada del recinto","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"el nombre de la entrada del recinto","required":true},"author":{"type":"integer","description":"El ID de autor del recinto","required":false},"date":{"type":"string","description":"Fecha de publicaci\u00f3n del recinto","required":false},"date_utc":{"type":"string","description":"Fecha de publicaci\u00f3n del recinto (zona horaria UTC)","required":false},"venue":{"type":"string","description":"Nombre del recinto","required":false},"description":{"type":"string","default":null,"description":"La descripci\u00f3n del recinto","required":false},"status":{"type":"string","description":"El estado de la entrada del recinto","required":false},"show_map":{"type":"string","default":null,"description":"Si los eventos enlazados al recinto deber\u00edan mostrar un mapa, o no","required":false},"show_map_link":{"type":"string","default":null,"description":"Si los eventos enlazados al recinto deber\u00edan mostrar un enlace al mapa , o no","required":false},"address":{"type":"string","default":null,"description":"Direcci\u00f3n del recinto","required":false},"city":{"type":"string","default":null,"description":"Poblaci\u00f3n del recinto","required":false},"country":{"type":"string","default":null,"description":"Pa\u00eds del recinto","required":false},"province":{"type":"string","default":null,"description":"Provincia del recinto","required":false},"state":{"type":"string","default":null,"description":"Estado del recinto","required":false},"zip":{"type":"string","default":null,"description":"C\u00f3digo postal del recinto","required":false},"phone":{"type":"string","default":null,"description":"N\u00famero de tel\u00e9fono del recinto","required":false},"stateprovince":{"type":"string","default":null,"description":"Estado y provincia del recinto","required":false},"website":{"type":"string","default":null,"description":"URL del sitio web del recinto","required":false},"image":{"type":"string","default":null,"description":"ID o URL de la imagen destacada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/organizers":{"namespace":"tribe\/events\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"default":1,"description":"La p\u00e1gina de archivo a devolver","type":"integer","required":false},"per_page":{"default":"10","description":"El n\u00famero de organizadores que se mostrar\u00e1 en cada p\u00e1gina","type":"integer","required":false},"search":{"description":"Los organizadores deben tener la cadena especificada en el t\u00edtulo, descripci\u00f3n o campos personalizados","type":"string","required":false},"event":{"description":"Los organizadores deben estar relacionados con este evento","type":"integer","required":false},"has_events":{"description":"Los organizadores deben tener eventos asociados a ellos","required":false},"only_with_upcoming":{"description":"Lo organizadores deben tener asociados pr\u00f3ximos eventos","default":false,"required":false},"status":{"format":"string","description":"Estado de la entrada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"author":{"type":"integer","default":null,"description":"ID de autor del organizador","required":false},"date":{"type":"string","default":null,"description":"Fecha de publicaci\u00f3n del organizador","required":false},"date_utc":{"type":"string","default":null,"description":"Fecha de publicaci\u00f3n del organizador (Zona horaria UTC)","required":false},"organizer":{"type":"string","default":null,"description":"Nombre del organizador","required":true},"description":{"type":"string","default":null,"description":"Descripci\u00f3n del organizador","required":false},"status":{"type":"string","default":null,"description":"Estado de la entrada del organizador","required":false},"phone":{"type":"string","default":null,"description":"N\u00famero de tel\u00e9fono del organizador","required":false},"website":{"type":"string","default":null,"description":"Sitio web del organizador","required":false},"email":{"type":"string","default":null,"description":"Correo electr\u00f3nico del organizador","required":false},"image":{"type":"string","default":null,"description":"ID o URL de la imagen destacada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1\/organizers"}]}},"\/tribe\/events\/v1\/organizers\/(?P<id>\\d+)":{"namespace":"tribe\/events\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"ID de la entrada del organizador","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"ID de la entrada del organizador","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"ID de la entrada del organizador","required":true},"author":{"type":"integer","default":null,"description":"ID de autor del organizador","required":false},"date":{"type":"string","default":null,"description":"Fecha de publicaci\u00f3n del organizador","required":false},"date_utc":{"type":"string","default":null,"description":"Fecha de publicaci\u00f3n del organizador (Zona horaria UTC)","required":false},"organizer":{"type":"string","default":null,"description":"Nombre del organizador","required":false},"description":{"type":"string","default":null,"description":"Descripci\u00f3n del organizador","required":false},"status":{"type":"string","default":null,"description":"Estado de la entrada del organizador","required":false},"phone":{"type":"string","default":null,"description":"N\u00famero de tel\u00e9fono del organizador","required":false},"website":{"type":"string","default":null,"description":"Sitio web del organizador","required":false},"email":{"type":"string","default":null,"description":"Correo electr\u00f3nico del organizador","required":false},"image":{"type":"string","default":null,"description":"ID o URL de la imagen destacada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/organizers\/by-slug\/(?P<slug>[^\/]+)":{"namespace":"tribe\/events\/v1","methods":["GET","DELETE","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"nombre de la entrada del organizador","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"type":"string","description":"nombre de la entrada del organizador","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"nombre de la entrada del organizador","required":true},"author":{"type":"integer","default":null,"description":"ID de autor del organizador","required":false},"date":{"type":"string","default":null,"description":"Fecha de publicaci\u00f3n del organizador","required":false},"date_utc":{"type":"string","default":null,"description":"Fecha de publicaci\u00f3n del organizador (Zona horaria UTC)","required":false},"organizer":{"type":"string","default":null,"description":"Nombre del organizador","required":false},"description":{"type":"string","default":null,"description":"Descripci\u00f3n del organizador","required":false},"status":{"type":"string","default":null,"description":"Estado de la entrada del organizador","required":false},"phone":{"type":"string","default":null,"description":"N\u00famero de tel\u00e9fono del organizador","required":false},"website":{"type":"string","default":null,"description":"Sitio web del organizador","required":false},"email":{"type":"string","default":null,"description":"Correo electr\u00f3nico del organizador","required":false},"image":{"type":"string","default":null,"description":"ID o URL de la imagen destacada del organizador","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/categories":{"namespace":"tribe\/events\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"default":1,"description":"La p\u00e1gina de archivo a devolver","type":"integer","required":false},"per_page":{"default":"10","description":"El n\u00famero de categor\u00edas de eventos que se mostrar\u00e1 en cada p\u00e1gina","type":"integer","required":false},"search":{"description":"Limitar resultados a aquellos con coinciden con una cadena","type":"string","required":false},"exclude":{"description":"Forzar la exclusi\u00f3n de ID espec\u00edficos de los resultados","items":{"type":"integer"},"required":false},"include":{"description":"Limitar el conjunto resultante a ID espec\u00edficos","items":{"type":"integer"},"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente","type":"string","required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributos de t\u00e9rmino","type":"string","required":false},"hide_empty":{"description":"Si de ocultan los t\u00e9rminos no asignados a ninguna entrada","type":"boolean","default":"1","required":false},"parent":{"description":"Limitar resultados a t\u00e9rminos asignados a uno espec\u00edfico superior","type":"integer","required":false},"post":{"description":"Limitar resultados a t\u00e9rminos asignados a una entrada espec\u00edfica","type":"integer","required":false},"event":{"description":"Limitar resultados a t\u00e9rminos asociados a un evento espec\u00edfico (un alias del par\u00e1metro \u00abpost\u00bb)","type":"integer","required":false},"slug":{"description":"Limitar resultados a t\u00e9rminos con un slug espec\u00edfico","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre de la categor\u00eda del evento","required":true},"description":{"type":"string","description":"Descripci\u00f3n de la categor\u00eda del evento","required":false},"slug":{"type":"string","description":"Slug de la categor\u00eda del evento","required":false},"parent":{"type":"integer","description":"Slug de la categor\u00eda del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1\/categories"}]}},"\/tribe\/events\/v1\/categories\/(?P<id>\\d+)":{"namespace":"tribe\/events\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"ID de la categor\u00eda del evento","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"ID de la categor\u00eda del evento","required":true},"name":{"type":"string","description":"Nombre de la categor\u00eda del evento","required":false},"description":{"type":"string","description":"Descripci\u00f3n de la categor\u00eda del evento","required":false},"slug":{"type":"string","description":"Slug de la categor\u00eda del evento","required":false},"parent":{"type":"integer","description":"Slug de la categor\u00eda del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"ID de la categor\u00eda del evento","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/events\/v1\/tags":{"namespace":"tribe\/events\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"default":1,"description":"La p\u00e1gina de archivo a devolver","type":"integer","required":false},"per_page":{"default":"10","description":"El n\u00famero de etiquetas de evento que se mostrar\u00e1 en cada p\u00e1gina","type":"integer","required":false},"search":{"description":"Limitar resultados a aquellos con coinciden con una cadena","type":"string","required":false},"exclude":{"description":"Forzar la exclusi\u00f3n de ID espec\u00edficos de los resultados","items":{"type":"integer"},"required":false},"include":{"description":"Limitar el conjunto resultante a ID espec\u00edficos","items":{"type":"integer"},"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente","type":"string","required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributos de t\u00e9rmino","type":"string","required":false},"hide_empty":{"description":"Si de ocultan los t\u00e9rminos no asignados a ninguna entrada","type":"boolean","default":"1","required":false},"post":{"description":"Limitar resultados a t\u00e9rminos asignados a una entrada espec\u00edfica","type":"integer","required":false},"event":{"description":"Limitar resultados a t\u00e9rminos asociados a un evento espec\u00edfico (un alias del par\u00e1metro \u00abpost\u00bb)","type":"integer","required":false},"slug":{"description":"Limitar resultados a t\u00e9rminos con un slug espec\u00edfico","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre de la etiqueta del evento","required":true},"description":{"type":"string","description":"Descripci\u00f3n de la etiqueta del evento","required":false},"slug":{"type":"string","description":"Slug de la etiqueta del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/events\/v1\/tags"}]}},"\/tribe\/events\/v1\/tags\/(?P<id>\\d+)":{"namespace":"tribe\/events\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"type":"integer","description":"el ID del t\u00e9rmino de la etiqueta del evento","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"integer","description":"el ID del t\u00e9rmino de la etiqueta del evento","required":true},"name":{"type":"string","description":"Nombre de la etiqueta del evento","required":false},"description":{"type":"string","description":"Descripci\u00f3n de la etiqueta del evento","required":false},"slug":{"type":"string","description":"Slug de la etiqueta del evento","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"type":"integer","description":"el ID del t\u00e9rmino de la etiqueta del evento","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tribe\/views\/v2":{"namespace":"tribe\/views\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tribe\/views\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/views\/v2"}]}},"\/tribe\/views\/v2\/html":{"namespace":"tribe\/views\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"u":{"required":true},"view":{"required":false},"tvn1":{"required":false},"tvn2":{"required":false},"view_data":{"required":false},"action":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tribe\/views\/v2\/html"}]}},"\/tec\/v2\/onboarding":{"namespace":"tec\/v2\/onboarding","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tec\/v2\/onboarding","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v2\/onboarding"}]}},"\/tec\/v2\/onboarding\/wizard":{"namespace":"tec\/v2\/onboarding","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action_nonce":{"type":"string","description":"El nonce de la acci\u00f3n de la solicitud.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v2\/onboarding\/wizard"}]}},"\/tec\/v1":{"namespace":"tec\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"tec\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v1"}]}},"\/tec\/v1\/events":{"namespace":"tec\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"El n\u00famero de p\u00e1gina de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"maximum":100,"minimum":1,"required":false},"start_date":{"description":"Limitar los eventos a los que empiecen despu\u00e9s de la fecha especificada.","type":"string","format":"date-time","required":false},"end_date":{"description":"Limitar los eventos a los que terminan antes de la fecha especificada.","type":"string","format":"date-time","required":false},"search":{"description":"Limitar los resultados a lo indicado en la cadena.","type":"string","required":false},"categories":{"description":"Limitar el conjunto de resultados a los eventos asignados a categor\u00edas espec\u00edficas.","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"tags":{"description":"Limitar el conjunto de resultados a los eventos que tengan asignadas etiquetas espec\u00edficas.","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"venue":{"description":"Limitar el conjunto de resultados a los eventos asignados a sedes espec\u00edficas.","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"organizer":{"description":"Limitar el conjunto de resultados a los eventos asignados a organizadores espec\u00edficos.","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"featured":{"description":"Limitar el conjunto de resultados s\u00f3lo a los eventos destacados.","type":"boolean","required":false},"status":{"description":"Limitar el conjunto de resultados a los eventos con un estado espec\u00edfico.","type":"array","items":{"type":"string","enum":["publish","pending","draft","future","private"]},"default":["publish"],"uniqueItems":true,"required":false},"post_parent":{"description":"Limitar el conjunto de resultados a los eventos con una entrada superior espec\u00edfica.","type":"integer","required":false},"starts_before":{"description":"Limitar el conjunto de resultados a los eventos que empiezan antes de la fecha especificada.","type":"string","format":"date-time","required":false},"starts_after":{"description":"Limitar el conjunto de resultados a los eventos que empiecen despu\u00e9s de la fecha especificada.","type":"string","format":"date-time","required":false},"ends_before":{"description":"Limitar el conjunto de resultados a los eventos que finalizan antes de la fecha especificada.","type":"string","format":"date-time","required":false},"ends_after":{"description":"Limitar el conjunto de resultados a los eventos que terminen despu\u00e9s de la fecha especificada.","type":"string","format":"date-time","required":false},"ticketed":{"description":"Limitar el conjunto de resultados a los eventos con entradas.","type":"boolean","required":false},"orderby":{"description":"Ordena la colecci\u00f3n por atributo de evento.","type":"string","default":"event_date","enum":["date","event_date","title","menu_order","modified"],"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"ASC","enum":["ASC","DESC"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the entity was published, in the site's timezone. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"date_gmt":{"description":"The date the entity was published, as GMT. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"slug":{"description":"An alphanumeric identifier for the entity unique to its type","type":"string","required":false},"status":{"description":"A named status for the entity.","type":"string","default":"publish","enum":["publish","pending","draft","future","private"],"required":false},"title":{"description":"HTML title for the entity, transformed for display","type":"string","required":false},"content":{"description":"HTML content for the entity, transformed for display","type":"string","required":false},"excerpt":{"description":"HTML excerpt for the entity, transformed for display","type":"string","required":false},"author":{"description":"The ID for the author of the entity.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the entity.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the entity.","type":"string","default":"open","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the entity can be pinged","type":"string","default":"open","enum":["open","closed"],"required":false},"format":{"description":"The format for the entity.","type":"string","default":"standard","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"sticky":{"description":"Si el evento est\u00e1 fijo","type":"boolean","required":false},"template":{"description":"The theme file to use to display the entity.","type":"string","required":false},"tags":{"description":"The terms assigned to the entity in the post_tag taxonomy","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"tribe_events_cat":{"description":"Los t\u00e9rminos asignados a la entidad en la taxonom\u00eda tribe_events_cat","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"start_date":{"description":"La fecha de inicio del evento","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"start_date_utc":{"description":"La fecha de inicio del evento en UTC","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"end_date":{"description":"La fecha de finalizaci\u00f3n del evento","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"end_date_utc":{"description":"La fecha de finalizaci\u00f3n del evento en UTC","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"timezone":{"description":"La zona horaria del evento","type":"string","required":false},"duration":{"description":"La duraci\u00f3n del evento en segundos","type":"integer","required":false},"all_day":{"description":"Si el evento dura todo el d\u00eda","type":"boolean","required":false},"featured":{"description":"Si el evento est\u00e1 destacado","type":"boolean","required":false},"cost":{"description":"El coste del evento","type":"string","required":false},"organizers":{"description":"Los organizadores del evento","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"venues":{"description":"Los recintos del evento","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v1\/events"}]}},"\/tec\/v1\/events\/(?P<id>\\d+)":{"namespace":"tec\/v1","methods":["GET","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["PUT","PATCH"],"args":{"date":{"description":"The date the entity was published, in the site's timezone. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"date_gmt":{"description":"The date the entity was published, as GMT. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"slug":{"description":"An alphanumeric identifier for the entity unique to its type","type":"string","required":false},"status":{"description":"A named status for the entity.","type":"string","default":"publish","enum":["publish","pending","draft","future","private"],"required":false},"title":{"description":"HTML title for the entity, transformed for display","type":"string","required":false},"content":{"description":"HTML content for the entity, transformed for display","type":"string","required":false},"excerpt":{"description":"HTML excerpt for the entity, transformed for display","type":"string","required":false},"author":{"description":"The ID for the author of the entity.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the entity.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the entity.","type":"string","default":"open","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the entity can be pinged","type":"string","default":"open","enum":["open","closed"],"required":false},"format":{"description":"The format for the entity.","type":"string","default":"standard","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"sticky":{"description":"Si el evento est\u00e1 fijo","type":"boolean","required":false},"template":{"description":"The theme file to use to display the entity.","type":"string","required":false},"tags":{"description":"The terms assigned to the entity in the post_tag taxonomy","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"tribe_events_cat":{"description":"Los t\u00e9rminos asignados a la entidad en la taxonom\u00eda tribe_events_cat","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"start_date":{"description":"La fecha de inicio del evento","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"start_date_utc":{"description":"La fecha de inicio del evento en UTC","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"end_date":{"description":"La fecha de finalizaci\u00f3n del evento","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"end_date_utc":{"description":"La fecha de finalizaci\u00f3n del evento en UTC","type":"string","format":"date-time","pattern":"^[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2}$","required":false},"timezone":{"description":"La zona horaria del evento","type":"string","required":false},"duration":{"description":"La duraci\u00f3n del evento en segundos","type":"integer","required":false},"all_day":{"description":"Si el evento dura todo el d\u00eda","type":"boolean","required":false},"featured":{"description":"Si el evento est\u00e1 destacado","type":"boolean","required":false},"cost":{"description":"El coste del evento","type":"string","required":false},"organizers":{"description":"Los organizadores del evento","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"venues":{"description":"Los recintos del evento","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"description":"Whether to bypass Trash and force deletion.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tec\/v1\/organizers":{"namespace":"tec\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"El n\u00famero de p\u00e1gina de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"maximum":100,"minimum":1,"required":false},"search":{"description":"Limitar los resultados a lo indicado en la cadena.","type":"string","required":false},"event":{"description":"Limitar el conjunto de resultados a los organizadores con un evento espec\u00edfico.","type":"integer","required":false},"has_events":{"description":"Limitar el conjunto de resultados a los organizadores con eventos.","type":"boolean","required":false},"only_with_upcoming":{"description":"Limitar el conjunto de resultados a los organizadores con pr\u00f3ximos eventos.","type":"boolean","required":false},"status":{"description":"Limitar el conjunto de resultados a los organizadores con un estado espec\u00edfico.","type":"array","items":{"type":"string","enum":["publish","pending","draft","future","private"]},"default":["publish"],"uniqueItems":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the entity was published, in the site's timezone. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"date_gmt":{"description":"The date the entity was published, as GMT. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"slug":{"description":"An alphanumeric identifier for the entity unique to its type","type":"string","required":false},"status":{"description":"A named status for the entity.","type":"string","default":"publish","enum":["publish","pending","draft","future","private"],"required":false},"title":{"description":"HTML title for the entity, transformed for display","type":"string","required":false},"content":{"description":"HTML content for the entity, transformed for display","type":"string","required":false},"excerpt":{"description":"HTML excerpt for the entity, transformed for display","type":"string","required":false},"author":{"description":"The ID for the author of the entity.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the entity.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the entity.","type":"string","default":"open","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the entity can be pinged","type":"string","default":"open","enum":["open","closed"],"required":false},"format":{"description":"The format for the entity.","type":"string","default":"standard","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"sticky":{"description":"Whether or not the entity should be treated as sticky","type":"boolean","default":false,"required":false},"template":{"description":"The theme file to use to display the entity.","type":"string","required":false},"tags":{"description":"The terms assigned to the entity in the post_tag taxonomy","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"phone":{"description":"N\u00famero de tel\u00e9fono del organizador","type":"string","format":"tel","required":false},"website":{"description":"Sitio web del organizador","type":"string","format":"uri","required":false},"email":{"description":"Direcci\u00f3n de correo electr\u00f3nico del organizador","type":"string","format":"email","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v1\/organizers"}]}},"\/tec\/v1\/organizers\/(?P<id>\\d+)":{"namespace":"tec\/v1","methods":["GET","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["PUT","PATCH"],"args":{"date":{"description":"The date the entity was published, in the site's timezone. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"date_gmt":{"description":"The date the entity was published, as GMT. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"slug":{"description":"An alphanumeric identifier for the entity unique to its type","type":"string","required":false},"status":{"description":"A named status for the entity.","type":"string","default":"publish","enum":["publish","pending","draft","future","private"],"required":false},"title":{"description":"HTML title for the entity, transformed for display","type":"string","required":false},"content":{"description":"HTML content for the entity, transformed for display","type":"string","required":false},"excerpt":{"description":"HTML excerpt for the entity, transformed for display","type":"string","required":false},"author":{"description":"The ID for the author of the entity.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the entity.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the entity.","type":"string","default":"open","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the entity can be pinged","type":"string","default":"open","enum":["open","closed"],"required":false},"format":{"description":"The format for the entity.","type":"string","default":"standard","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"sticky":{"description":"Whether or not the entity should be treated as sticky","type":"boolean","default":false,"required":false},"template":{"description":"The theme file to use to display the entity.","type":"string","required":false},"tags":{"description":"The terms assigned to the entity in the post_tag taxonomy","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"phone":{"description":"N\u00famero de tel\u00e9fono del organizador","type":"string","format":"tel","required":false},"website":{"description":"Sitio web del organizador","type":"string","format":"uri","required":false},"email":{"description":"Direcci\u00f3n de correo electr\u00f3nico del organizador","type":"string","format":"email","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"description":"Whether to bypass Trash and force deletion.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tec\/v1\/venues":{"namespace":"tec\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"El n\u00famero de p\u00e1gina de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"maximum":100,"minimum":1,"required":false},"search":{"description":"Limitar los resultados a lo indicado en la cadena.","type":"string","required":false},"event":{"description":"Limita el conjunto de resultados a los recintos con un evento espec\u00edfico.","type":"integer","required":false},"has_events":{"description":"Limita el conjunto de resultados a los recintos con eventos.","type":"boolean","required":false},"only_with_upcoming":{"description":"Limita el conjunto de resultados a los recintos con pr\u00f3ximos eventos.","type":"boolean","required":false},"status":{"description":"Limita el conjunto de resultados a los recintos con un estado espec\u00edfico.","type":"array","items":{"type":"string","enum":["publish","pending","draft","future","private"]},"default":["publish"],"uniqueItems":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"The date the entity was published, in the site's timezone. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"date_gmt":{"description":"The date the entity was published, as GMT. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"slug":{"description":"An alphanumeric identifier for the entity unique to its type","type":"string","required":false},"status":{"description":"A named status for the entity.","type":"string","default":"publish","enum":["publish","pending","draft","future","private"],"required":false},"title":{"description":"HTML title for the entity, transformed for display","type":"string","required":false},"content":{"description":"HTML content for the entity, transformed for display","type":"string","required":false},"excerpt":{"description":"HTML excerpt for the entity, transformed for display","type":"string","required":false},"author":{"description":"The ID for the author of the entity.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the entity.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the entity.","type":"string","default":"open","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the entity can be pinged","type":"string","default":"open","enum":["open","closed"],"required":false},"format":{"description":"The format for the entity.","type":"string","default":"standard","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"sticky":{"description":"Whether or not the entity should be treated as sticky","type":"boolean","default":false,"required":false},"template":{"description":"The theme file to use to display the entity.","type":"string","required":false},"tags":{"description":"The terms assigned to the entity in the post_tag taxonomy","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"address":{"description":"Direcci\u00f3n del recinto","type":"string","required":false},"country":{"description":"Pa\u00eds del recinto","type":"string","required":false},"city":{"description":"Poblaci\u00f3n del recinto","type":"string","required":false},"state_province":{"description":"Estado\/provincia del recinto","type":"string","required":false},"state":{"description":"Estado del recinto","type":"string","required":false},"province":{"description":"Provincia del recinto","type":"string","required":false},"zip":{"description":"C\u00f3digo postal del recinto","type":"string","required":false},"phone":{"description":"N\u00famero de tel\u00e9fono del recinto","type":"string","required":false},"website":{"description":"Sitio web del recinto","type":"string","format":"uri","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v1\/venues"}]}},"\/tec\/v1\/venues\/(?P<id>\\d+)":{"namespace":"tec\/v1","methods":["GET","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["PUT","PATCH"],"args":{"date":{"description":"The date the entity was published, in the site's timezone. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"date_gmt":{"description":"The date the entity was published, as GMT. In RFC3339 format.","type":"string","format":"date-time","pattern":"^\\d{4}-\\d{2}-\\d{2}[Tt ]\\d{2}:\\d{2}:\\d{2}(?:\\.\\d+)?(?:Z|[+-]\\d{2}(?::\\d{2})?)?$","required":false},"slug":{"description":"An alphanumeric identifier for the entity unique to its type","type":"string","required":false},"status":{"description":"A named status for the entity.","type":"string","default":"publish","enum":["publish","pending","draft","future","private"],"required":false},"title":{"description":"HTML title for the entity, transformed for display","type":"string","required":false},"content":{"description":"HTML content for the entity, transformed for display","type":"string","required":false},"excerpt":{"description":"HTML excerpt for the entity, transformed for display","type":"string","required":false},"author":{"description":"The ID for the author of the entity.","type":"integer","required":false},"featured_media":{"description":"The ID of the featured media for the entity.","type":"integer","required":false},"comment_status":{"description":"Whether or not comments are open on the entity.","type":"string","default":"open","enum":["open","closed"],"required":false},"ping_status":{"description":"Whether or not the entity can be pinged","type":"string","default":"open","enum":["open","closed"],"required":false},"format":{"description":"The format for the entity.","type":"string","default":"standard","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"sticky":{"description":"Whether or not the entity should be treated as sticky","type":"boolean","default":false,"required":false},"template":{"description":"The theme file to use to display the entity.","type":"string","required":false},"tags":{"description":"The terms assigned to the entity in the post_tag taxonomy","type":"array","items":{"type":"integer"},"uniqueItems":true,"required":false},"address":{"description":"Direcci\u00f3n del recinto","type":"string","required":false},"country":{"description":"Pa\u00eds del recinto","type":"string","required":false},"city":{"description":"Poblaci\u00f3n del recinto","type":"string","required":false},"state_province":{"description":"Estado\/provincia del recinto","type":"string","required":false},"state":{"description":"Estado del recinto","type":"string","required":false},"province":{"description":"Provincia del recinto","type":"string","required":false},"zip":{"description":"C\u00f3digo postal del recinto","type":"string","required":false},"phone":{"description":"N\u00famero de tel\u00e9fono del recinto","type":"string","required":false},"website":{"description":"Sitio web del recinto","type":"string","format":"uri","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"description":"Whether to bypass Trash and force deletion.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/tec\/v1\/docs":{"namespace":"tec\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/tec\/v1\/docs"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/sync\/full-sync":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"description":"M\u00f3dulos de datos que se deber\u00edan incluir en la sincronizaci\u00f3n completa","type":"array","required":false},"users":{"description":"IDs de usuario que quieras incluir en la sincronizaci\u00f3n completa o \u00abinicial\u00bb","required":false},"posts":{"description":"IDs de entrada que quieras incluir en la sincronizaci\u00f3n completa","type":"array","required":false},"comments":{"description":"IDs de comentario que quieras incluir en la sincronizaci\u00f3n completa","type":"array","required":false},"context":{"description":"Contexto para una sincronizaci\u00f3n completa","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/full-sync"}]}},"\/jetpack\/v4\/sync\/status":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"fields":{"description":"Lista separada por comas de los campos adicionales que deben incluirse en el estado.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/status"}]}},"\/jetpack\/v4\/sync\/health":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"description":"Estado de salud de la nueva sincronizaci\u00f3n","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/health"}]}},"\/jetpack\/v4\/sync\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/settings"}]}},"\/jetpack\/v4\/sync\/object":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"module_name":{"description":"Nombre del m\u00f3dulo de sincronizaci\u00f3n","type":"string","required":false},"object_type":{"description":"Tipo de objeto","type":"string","required":false},"object_ids":{"description":"Identificadores de objetos ","type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/object"}]}},"\/jetpack\/v4\/sync\/now":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nombre de la cola de sincronizaci\u00f3n. ","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/now"}]}},"\/jetpack\/v4\/sync\/checkout":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nombre de la cola de sincronizaci\u00f3n. ","type":"string","required":false},"number_of_items":{"description":"N\u00famero de elementos a pagar de la cola.","type":"integer","required":false},"pop":{"description":"Extrae los elementos directamente de la cola en lugar de usar el m\u00e9todo de extracci\u00f3n est\u00e1ndar.","type":"boolean","required":false},"force":{"description":"Forzar el desbloqueo de la cola antes de la extracci\u00f3n.","type":"boolean","required":false},"encode":{"description":"Codifica los elementos antes de enviarlos.","type":"boolean","default":true,"required":false},"use_memory_limit":{"description":"Usa la extracci\u00f3n basada en memoria en lugar de un n\u00famero fijo de elementos.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/checkout"}]}},"\/jetpack\/v4\/sync\/close":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/close"}]}},"\/jetpack\/v4\/sync\/unlock":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nombre de la cola de sincronizaci\u00f3n. ","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/unlock"}]}},"\/jetpack\/v4\/sync\/object-id-range":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"sync_module":{"description":"Nombre del m\u00f3dulo de sincronizaci\u00f3n.","type":"string","required":true},"batch_size":{"description":"Tama\u00f1o de los procesos","type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/object-id-range"}]}},"\/jetpack\/v4\/sync\/data-check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"perform_text_conversion":{"description":"Si los campos de texto se deben convertir a latin1 en la suma de comprobaci\u00f3n.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/data-check"}]}},"\/jetpack\/v4\/sync\/data-histogram":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"columns":{"description":"Asignaciones de columnas","type":"array","required":false},"object_type":{"description":"Tipo de objeto","type":"string","required":false},"buckets":{"description":"N\u00famero de contenedores del histograma.","type":"int","required":false},"start_id":{"description":"ID de inicio del histograma","type":"int","required":false},"end_id":{"description":"ID final del histograma","type":"int","required":false},"strip_non_ascii":{"description":"\u00bfQuieres eliminar los caracteres que no est\u00e1n en ASCII?","type":"boolean","required":false},"shared_salt":{"description":"Salt compartido que se utilizar\u00e1 al generar la suma de comprobaci\u00f3n","type":"string","required":false},"only_range_edges":{"description":"\u00bfDeben devolverse solo los extremos del rango?","type":"boolean","required":false},"detailed_drilldown":{"description":"\u00bfQueremos la suma de comprobaci\u00f3n o el ID del objeto?","type":"boolean","required":false},"perform_text_conversion":{"description":"Si los campos de texto se deben convertir a latin1 en la suma de comprobaci\u00f3n.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/data-histogram"}]}},"\/jetpack\/v4\/sync\/spawn-sync":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/spawn-sync"}]}},"\/jetpack\/v4\/sync\/locks":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/locks"}]}},"\/jetpack\/v4\/sync\/clear-queue":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/sync\/clear-queue"}]}},"\/jetpack\/v4\/jitm":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/jitm"}]}},"\/jetpack\/v4\/identity-crisis\/confirm-safe-mode":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/identity-crisis\/confirm-safe-mode"}]}},"\/jetpack\/v4\/identity-crisis\/migrate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/identity-crisis\/migrate"}]}},"\/jetpack\/v4\/identity-crisis\/start-fresh":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"redirect_uri":{"description":"URI de la p\u00e1gina de administraci\u00f3n a la que se debe redirigir al usuario despu\u00e9s del proceso de conexi\u00f3n","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/identity-crisis\/start-fresh"}]}},"\/jetpack\/v4\/identity-crisis\/idc-url-validation":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/identity-crisis\/idc-url-validation"}]}},"\/jetpack\/v4\/identity-crisis\/url-secret":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/identity-crisis\/url-secret"}]}},"\/jetpack\/v4\/identity-crisis\/compare-url-secret":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"secret":{"description":"URL secreta para compararla con las almacenadas en la base de datos.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/identity-crisis\/compare-url-secret"}]}},"\/jetpack\/v4\/search\/plan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/plan"}]}},"\/jetpack\/v4\/search\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/settings"}]}},"\/jetpack\/v4\/search\/stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/stats"}]}},"\/jetpack\/v4\/search\/pricing":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/pricing"}]}},"\/jetpack\/v4\/search\/templates\/(?P<post_type>[a-z0-9_-]+)":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"post_type":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/search\/plan\/activate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/plan\/activate"}]}},"\/jetpack\/v4\/search\/plan\/deactivate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/plan\/deactivate"}]}},"\/jetpack\/v4\/search":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search"}]}},"\/jetpack\/v4\/search\/local-stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/search\/local-stats"}]}},"\/jetpack\/v4\/waf":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/waf"}]}},"\/jetpack\/v4\/waf\/update-rules":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/waf\/update-rules"}]}},"\/jetpack\/v4\/stats-app":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/stats-app","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/(?P<resource>[\\-\\w]+)\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/posts\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/posts\/(?P<resource_id>[\\d]+)\/likes":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/stats"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/site-has-never-published-post":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/site-has-never-published-post"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/posts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/posts"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/subscribers\/counts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/subscribers\/counts"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats\/usage":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats\/usage"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats\/user-feedback":{"namespace":"jetpack\/v4\/stats-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats\/user-feedback"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/wordads\/earnings":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/wordads\/earnings"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/wordads\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/wordads\/stats"}]}},"\/jetpack\/v4\/stats-app\/stats\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":null,"description":"Postponed for (in seconds)","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/stats\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats-dashboard\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":null,"description":"Postponed for (in seconds)","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats-dashboard\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/referrers\/spam":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/referrers\/spam"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/referrers\/spam\/new":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/referrers\/spam\/new"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/referrers\/spam\/delete":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/referrers\/spam\/delete"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats-dashboard\/modules":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats-dashboard\/modules"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats-dashboard\/module-settings":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/jetpack-stats-dashboard\/module-settings"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/emails\/(?P<resource>[\\-\\w\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/opens\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/clicks\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/(?P<resource>[\\-\\w]+)\/emails\/(?P<post_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/utm\/(?P<utm_params>[_,\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/devices\/(?P<device_property>[\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats-app\/sites\/234862722\/commercial-classification":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/commercial-classification"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/purchases":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats-app\/sites\/234862722\/purchases"}]}},"\/jetpack\/v4\/stats-app\/sites\/234862722\/stats\/location-views\/(?P<geo_mode>country|region|city)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/complianz\/v1":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"complianz\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1"}]}},"\/complianz\/v1\/documents":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/documents"}]}},"\/complianz\/v1\/banner":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/banner"}]}},"\/complianz\/v1\/track":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/track"}]}},"\/complianz\/v1\/manage_consent_html":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/manage_consent_html"}]}},"\/complianz\/v1\/store_cookies":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/store_cookies"}]}},"\/complianz\/v1\/consent-area\/(?P<post_id>([0-9]+))\/(?P<block_id>([a-z0-9-_]+))":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/complianz\/v1\/datarequests":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/datarequests"}]}},"\/complianz\/v1\/cookie_data":{"namespace":"complianz\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/cookie_data"}]}},"\/complianz\/v1\/wsc-scan":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/wsc-scan"}]}},"\/complianz\/v1\/wsc-checks":{"namespace":"complianz\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/complianz\/v1\/wsc-checks"}]}},"\/popup-maker\/v2":{"namespace":"popup-maker\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"popup-maker\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2"}]}},"\/popup-maker\/v2\/addons":{"namespace":"popup-maker\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2\/addons"}]}},"\/popup-maker\/v2\/addons\/activate":{"namespace":"popup-maker\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2\/addons\/activate"}]}},"\/popup-maker\/v2\/addons\/deactivate":{"namespace":"popup-maker\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2\/addons\/deactivate"}]}},"\/popup-maker\/v2\/object-search":{"namespace":"popup-maker\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"object_type":{"type":"string","description":"Tipo de objeto a buscar (post_type, taxonomy, user, custom_entity)","enum":["post_type","taxonomy","user","custom_entity"],"required":true},"object_key":{"type":"string","description":"Clave de objeto espec\u00edfica (nombre del tipo de entrada, nombre de la taxonom\u00eda, rol de usuario)","required":false},"s":{"type":"string","description":"T\u00e9rmino de b\u00fasqueda","required":false},"include":{"type":"array","description":"IDs para incluir en los resultados (n\u00fameros enteros para objetos est\u00e1ndar, cadenas para entidades personalizadas)","items":{"type":["integer","string"]},"required":false},"exclude":{"type":"array","description":"IDs para excluir de los resultados (n\u00fameros enteros para objetos est\u00e1ndar, cadenas para entidades personalizadas)","items":{"type":["integer","string"]},"required":false},"paged":{"type":"integer","description":"N\u00famero de p\u00e1gina para la paginaci\u00f3n","minimum":1,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2\/object-search"}]}},"\/popup-maker\/v2\/notifications":{"namespace":"popup-maker\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2\/notifications"}]}},"\/popup-maker\/v2\/notifications\/dismiss":{"namespace":"popup-maker\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"type":"string","required":true},"action":{"type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/popup-maker\/v2\/notifications\/dismiss"}]}},"\/pum\/v1":{"namespace":"pum\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"pum\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/pum\/v1"}]}},"\/pum\/v1\/analytics":{"namespace":"pum\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"event":{"description":"Tipo de evento","type":"string","required":false},"pid":{"description":"ID de ventana emergente","type":"integer","required":false},"events":{"description":"Eventos de anal\u00edticas (JSON o tabla)","required":false},"eventData":{"description":"Metadatos del evento (JSON o array)","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/pum\/v1\/analytics"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/troubleshooting\/posthog":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/troubleshooting\/posthog"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/website-contexts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/website-contexts"}]}},"\/wpml\/v1\/has-posts-using-native-editor":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/has-posts-using-native-editor"}]}},"\/wpml\/v1\/get-credits-to-translate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/get-credits-to-translate"}]}},"\/wpml\/v1\/get-credits-per-word":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/get-credits-per-word"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/minimum-requirements":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/minimum-requirements"}]}},"\/wpml\/v1\/rest\/status":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/rest\/status"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/wpml\/v1\/wpml\/posthog\/capture-event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/wpml\/posthog\/capture-event"}]}},"\/wpml\/v1\/wpml-proxy\/status":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/wpml-proxy\/status"}]}},"\/wpml\/v1\/wpml-content-stats":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/wpml-content-stats"}]}},"\/wpml\/v1\/wpml-ph-make-external-request":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpml\/v1\/wpml-ph-make-external-request"}]}},"\/uavc\/v1\/plugins":{"namespace":"uavc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/uavc\/v1\/plugins"}]}},"\/metaslider\/v1":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"metaslider\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1"}]}},"\/metaslider\/v1\/slideshow\/all":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/all"}]}},"\/metaslider\/v1\/slideshow\/list":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/list"}]}},"\/metaslider\/v1\/slideshow\/single":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/single"}]}},"\/metaslider\/v1\/slideshow\/legacy":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/legacy"}]}},"\/metaslider\/v1\/slideshow\/preview":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/preview"}]}},"\/metaslider\/v1\/slideshow\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/save"}]}},"\/metaslider\/v1\/slideshow\/delete":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/delete"}]}},"\/metaslider\/v1\/slideshow\/duplicate":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/duplicate"}]}},"\/metaslider\/v1\/slideshow\/search":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/search"}]}},"\/metaslider\/v1\/slideshow\/export":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/export"}]}},"\/metaslider\/v1\/slideshow\/import":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/slideshow\/import"}]}},"\/metaslider\/v1\/themes\/all":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/themes\/all"}]}},"\/metaslider\/v1\/themes\/custom":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/themes\/custom"}]}},"\/metaslider\/v1\/theme\/customization":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/theme\/customization"}]}},"\/metaslider\/v1\/themes\/set":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/themes\/set"}]}},"\/metaslider\/v1\/import\/images":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/import\/images"}]}},"\/metaslider\/v1\/import\/others":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/import\/others"}]}},"\/metaslider\/v1\/tour\/status":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/tour\/status"}]}},"\/metaslider\/v1\/settings\/user\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/user\/save"}]}},"\/metaslider\/v1\/settings\/user":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/user"}]}},"\/metaslider\/v1\/settings\/global\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/global\/save"}]}},"\/metaslider\/v1\/settings\/global\/single\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/global\/single\/save"}]}},"\/metaslider\/v1\/settings\/single":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/single"}]}},"\/metaslider\/v1\/settings\/global":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/global"}]}},"\/metaslider\/v1\/settings\/slideshow\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/slideshow\/save"}]}},"\/metaslider\/v1\/settings\/slideshow\/save-single":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/slideshow\/save-single"}]}},"\/metaslider\/v1\/settings\/slideshow\/defaults":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/slideshow\/defaults"}]}},"\/metaslider\/v1\/settings\/slideshow\/defaults\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/slideshow\/defaults\/save"}]}},"\/metaslider\/v1\/images\/ids-from-filenames":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/images\/ids-from-filenames"}]}},"\/metaslider\/v1\/settings\/pro":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/pro"}]}},"\/metaslider\/v1\/settings\/pro\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/metaslider\/v1\/settings\/pro\/save"}]}},"\/ultimate-blocks\/v1":{"namespace":"ultimate-blocks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ultimate-blocks\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-blocks\/v1"}]}},"\/ultimate-blocks\/v1\/saved-styles-base":{"namespace":"ultimate-blocks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/ultimate-blocks\/v1\/saved-styles-base"}]}},"\/wc-site-health\/v1":{"namespace":"wc-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-site-health\/v1"}]}},"\/wc-site-health\/v1\/tests\/woocommerce-uploads-directory-protection":{"namespace":"wc-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-site-health\/v1\/tests\/woocommerce-uploads-directory-protection"}]}},"\/wc-admin":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin"}]}},"\/wc-admin\/tax\/recommendations\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/tax\/recommendations\/dismiss"}]}},"\/wc-admin\/notice\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/notice\/dismiss"}]}},"\/wc-admin\/features":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/features"}]}},"\/wc-admin\/experiments\/assignment":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/experiments\/assignment"}]}},"\/wc-admin\/marketing\/recommended":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"category":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/recommended"}]}},"\/wc-admin\/marketing\/knowledge-base":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/knowledge-base"}]}},"\/wc-admin\/marketing\/misc-recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/misc-recommendations"}]}},"\/wc-admin\/marketing\/overview\/activate-plugin":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/overview\/activate-plugin"}]}},"\/wc-admin\/marketing\/overview\/installed-plugins":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/overview\/installed-plugins"}]}},"\/wc-admin\/marketing\/recommendations":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"category":{"type":"string","enum":["channels","extensions"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/recommendations"}]}},"\/wc-admin\/marketing\/channels":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/channels"}]}},"\/wc-admin\/marketing\/campaigns":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/campaigns"}]}},"\/wc-admin\/marketing\/campaign-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketing\/campaign-types"}]}},"\/wc-admin\/options":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/options"}]}},"\/wc-admin\/payment-gateway-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Muestra las sugerencias de pago cuando las opciones woocommerce_show_marketplace_suggestions y woocommerce_setting_payments_recommendations_hidden est\u00e9n establecidas en \u00abno\u00bb","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/payment-gateway-suggestions"}]}},"\/wc-admin\/payment-gateway-suggestions\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/payment-gateway-suggestions\/dismiss"}]}},"\/wc-admin\/themes":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"pluginzip":{"description":"Un archivo zip del tema a subir.","type":"file","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/themes"}]}},"\/wc-admin\/plugins\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/install"}]}},"\/wc-admin\/plugins\/install\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/install\/status"}]}},"\/wc-admin\/plugins\/install\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/plugins\/active":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/active"}]}},"\/wc-admin\/plugins\/installed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/installed"}]}},"\/wc-admin\/plugins\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/activate"}]}},"\/wc-admin\/plugins\/activate\/status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/activate\/status"}]}},"\/wc-admin\/plugins\/activate\/status\/(?P<job_id>[a-z0-9_\\-]+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/plugins\/connect-jetpack":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/connect-jetpack"}]}},"\/wc-admin\/plugins\/request-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/request-wccom-connect"}]}},"\/wc-admin\/plugins\/finish-wccom-connect":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/finish-wccom-connect"}]}},"\/wc-admin\/plugins\/connect-wcpay":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/connect-wcpay"}]}},"\/wc-admin\/plugins\/connect-square":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/plugins\/connect-square"}]}},"\/wc-admin\/onboarding\/free-extensions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/free-extensions"}]}},"\/wc-admin\/onboarding\/product-types":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/product-types"}]}},"\/wc-admin\/onboarding\/profile":{"namespace":"wc-admin","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"completed":{"type":"boolean","description":"Si se complet\u00f3 o no el perfil.","required":false},"skipped":{"type":"boolean","description":"Si se omiti\u00f3 o no el perfil.","required":false},"industry":{"type":"array","description":"Sector.","items":{"type":"string"},"required":false},"business_extensions":{"type":"array","description":"Extensiones de negocio adicionales a instalar.","items":{"type":"string"},"required":false},"is_agree_marketing":{"type":"boolean","description":"Si esta tienda acepta o no recibir contenidos de m\u00e1rketing de Woo.com.","required":false},"store_email":{"type":"string","description":"Direcci\u00f3n de correo electr\u00f3nico de la tienda.","required":false},"is_store_country_set":{"type":"boolean","description":"Si el pa\u00eds de la tienda est\u00e1 configurado en el perfil de la puesta en marcha.","required":false},"is_plugins_page_skipped":{"type":"boolean","description":"Si se ha omitido o no el paso de plugins en el perfilador del n\u00facleo.","required":false},"business_choice":{"type":"string","description":"Elecci\u00f3n de negocio.","required":false},"selling_online_answer":{"type":"string","description":"Respuesta de ventas en l\u00ednea.","required":false},"selling_platforms":{"type":["array","null"],"description":"Plataformas de ventas.","items":{"type":["string","null"]},"required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/profile"}]}},"\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/profile\/experimental_get_email_prefill"}]}},"\/wc-admin\/onboarding\/profile\/progress":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/profile\/progress"}]}},"\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","description":"El paso del configurador central que se debe marcar como completado.","enum":["intro-opt-in","skip-guided-setup","user-profile","business-info","plugins","intro-builder","skip-guided-setup"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/profile\/progress\/core-profiler\/complete"}]}},"\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"description":"C\u00f3digo de pa\u00eds","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/profile\/update-store-currency-and-measurement-units"}]}},"\/wc-admin\/onboarding\/tasks\/import_sample_products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/tasks\/import_sample_products"}]}},"\/wc-admin\/onboarding\/tasks\/create_homepage":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/tasks\/create_homepage"}]}},"\/wc-admin\/onboarding\/tasks\/create_product_from_template":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template_name":{"type":"string","description":"Nombre de plantilla de producto.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/tasks\/create_product_from_template"}]}},"\/wc-admin\/onboarding\/tasks":{"namespace":"wc-admin","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"ids":{"description":"Par\u00e1metro opcional para obtener solamente listas de tareas espec\u00edficas por ID.","type":"array","items":{"enum":["setup","extended","secret_tasklist"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"ids":{"description":"Par\u00e1metro opcional para obtener solamente listas de tareas espec\u00edficas por ID.","type":"array","items":{"enum":["setup","extended","secret_tasklist"],"type":"string"},"required":false},"extended_tasks":{"description":"Lista de tareas obsoletas ampliada en el filtro del cliente.","type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/tasks"}]}},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/unhide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"task_list_id":{"description":"Par\u00e1metro opcional para consultar una lista espec\u00edfica de tareas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"task_list_id":{"description":"Par\u00e1metro opcional para consultar una lista espec\u00edfica de tareas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_-]+)\/snooze":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"duration":{"description":"Periodo de tiempo en el que silenciar la tarea.","type":"string","required":false},"task_list_id":{"description":"Par\u00e1metro opcional para consultar una lista espec\u00edfica de tareas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/action":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/tasks\/(?P<id>[a-z0-9_\\-]+)\/undo_snooze":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/themes\/install":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/themes\/install"}]}},"\/wc-admin\/onboarding\/themes\/activate":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/themes\/activate"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate-async":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"description":"A list of plugins to install","type":"array","items":"string","required":true},"source":{"description":"The source of the request","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate-async"}]}},"\/wc-admin\/onboarding\/plugins\/install-and-activate":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/plugins\/install-and-activate"}]}},"\/wc-admin\/onboarding\/plugins\/scheduled-installs\/(?P<job_id>\\w+)":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"The URL to redirect to after authorization","type":"string","required":true},"from":{"description":"from value for the jetpack authorization page","type":"string","default":"woocommerce-onboarding","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/plugins\/jetpack-authorization-url"}]}},"\/wc-admin\/onboarding\/products":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/onboarding\/products"}]}},"\/wc-admin\/mobile-app\/send-magic-link":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/send-magic-link"}]}},"\/wc-admin\/mobile-app":{"namespace":"wc-admin","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app"}]}},"\/wc-admin\/mobile-app\/qr-login-token":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-token"}]}},"\/wc-admin\/mobile-app\/qr-login-exchange":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","required":true},"exchange_grant":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-exchange"}]}},"\/wc-admin\/mobile-app\/qr-login-status":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-status"}]}},"\/wc-admin\/mobile-app\/qr-login-revoke":{"namespace":"wc-admin","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"uuid":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-revoke"}]}},"\/wc-admin\/mobile-app\/qr-login-scan":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","required":true},"device":{"type":"object","properties":{"os":{"type":"string"},"os_version":{"type":"string"},"model":{"type":"string"},"brand":{"type":"string"},"app_version":{"type":"string"}},"required":true},"supports_number_matching":{"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-scan"}]}},"\/wc-admin\/mobile-app\/qr-login-approve":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","required":true},"choice":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-approve"}]}},"\/wc-admin\/mobile-app\/qr-login-session-status":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"session_id":{"type":"string","required":true},"token_hash":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-session-status"}]}},"\/wc-admin\/mobile-app\/qr-login-availability":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/mobile-app\/qr-login-availability"}]}},"\/wc-admin\/shipping-partner-suggestions":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"force_default_suggestions":{"type":"boolean","description":"Devuelve las sugerencias del socio de env\u00edos por defecto cuando la opci\u00f3n woocommerce_show_marketplace_suggestions est\u00e1 configurada en \u00abNo\u00bb.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/shipping-partner-suggestions"}]}},"\/wc-analytics":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-analytics","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics"}]}},"\/wc-analytics\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"registered_before":{"description":"Limita la respuesta a los objetos registrados antes (o en) una determinada fecha y hora que cumpla con la norma ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limita la respuesta a los objetos registrados despu\u00e9s de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limitar la respuesta a objetos con un campo de cliente que contenga el concepto de b\u00fasqueda. Busca en el campo proporcionado por \u00absearchby\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limitar la respuesta a los objetos con nombres espec\u00edficos.","type":"string","required":false},"name_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo nombres espec\u00edficos.","type":"string","required":false},"username_includes":{"description":"Limitar la respuesta a los objetos con nombres de usuario espec\u00edficos.","type":"string","required":false},"username_excludes":{"description":"Limita la respuesta a los objetos excluyendo nombres de usuario espec\u00edficos.","type":"string","required":false},"email_includes":{"description":"Limitar la respuesta a los objetos, incluidos los correos electr\u00f3nicos.","type":"string","required":false},"email_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo los correos electr\u00f3nicos.","type":"string","required":false},"country_includes":{"description":"Limita la respuesta a objetos con pa\u00edses espec\u00edficos.","type":"string","required":false},"country_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo pa\u00edses espec\u00edficos.","type":"string","required":false},"last_active_before":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez antes de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez despu\u00e9s de (o en) una fecha\/hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos mayor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_max":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos menor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_between":{"description":"Limita la respuesta a objetos con una cuenta de pedidos entre dos n\u00fameros enteros dados.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido mayor o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_max":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_between":{"description":"Limita la respuesta a objetos con un total de gasto de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido superior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_max":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_between":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido antes (o en) una determinada fecha y hora conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido despu\u00e9s de (o en) una fecha y hora determinada conforme a ISO8601.","type":"string","format":"date-time","required":false},"customers_exclude":{"description":"Limita el resultado para que excluya elementos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"users":{"description":"Limitar el resultado a art\u00edculos con los id de usuario especificados.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filtrar los resultados en los que alguno de los campos introducidos est\u00e9 vac\u00edo","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limitar el resultado a art\u00edculos con el tipo de usuario especificado.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Incluye clientes seg\u00fan la ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"location_excludes":{"description":"Excluye clientes seg\u00fan la ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"include":{"description":"Limita el resultado a art\u00edculos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/customers"}]}},"\/wc-analytics\/customers\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"registered_before":{"description":"Limita la respuesta a los objetos registrados antes (o en) una determinada fecha y hora que cumpla con la norma ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limita la respuesta a los objetos registrados despu\u00e9s de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limitar la respuesta a objetos con un campo de cliente que contenga el concepto de b\u00fasqueda. Busca en el campo proporcionado por \u00absearchby\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limitar la respuesta a los objetos con nombres espec\u00edficos.","type":"string","required":false},"name_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo nombres espec\u00edficos.","type":"string","required":false},"username_includes":{"description":"Limitar la respuesta a los objetos con nombres de usuario espec\u00edficos.","type":"string","required":false},"username_excludes":{"description":"Limita la respuesta a los objetos excluyendo nombres de usuario espec\u00edficos.","type":"string","required":false},"email_includes":{"description":"Limitar la respuesta a los objetos, incluidos los correos electr\u00f3nicos.","type":"string","required":false},"email_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo los correos electr\u00f3nicos.","type":"string","required":false},"country_includes":{"description":"Limita la respuesta a objetos con pa\u00edses espec\u00edficos.","type":"string","required":false},"country_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo pa\u00edses espec\u00edficos.","type":"string","required":false},"last_active_before":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez antes de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez despu\u00e9s de (o en) una fecha\/hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos mayor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_max":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos menor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_between":{"description":"Limita la respuesta a objetos con una cuenta de pedidos entre dos n\u00fameros enteros dados.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido mayor o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_max":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_between":{"description":"Limita la respuesta a objetos con un total de gasto de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido superior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_max":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_between":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido antes (o en) una determinada fecha y hora conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido despu\u00e9s de (o en) una fecha y hora determinada conforme a ISO8601.","type":"string","format":"date-time","required":false},"customers_exclude":{"description":"Limita el resultado para que excluya elementos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"users":{"description":"Limitar el resultado a art\u00edculos con los id de usuario especificados.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filtrar los resultados en los que alguno de los campos introducidos est\u00e9 vac\u00edo","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limitar el resultado a art\u00edculos con el tipo de usuario especificado.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Incluye clientes seg\u00fan la ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"location_excludes":{"description":"Excluye clientes seg\u00fan la ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"include":{"description":"Limita el resultado a art\u00edculos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/leaderboards":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"Consulta de URL para persistir en los enlaces.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/leaderboards"}]}},"\/wc-analytics\/leaderboards\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/leaderboards\/allowed"}]}},"\/wc-analytics\/leaderboards\/(?P<leaderboard>\\w+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"leaderboard":{"type":"string","enum":["customers","coupons","categories","products"],"required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":5,"minimum":1,"maximum":20,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"persisted_query":{"description":"Consulta de URL para persistir en los enlaces.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/reports":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports"}]}},"\/wc-analytics\/reports\/import":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"days":{"description":"N\u00famero de d\u00edas a importar.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"No importar datos de pedidos existentes.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/import"}]}},"\/wc-analytics\/reports\/import\/cancel":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/import\/cancel"}]}},"\/wc-analytics\/reports\/import\/delete":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/import\/delete"}]}},"\/wc-analytics\/reports\/import\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/import\/status"}]}},"\/wc-analytics\/reports\/import\/totals":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"days":{"description":"N\u00famero de d\u00edas a importar.","type":"integer","minimum":0,"required":false},"skip_existing":{"description":"No importar datos de pedidos existentes.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/import\/totals"}]}},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"report_args":{"description":"Par\u00e1metros para pasar al informe exportado.","type":"object","required":false},"email":{"description":"Cuando se configura en true, env\u00eda por correo electr\u00f3nico un enlace para descargar la exportaci\u00f3n al usuario que lo ha solicitado.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/reports\/(?P<type>[a-z]+)\/export\/(?P<export_id>[a-z0-9]+)\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/reports\/products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","product_name","variations","sku"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"categories":{"description":"Limita el resultado a los art\u00edculos de las categor\u00edas especificadas.","type":"array","items":{"type":"integer"},"required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"products":{"description":"Limita el resultado a art\u00edculos con IDs de producto espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"search":{"description":"Limita el resultado a los productos cuyo nombre o SKU coincida con cualquiera de los t\u00e9rminos indicados.","type":"array","items":{"type":"string"},"required":false},"extended_info":{"description":"A\u00f1ade una pieza adicional de informaci\u00f3n sobre cada producto al informe.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/products"}]}},"\/wc-analytics\/reports\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","net_revenue","orders_count","items_sold","sku"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limitar el resultado establecido a art\u00edculos que tengan los productos superiores especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limitar el resultado establecido a art\u00edculos que no tengan los productos superiores especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Limita el resultado a art\u00edculos con IDs de variaci\u00f3n espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"A\u00f1ade una pieza adicional de informaci\u00f3n sobre cada variaci\u00f3n al informe.","type":"boolean","default":false,"required":false},"attribute_is":{"description":"Limitar el conjunto de resultados a las variaciones que incluyan los atributos especificados.","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limitar el conjunto de resultados a las variaciones que no incluyan los atributos especificados.","type":"array","items":{"type":"array"},"default":[],"required":false},"category_includes":{"description":"Limitar el resultado a las variaciones de las categor\u00edas especificadas.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limitar el resultado establecido a variaciones que no est\u00e9n en las categor\u00edas especificadas.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Limita el resultado a art\u00edculos con IDs de producto espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/variations"}]}},"\/wc-analytics\/reports\/products\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"fields":{"description":"Limita los campos de estad\u00edstica a los art\u00edculos especificados.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"categories":{"description":"Limita el resultado a los art\u00edculos de las categor\u00edas especificadas.","type":"array","items":{"type":"integer"},"required":false},"products":{"description":"Limita el resultado a art\u00edculos con IDs de producto espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"variations":{"description":"Limita el resultado a art\u00edculos con IDs de variaci\u00f3n espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"search":{"description":"Limita el resultado a los productos cuyo nombre o SKU coincida con cualquiera de los t\u00e9rminos indicados.","type":"array","items":{"type":"string"},"required":false},"segmentby":{"description":"Segmentar la respuesta por restricciones adicionales.","type":"string","enum":["product","category","variation"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/products\/stats"}]}},"\/wc-analytics\/reports\/variations\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","net_revenue","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"fields":{"description":"Limita los campos de estad\u00edstica a los art\u00edculos especificados.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"category_includes":{"description":"Limita el resultado a los art\u00edculos de las categor\u00edas especificadas.","type":"array","items":{"type":"integer"},"required":false},"category_excludes":{"description":"Limitar el resultado establecido a variaciones que no est\u00e9n en las categor\u00edas especificadas.","type":"array","items":{"type":"integer"},"required":false},"product_includes":{"description":"Limitar el resultado establecido a art\u00edculos que tengan los productos superiores especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limitar el resultado establecido a art\u00edculos que no tengan los productos superiores especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"variations":{"description":"Limita el resultado a art\u00edculos con IDs de variaci\u00f3n espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segmentar la respuesta por restricciones adicionales.","type":"string","enum":["product","category","variation"],"required":false},"attribute_is":{"description":"Limita el conjunto de resultados a los pedidos que incluyan productos con los atributos especificados. ","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limita el conjunto de resultados a los pedidos que no incluyan productos con los atributos especificados. ","type":"array","items":{"type":"array"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/variations\/stats"}]}},"\/wc-analytics\/reports\/revenue\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","total_sales","coupons","refunds","shipping","taxes","net_revenue","orders_count","items_sold","gross_sales"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"segmentby":{"description":"Segmentar la respuesta por restricciones adicionales.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false},"date_type":{"description":"Anula la opci\u00f3n \u00abwoocommerce_date_type\u00bb que se utiliza para el campo de fecha de la base de datos para los informes de ingresos.","type":"string","enum":["date_paid","date_created","date_completed"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/revenue\/stats"}]}},"\/wc-analytics\/reports\/orders":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":0,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","num_items_sold","net_total"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"product_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan el\/los producto(s) espec\u00edfico(s) asignado(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limita el resultado establecido a art\u00edculo(s) que no tenga(n) el\/los producto(s) especificado(s) asignado(s)","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limitar el resultado establecido a art\u00edculos en los que hayas especificado la(s) variaci\u00f3n(es) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limitar el resultado establecido a art\u00edculos en los que no hayas especificado la(s) variaci\u00f3n(es) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Limita el resultado a los art\u00edculos que tienen asignado el cup\u00f3n o los cupones especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Limita el resultado a los art\u00edculos que no tienen asignado el cup\u00f3n o los cupones especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Limitar el resultado establecido a art\u00edculos en los que hayas especificado la(s) tasa(s) de impuesto(s) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Limitar el resultado establecido a art\u00edculos en los que no hayas especificado la(s) tasa(s) de impuesto(s) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"status_is":{"description":"Limita el resultado fijado a art\u00edculos que tienen el estado de pedido especificado.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limita el resultado establecido a los art\u00edculos que no tienen el estado de pedido especificado.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"customer_type":{"description":"Limitar el resultado establecido a clientes habituales o nuevos.","type":"string","default":"","enum":["","returning","new"],"required":false},"payment_method_is":{"description":"Limita el conjunto de resultados a los elementos que se pagaron con las pasarelas de pago especificadas.","type":"array","default":[],"items":{"type":"string"},"required":false},"payment_method_is_not":{"description":"Limita el conjunto de resultados a los elementos que no se pagaron con las pasarelas de pago especificadas.","type":"array","default":[],"items":{"type":"string"},"required":false},"refunds":{"description":"Limitar el resultado a tipos espec\u00edficos de reembolsos.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"extended_info":{"description":"A\u00f1ade informaci\u00f3n adicional sobre cada cup\u00f3n al informe.","type":"boolean","default":false,"required":false},"order_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan los IDs de pedido especificados.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limita el resultado establecido a art\u00edculos que no tengan los IDs de pedido especificados.","type":"array","items":{"type":"integer"},"required":false},"attribute_is":{"description":"Limita el conjunto de resultados a los pedidos que incluyan productos con los atributos especificados. ","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limita el conjunto de resultados a los pedidos que no incluyan productos con los atributos especificados. ","type":"array","items":{"type":"array"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/orders"}]}},"\/wc-analytics\/reports\/orders\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","net_revenue","orders_count","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"status_is":{"description":"Limita el resultado fijado a art\u00edculos que tienen el estado de pedido especificado.","type":"array","default":null,"items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limita el resultado establecido a los art\u00edculos que no tienen el estado de pedido especificado.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"product_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan el\/los producto(s) espec\u00edfico(s) asignado(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limita el resultado establecido a art\u00edculo(s) que no tenga(n) el\/los producto(s) especificado(s) asignado(s)","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_includes":{"description":"Limitar el resultado establecido a art\u00edculos en los que hayas especificado la(s) variaci\u00f3n(es) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"variation_excludes":{"description":"Limitar el resultado establecido a art\u00edculos en los que no hayas especificado la(s) variaci\u00f3n(es) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_includes":{"description":"Limita el resultado a los art\u00edculos que tienen asignado el cup\u00f3n o los cupones especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"coupon_excludes":{"description":"Limita el resultado a los art\u00edculos que no tienen asignado el cup\u00f3n o los cupones especificados.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_includes":{"description":"Limitar el resultado establecido a art\u00edculos en los que hayas especificado la(s) tasa(s) de impuesto(s) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"tax_rate_excludes":{"description":"Limitar el resultado establecido a art\u00edculos en los que no hayas especificado la(s) tasa(s) de impuesto(s) asignada(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"customer":{"description":"Alias del tipo de cliente (obsoleto).","type":"string","enum":["new","returning"],"required":false},"payment_method_is":{"description":"Limita el conjunto de resultados a los elementos que se pagaron con las pasarelas de pago especificadas.","type":"array","default":[],"items":{"type":"string"},"required":false},"payment_method_is_not":{"description":"Limita el conjunto de resultados a los elementos que no se pagaron con las pasarelas de pago especificadas.","type":"array","default":[],"items":{"type":"string"},"required":false},"customer_type":{"description":"Limita el conjunto de resultados a los pedidos que tengan el tipo de cliente especificado","type":"string","enum":["new","returning"],"required":false},"refunds":{"description":"Limitar el resultado a tipos espec\u00edficos de reembolsos.","type":"string","default":"","enum":["","all","partial","full","none"],"required":false},"attribute_is":{"description":"Limita el conjunto de resultados a los pedidos que incluyan productos con los atributos especificados. ","type":"array","items":{"type":"array"},"default":[],"required":false},"attribute_is_not":{"description":"Limita el conjunto de resultados a los pedidos que no incluyan productos con los atributos especificados. ","type":"array","items":{"type":"array"},"default":[],"required":false},"segmentby":{"description":"Segmentar la respuesta por restricciones adicionales.","type":"string","enum":["product","category","variation","coupon","customer_type"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/orders\/stats"}]}},"\/wc-analytics\/reports\/categories":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"category_id","enum":["category_id","items_sold","net_revenue","orders_count","products_count","category"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"status_is":{"description":"Limita el resultado fijado a art\u00edculos que tienen el estado de pedido especificado.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"status_is_not":{"description":"Limita el resultado establecido a los art\u00edculos que no tienen el estado de pedido especificado.","type":"array","items":{"enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"type":"string"},"required":false},"categories":{"description":"Limita el resultado a todos los art\u00edculos que tienen el t\u00e9rmino especificado asignado en la taxonom\u00eda de las categor\u00edas.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"A\u00f1ade informaci\u00f3n adicional sobre cada categor\u00eda al informe.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/categories"}]}},"\/wc-analytics\/reports\/taxes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"tax_rate_id","enum":["name","tax_rate_id","tax_code","rate","order_tax","total_tax","shipping_tax","taxable_amount","order_taxable_amount","shipping_taxable_amount","orders_count"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"taxes":{"description":"L\u00edmite de resultado establecido para los art\u00edculos asignados a una o m\u00e1s tasas de impuestos.","type":"array","items":{"type":"string"},"required":false},"location_includes":{"description":"Incluye las tasas de impuestos por ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"location_excludes":{"description":"Excluye las tasas de impuestos por ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/taxes"}]}},"\/wc-analytics\/reports\/taxes\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","items_sold","total_sales","orders_count","products_count"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"fields":{"description":"Limita los campos de estad\u00edstica a los art\u00edculos especificados.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"taxes":{"description":"Limitar el resultado a todos los art\u00edculos que tengan asignado un t\u00e9rmino espec\u00edfico en la taxonom\u00eda de impuestos.","type":"array","items":{"type":"integer"},"required":false},"location_includes":{"description":"Incluye las tasas de impuestos por ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"location_excludes":{"description":"Excluye las tasas de impuestos por ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"segmentby":{"description":"Segmentar la respuesta por restricciones adicionales.","type":"string","enum":["tax_rate_id"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/taxes\/stats"}]}},"\/wc-analytics\/reports\/coupons":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"coupon_id","enum":["coupon_id","code","amount","orders_count"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"coupons":{"description":"Limita el resultado a los cupones a los que se les han asignado IDs de cup\u00f3n espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"extended_info":{"description":"A\u00f1ade informaci\u00f3n adicional sobre cada cup\u00f3n al informe.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/coupons"}]}},"\/wc-analytics\/reports\/coupons\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","amount","coupons_count","orders_count"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"fields":{"description":"Limita los campos de estad\u00edstica a los art\u00edculos especificados.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"coupons":{"description":"Limita el resultado a los cupones a los que se les han asignado IDs de cup\u00f3n espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"segmentby":{"description":"Segmentar la respuesta por restricciones adicionales.","type":"string","enum":["product","variation","category","coupon"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/coupons\/stats"}]}},"\/wc-analytics\/reports\/stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"stock_status","enum":["stock_status","stock_quantity","date","id","include","title","sku"],"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limita el resultado establecido a art\u00edculos asignados a un tipo de informe de inventario.","type":"string","default":"all","enum":["all","lowstock","instock","outofstock","onbackorder"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/stock"}]}},"\/wc-analytics\/reports\/stock\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/stock\/stats"}]}},"\/wc-analytics\/reports\/downloads":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","product"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: productos, pedidos, nombre de usuario, direcci\u00f3n IP.","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan el\/los producto(s) espec\u00edfico(s) asignado(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limita el resultado establecido a art\u00edculo(s) que no tenga(n) el\/los producto(s) especificado(s) asignado(s)","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan los IDs de pedido especificados.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limita el resultado establecido a art\u00edculos que no tengan los IDs de pedido especificados.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Limita la respuesta a objetos que tengan los IDs de usuario especificados.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Limita la respuesta a objetos que no tengan los IDs de usuario especificados.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Limita la respuesta a objetos que tengan una direcci\u00f3n ip especificada.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Limita la respuesta a objetos que no tengan una direcci\u00f3n ip especificada.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/downloads"}]}},"\/wc-analytics\/reports\/downloads\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","download_count"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"fields":{"description":"Limita los campos de estad\u00edstica a los art\u00edculos especificados.","type":"array","items":{"type":"string"},"required":false},"interval":{"description":"Intervalo de tiempo para utilizar para los contenedores en los datos devueltos.","type":"string","default":"week","enum":["hour","day","week","month","quarter","year"],"required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"product_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan el\/los producto(s) espec\u00edfico(s) asignado(s).","type":"array","items":{"type":"integer"},"default":[],"required":false},"product_excludes":{"description":"Limita el resultado establecido a art\u00edculo(s) que no tenga(n) el\/los producto(s) especificado(s) asignado(s)","type":"array","items":{"type":"integer"},"default":[],"required":false},"order_includes":{"description":"Limita el resultado establecido a art\u00edculos que tengan los IDs de pedido especificados.","type":"array","items":{"type":"integer"},"required":false},"order_excludes":{"description":"Limita el resultado establecido a art\u00edculos que no tengan los IDs de pedido especificados.","type":"array","items":{"type":"integer"},"required":false},"customer_includes":{"description":"Limita la respuesta a los objetos que tienen los identificadores de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"customer_excludes":{"description":"Limita la respuesta a los objetos que no tienen los identificadores de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"ip_address_includes":{"description":"Limita la respuesta a objetos que tengan una direcci\u00f3n ip especificada.","type":"array","items":{"type":"string"},"required":false},"ip_address_excludes":{"description":"Limita la respuesta a objetos que no tengan una direcci\u00f3n ip especificada.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/downloads\/stats"}]}},"\/wc-analytics\/reports\/customers":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date_registered","enum":["username","name","first_name","last_name","email","location","country","city","state","postcode","date_registered","date_last_active","orders_count","total_spend","avg_order_value"],"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"registered_before":{"description":"Limita la respuesta a los objetos registrados antes (o en) una determinada fecha y hora que cumpla con la norma ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limita la respuesta a los objetos registrados despu\u00e9s de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limitar la respuesta a objetos con un campo de cliente que contenga el concepto de b\u00fasqueda. Busca en el campo proporcionado por \u00absearchby\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limitar la respuesta a los objetos con nombres espec\u00edficos.","type":"string","required":false},"name_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo nombres espec\u00edficos.","type":"string","required":false},"username_includes":{"description":"Limitar la respuesta a los objetos con nombres de usuario espec\u00edficos.","type":"string","required":false},"username_excludes":{"description":"Limita la respuesta a los objetos excluyendo nombres de usuario espec\u00edficos.","type":"string","required":false},"email_includes":{"description":"Limitar la respuesta a los objetos, incluidos los correos electr\u00f3nicos.","type":"string","required":false},"email_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo los correos electr\u00f3nicos.","type":"string","required":false},"country_includes":{"description":"Limita la respuesta a objetos con pa\u00edses espec\u00edficos.","type":"string","required":false},"country_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo pa\u00edses espec\u00edficos.","type":"string","required":false},"last_active_before":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez antes de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez despu\u00e9s de (o en) una fecha\/hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos mayor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_max":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos menor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_between":{"description":"Limita la respuesta a objetos con una cuenta de pedidos entre dos n\u00fameros enteros dados.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido mayor o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_max":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_between":{"description":"Limita la respuesta a objetos con un total de gasto de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido superior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_max":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_between":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido antes (o en) una determinada fecha y hora conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido despu\u00e9s de (o en) una fecha y hora determinada conforme a ISO8601.","type":"string","format":"date-time","required":false},"customers":{"description":"Limita el resultado a art\u00edculos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"customers_exclude":{"description":"Limita el resultado para que excluya elementos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"users":{"description":"Limitar el resultado a art\u00edculos con los id de usuario especificados.","type":"array","items":{"type":"integer"},"required":false},"filter_empty":{"description":"Filtrar los resultados en los que alguno de los campos introducidos est\u00e9 vac\u00edo","type":"array","items":{"type":"string","enum":["email","name","country","city","state","postcode"]},"required":false},"user_type":{"description":"Limitar el resultado a art\u00edculos con el tipo de usuario especificado.","type":"string","default":"all","enum":["all","registered","guest"],"required":false},"location_includes":{"description":"Incluye clientes seg\u00fan la ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"location_excludes":{"description":"Excluye clientes seg\u00fan la ubicaci\u00f3n (estado, pa\u00eds). Proporciona una lista de ubicaciones separadas por comas. Cada ubicaci\u00f3n puede ser un c\u00f3digo de pa\u00eds (por ejemplo, GB) o una combinaci\u00f3n de pa\u00eds y estado (por ejemplo, US:CA).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/customers"}]}},"\/wc-analytics\/reports\/customers\/stats":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"registered_before":{"description":"Limita la respuesta a los objetos registrados antes (o en) una determinada fecha y hora que cumpla con la norma ISO8601.","type":"string","format":"date-time","required":false},"registered_after":{"description":"Limita la respuesta a los objetos registrados despu\u00e9s de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"match":{"description":"Indica si todas las condiciones deben ser ciertas para el conjunto resultante, o si alguna de ellas es suficiente. La coincidencia afecta a los siguientes par\u00e1metros: status_is, status_is_not, product_includes, product_excludes, coupon_includes, coupon_excludes, customer, categories","type":"string","default":"all","enum":["all","any"],"required":false},"search":{"description":"Limitar la respuesta a objetos con un campo de cliente que contenga el concepto de b\u00fasqueda. Busca en el campo proporcionado por \u00absearchby\u00bb.","type":"string","required":false},"searchby":{"description":"Limit results with `search` and `searchby` to specific fields containing the search term.","type":"string","default":"name","enum":["name","username","email","all"],"required":false},"name_includes":{"description":"Limitar la respuesta a los objetos con nombres espec\u00edficos.","type":"string","required":false},"name_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo nombres espec\u00edficos.","type":"string","required":false},"username_includes":{"description":"Limitar la respuesta a los objetos con nombres de usuario espec\u00edficos.","type":"string","required":false},"username_excludes":{"description":"Limita la respuesta a los objetos excluyendo nombres de usuario espec\u00edficos.","type":"string","required":false},"email_includes":{"description":"Limitar la respuesta a los objetos, incluidos los correos electr\u00f3nicos.","type":"string","required":false},"email_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo los correos electr\u00f3nicos.","type":"string","required":false},"country_includes":{"description":"Limita la respuesta a objetos con pa\u00edses espec\u00edficos.","type":"string","required":false},"country_excludes":{"description":"Limitar la respuesta a los objetos, excluyendo pa\u00edses espec\u00edficos.","type":"string","required":false},"last_active_before":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez antes de (o en) una fecha y hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_after":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez despu\u00e9s de (o en) una fecha\/hora determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_active_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"registered_between":{"description":"Limita la respuesta a los objetos activos por \u00faltima vez entre dos fechas conforme a la norma ISO8601.","type":"array","items":{"type":"string"},"required":false},"orders_count_min":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos mayor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_max":{"description":"Limita la respuesta a objetos con un n\u00famero de pedidos menor o igual al n\u00famero entero dado.","type":"integer","required":false},"orders_count_between":{"description":"Limita la respuesta a objetos con una cuenta de pedidos entre dos n\u00fameros enteros dados.","type":"array","items":{"type":"integer"},"required":false},"total_spend_min":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido mayor o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_max":{"description":"Limita la respuesta a los objetos con un total de gasto de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"total_spend_between":{"description":"Limita la respuesta a objetos con un total de gasto de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"avg_order_value_min":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido superior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_max":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido inferior o igual a un n\u00famero determinado.","type":"number","required":false},"avg_order_value_between":{"description":"Limita la respuesta a los objetos con un gasto medio de pedido entre dos n\u00fameros determinados.","type":"array","items":{"type":"integer"},"required":false},"last_order_before":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido antes (o en) una determinada fecha y hora conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"last_order_after":{"description":"Limita la respuesta a los objetos con el \u00faltimo pedido despu\u00e9s de (o en) una fecha y hora determinada conforme a ISO8601.","type":"string","format":"date-time","required":false},"customers":{"description":"Limita el resultado a art\u00edculos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"customers_exclude":{"description":"Limita el resultado para que excluya elementos con los IDs de cliente especificados.","type":"array","items":{"type":"integer"},"required":false},"fields":{"description":"Limita los campos de estad\u00edstica a los art\u00edculos especificados.","type":"array","items":{"type":"string"},"required":false},"force_cache_refresh":{"description":"Forzar la recuperaci\u00f3n de datos nuevos en vez que desde la cach\u00e9.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/customers\/stats"}]}},"\/wc-analytics\/imports\/status":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/imports\/status"}]}},"\/wc-analytics\/imports\/trigger":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/imports\/trigger"}]}},"\/wc-analytics\/imports\/retry-failed":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/imports\/retry-failed"}]}},"\/wc-analytics\/reports\/performance-indicators":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Limitar la respuesta a las estad\u00edsticas de informes espec\u00edficos. Valores permitidos: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/performance-indicators"}]}},"\/wc-analytics\/reports\/performance-indicators\/allowed":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"stats":{"description":"Limitar la respuesta a las estad\u00edsticas de informes espec\u00edficos. Valores permitidos: .","type":"array","items":{"type":"string","enum":[]},"default":[],"required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/reports\/performance-indicators\/allowed"}]}},"\/wc-analytics\/admin\/notes":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["note_id","date","type","title","status"],"required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"type":{"description":"Tipo de nota.","type":"array","items":{"enum":["error","warning","update","info","marketing","survey"],"type":"string"},"required":false},"status":{"description":"Estado de la nota.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false},"source":{"description":"Origen de la nota.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/admin\/notes"}]}},"\/wc-analytics\/admin\/notes\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/delete\/(?P<id>[\\d-]+)":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/delete\/all":{"namespace":"wc-analytics","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"status":{"description":"Estado de la nota.","type":"array","items":{"enum":["pending","actioned","unactioned","snoozed","sent"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/admin\/notes\/delete\/all"}]}},"\/wc-analytics\/admin\/notes\/update":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/admin\/notes\/update"}]}},"\/wc-analytics\/admin\/notes\/experimental-activate-promo\/(?P<promo_note_name>[\\w-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/admin\/notes\/(?P<note_id>[\\d-]+)\/action\/(?P<action_id>[\\d-]+)":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"note_id":{"description":"ID \u00fanico de la nota.","type":"integer","required":false},"action_id":{"description":"ID \u00fanico de la acci\u00f3n de la nota.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/coupons":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a los cupones con c\u00f3digos que coincidan con una cadena concreta.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limitar los resultados a recursos con un c\u00f3digo espec\u00edfico.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":true},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/coupons"}]}},"\/wc-analytics\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/coupons\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/coupons\/batch"}]}},"\/wc-analytics\/data":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/data"}]}},"\/wc-analytics\/data\/countries\/locales":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/data\/countries\/locales"}]}},"\/wc-analytics\/data\/countries":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/data\/countries"}]}},"\/wc-analytics\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/data\/download-ips":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/data\/download-ips"}]}},"\/wc-analytics\/orders":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":["any"],"description":"Limitar el resultado a los pedidos que tenga estados espec\u00edficos.","type":"array","items":{"type":"string","enum":["any","trash","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Limitar resultados a pedidos de un cliente determinado.","type":"integer","required":false},"product":{"description":"Limitar resultados a pedidos asignados con un producto determinado.","type":"integer","required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Mostrar solo los metadatos que deben aparecer en un pedido.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limita el conjunto de resultados a los pedidos creados a trav\u00e9s de fuentes espec\u00edficas (por ejemplo, pago, administraci\u00f3n).","type":"array","items":{"type":"string"},"required":false},"number":{"description":"Limita el resultado a los pedidos que coincidan con parte de un n\u00famero de pedido.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"created_via":{"description":"Muestra d\u00f3nde fue creado el pedido.","type":"string","required":false},"status":{"default":"pending","description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"USD","description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"manual_update":{"default":false,"description":"Define la acci\u00f3n como manual para que la nota del pedido se registre como \u00aba\u00f1adida por el usuario\u00bb.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/orders"}]}},"\/wc-analytics\/orders\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"created_via":{"description":"Muestra d\u00f3nde fue creado el pedido.","type":"string","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"manual_update":{"description":"Define la acci\u00f3n como manual para que la nota del pedido se registre como \u00aba\u00f1adida por el usuario\u00bb.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/orders\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"created_via":{"description":"Muestra d\u00f3nde fue creado el pedido.","type":"string","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"manual_update":{"description":"Define la acci\u00f3n como manual para que la nota del pedido se registre como \u00aba\u00f1adida por el usuario\u00bb.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/orders\/batch"}]}},"\/wc-analytics\/products":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Buscar por nombre de producto similar o sku.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limita los resultados a productos asignados al ID de una marca espec\u00edfica.","type":"string","required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limita el resultado a productos con un atributo espec\u00edfico. Usa el slug del nombre\/atributo de la taxonom\u00eda.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limita los resultados a aquellos con un SKU que coincida parcialmente con una cadena. Este argumento tiene prioridad sobre 'sku'.","type":"string","required":false},"search_name_or_sku":{"description":"Limita los resultados a los que tengan un nombre o SKU que coincidan parcialmente con una cadena. Este argumento tiene prioridad sobre 'search', 'sku' y 'search_sku'.","type":"string","required":false},"search_fields":{"description":"Limita la b\u00fasqueda a campos espec\u00edficos cuando se usa con un par\u00e1metro de b\u00fasqueda. Campos disponibles: name, sku, global_unique_id, description y short_description. Este argumento tiene prioridad sobre todos los dem\u00e1s par\u00e1metros de b\u00fasqueda.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limitar el resultado a productos con cualquiera de los estados.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluir productos con cualquiera de los estados del conjunto de resultados.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limitar el conjunto de resultados a los productos con cualquiera de los tipos.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"exclude_types":{"description":"Excluir productos con cualquiera de los tipos del conjunto de resultados.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"downloadable":{"description":"Limitar el resultado a productos que se pueden descargar.","type":"boolean","required":false},"virtual":{"description":"Limitar el resultado a productos virtuales.","type":"boolean","required":false},"pos_products_only":{"description":"Limitar el resultado a los productos visibles en el punto de venta.","type":"boolean","required":false},"low_in_stock":{"description":"Limita el conjunto de resultados a productos que tengan pocas existencias o est\u00e9n agotados. (Obsoleto)","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"description":"Si se ignora la papelera y se fuerza el borrado.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/batch"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/suggested-products":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limita los resultados a productos asignados al ID de una marca espec\u00edfica.","type":"string","required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limita el resultado a productos con un atributo espec\u00edfico. Usa el slug del nombre\/atributo de la taxonom\u00eda.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limitar el resultado a productos con existencias o sin existencias.","type":"boolean","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"categories":{"description":"Limita el resultado establecido a ID de categor\u00edas de productos espec\u00edficas.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limita el resultado establecido a ID de etiquetas de productos espec\u00edficas.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limita el resultado establecido a una cantidad espec\u00edfica de productos recomendados.","type":"integer","default":5,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/suggested-products"}]}},"\/wc-analytics\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/attributes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"search":{"description":"Buscar por nombre de atributo similar.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del recurso.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"default":"select","description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"default":"menu_order","description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/attributes"}]}},"\/wc-analytics\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/attributes\/batch"}]}},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identificador del slug del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/attributes\/(?P<slug>[a-z0-9_\\-]+)\/terms":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/categories":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"default":"default","description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/categories"}]}},"\/wc-analytics\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/categories\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/categories\/batch"}]}},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Busca un nombre de producto, SKU o valor de atributo similar.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Usa un tama\u00f1o de imagen registrado espec\u00edfico para el src de la imagen de variaci\u00f3n devuelta. Vuelve al tama\u00f1o completo si el tama\u00f1o solicitado no est\u00e1 registrado.","type":"string","default":"full","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limita el conjunto de resultados a productos con o sin precio.","type":"boolean","required":false},"attributes":{"description":"Limitar resultados a productos con atributos espec\u00edficos.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Slug del atributo."},"term":{"type":"string","description":"T\u00e9rmino del atributo."},"terms":{"type":"array","description":"T\u00e9rminos del atributo."}}},"required":false},"virtual":{"description":"Limitar el resultado a variaciones de productos.","type":"boolean","required":false},"downloadable":{"description":"Limitar el resultado a las variaciones de productos que se pueden descargar.","type":"boolean","required":false},"include_status":{"description":"Limitar el resultado a las variaciones de productos con cualquiera de los estados.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluir variaciones de productos con cualquiera de los estados del conjunto de resultados.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limitar el resultado a las variaciones visibles en el punto de venta.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"type":{"default":"variation","description":"Tipo de producto.","type":"string","enum":["variation"],"required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"name":{"description":"Nombre del producto superior.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["variation"],"required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"name":{"description":"Nombre del producto superior.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["variation"],"required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"name":{"description":"Nombre del producto superior.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc-analytics","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"delete":{"description":"Borra las variaciones sin utilizar.","type":"boolean","required":false},"default_values":{"description":"Valores por defecto para las variaciones generadas.","type":"object","properties":{"type":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Tipo de producto.","type":"string","enum":["variation"]},"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Descripci\u00f3n de la variaci\u00f3n","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Unidad de salvaguarda de inventario.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN o ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Precio normal de la variaci\u00f3n.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Precio rebajado de la variaci\u00f3n.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variaci\u00f3n es virtual.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variaci\u00f3n es descargable.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Clase de impuesto.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Cantidad de inventario.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Peso de la variaci\u00f3n (lbs).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Slug de la clase de env\u00edo.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"gallery_image_ids":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}},"parent_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"ID del producto superior.","type":"integer"},"customs_commodity_code":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"]},"customs_country_of_origin":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"]},"customs_description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"]},"name":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Nombre del producto superior.","type":"string"}},"required":false},"type":{"default":"variation","description":"Tipo de producto.","type":"string","enum":["variation"],"required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"name":{"description":"Nombre del producto superior.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/variations":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Busca un nombre de producto, SKU o valor de atributo similar.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Usa un tama\u00f1o de imagen registrado espec\u00edfico para el src de la imagen de variaci\u00f3n devuelta. Vuelve al tama\u00f1o completo si el tama\u00f1o solicitado no est\u00e1 registrado.","type":"string","default":"full","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limita el conjunto de resultados a productos con o sin precio.","type":"boolean","required":false},"attributes":{"description":"Limitar resultados a productos con atributos espec\u00edficos.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Slug del atributo."},"term":{"type":"string","description":"T\u00e9rmino del atributo."},"terms":{"type":"array","description":"T\u00e9rminos del atributo."}}},"required":false},"virtual":{"description":"Limitar el resultado a variaciones de productos.","type":"boolean","required":false},"downloadable":{"description":"Limitar el resultado a las variaciones de productos que se pueden descargar.","type":"boolean","required":false},"include_status":{"description":"Limitar el resultado a las variaciones de productos con cualquiera de los estados.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluir variaciones de productos con cualquiera de los estados del conjunto de resultados.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limitar el resultado a las variaciones visibles en el punto de venta.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/variations"}]}},"\/wc-analytics\/products\/reviews":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a valoraciones publicadas antes de una fecha dada compatible con ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el resultado a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Limitar el resultado a las valoraciones asignadas a IDs de usuario espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"Asegura que el resultado establecido excluye las valoraciones asignadas a IDs de usuario espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Limita el resultado a los del correo electr\u00f3nico de un autor espec\u00edfico.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Limita el resultado a valoraciones asignadas a IDs de producto espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Limita el resultado a las valoraciones asignadas a un estado espec\u00edfico.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto.","type":"integer","required":true},"product_name":{"description":"Nombre del producto.","type":"string","required":false},"status":{"default":"approved","description":"Estado de la valoraci\u00f3n.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Nombre de quien dej\u00f3 la valoraci\u00f3n.","required":true},"reviewer_email":{"type":"string","description":"Correo electr\u00f3nico de quien dej\u00f3 la valoraci\u00f3n.","required":true},"review":{"type":"string","description":"Contenido de la valoraci\u00f3n.","required":true},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/reviews"}]}},"\/wc-analytics\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"product_id":{"description":"Identificador \u00fanico del producto al que pertenece la valoraci\u00f3n.","type":"integer","required":false},"product_name":{"description":"Nombre del producto.","type":"string","required":false},"status":{"description":"Estado de la valoraci\u00f3n.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nombre de quien valora.","type":"string","required":false},"reviewer_email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","format":"email","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/products\/reviews\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto al que pertenece la valoraci\u00f3n.","type":"integer","required":false},"product_name":{"description":"Nombre del producto.","type":"string","required":false},"status":{"description":"Estado de la valoraci\u00f3n.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nombre de quien valora.","type":"string","required":false},"reviewer_email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","format":"email","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/reviews\/batch"}]}},"\/wc-analytics\/products\/low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"status":{"default":"publish","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/low-in-stock"}]}},"\/wc-analytics\/products\/count-low-in-stock":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"status":{"default":"publish","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/products\/count-low-in-stock"}]}},"\/wc-analytics\/activity-panel\/counts":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","default":"view","required":false},"order_statuses":{"description":"Estados de pedido contados como \u00abpor preparar\u00bb.","type":"array","items":{"type":"string"},"default":["processing","on-hold"],"required":false},"review_status":{"description":"Estado de rese\u00f1a contado como \u00abpendiente de moderar\u00bb.","type":"string","default":"hold","required":false},"product_status":{"description":"Estado de la entrada de producto utilizado para el recuento de stock bajo.","type":"string","default":"publish","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/activity-panel\/counts"}]}},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"value":{"description":"Valor del ajuste.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"value":{"description":"Valor del ajuste.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/taxes":{"namespace":"wc-analytics","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Ordenar por clase de impuesto.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"search":{"description":"Buscar por c\u00f3digo de impuestos similar.","type":"string","required":false},"include":{"description":"Limita el resultado a los art\u00edculos que tienen asignados ID(s) de impuesto especificos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"\u00abC\u00f3digo postal\/ZIP\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abc\u00f3digopostal\u00bb.","type":"string","required":false},"city":{"description":"\u00abNombre de la ciudad\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abciudades\u00bb.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"default":1,"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"default":false,"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"default":"standard","description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista de c\u00f3digos postales. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista de nombres de ciudades. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/taxes"}]}},"\/wc-analytics\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc-analytics","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"\u00abC\u00f3digo postal\/ZIP\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abc\u00f3digopostal\u00bb.","type":"string","required":false},"city":{"description":"\u00abNombre de la ciudad\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abciudades\u00bb.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista de c\u00f3digos postales. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista de nombres de ciudades. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-analytics\/taxes\/batch":{"namespace":"wc-analytics","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"\u00abC\u00f3digo postal\/ZIP\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abc\u00f3digopostal\u00bb.","type":"string","required":false},"city":{"description":"\u00abNombre de la ciudad\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abciudades\u00bb.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista de c\u00f3digos postales. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista de nombres de ciudades. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-analytics\/taxes\/batch"}]}},"\/wc-admin\/launch-your-store\/initialize-coming-soon":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/launch-your-store\/initialize-coming-soon"}]}},"\/wc-admin\/launch-your-store\/update-survey-status":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"status":{"type":"string","enum":["yes","no"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/launch-your-store\/update-survey-status"}]}},"\/wc-admin\/launch-your-store\/survey-completed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/launch-your-store\/survey-completed"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders\/count"}]}},"\/wc-admin\/launch-your-store\/woopayments\/test-orders":{"namespace":"wc-admin","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/launch-your-store\/woopayments\/test-orders"}]}},"\/wc\/store":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store"}]}},"\/wc\/store\/batch":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/batch"}]}},"\/wc\/store\/cart":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart"}]}},"\/wc\/store\/cart\/add-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"El ID del producto o la variaci\u00f3n en el carrito.","type":"integer","required":false},"quantity":{"description":"Cantidad de este art\u00edculo para a\u00f1adir en el carrito.","type":"number","required":false},"variation":{"description":"Atributos elegidos (para variaciones).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nombre del atributo de la variaci\u00f3n.","type":"string","context":["view","edit"]},"value":{"description":"Valor del atributo de la variaci\u00f3n.","type":"string","context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/add-item"}]}},"\/wc\/store\/cart\/apply-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/apply-coupon"}]}},"\/wc\/store\/cart\/coupons":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"El c\u00f3digo \u00fanico del cup\u00f3n.","type":"string","required":false},"discount_type":{"description":"El tipo de descuento del cup\u00f3n (p.ej.: porcentaje o cantidad fija)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/coupons"}]}},"\/wc\/store\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/cart\/extensions":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Nombre de la extensi\u00f3n - ser\u00e1 usado para garantizar que los datos de la solicitud se dirijan adecuadamente.","type":"string","required":false},"data":{"description":"Datos adicionales para pasar a la extensi\u00f3n","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/extensions"}]}},"\/wc\/store\/cart\/items":{"namespace":"wc\/store","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":{"woocommerce_google_analytics_integration":{"description":"Datos de extensi\u00f3n registrados por woocommerce_google_analytics_integration","type":["object","null"],"context":["view","edit"],"properties":{"identifier":{"description":"El identificador de producto formateado que se utilizar\u00e1 en los eventos de Google Analytics.","type":"string","readonly":true}}}},"default":{"woocommerce_google_analytics_integration":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/items"}]}},"\/wc\/store\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico para el art\u00edculo en el carrito.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico para el art\u00edculo en el carrito.","type":"string","required":false},"extensions":{"type":"object","properties":{"woocommerce_google_analytics_integration":{"description":"Datos de extensi\u00f3n registrados por woocommerce_google_analytics_integration","type":["object","null"],"context":["view","edit"],"properties":{"identifier":{"description":"El identificador de producto formateado que se utilizar\u00e1 en los eventos de Google Analytics.","type":"string","readonly":true}}}},"required":false},"quantity":{"description":"Nueva cantidad del producto en el carrito.","type":"number","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico para el art\u00edculo en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/cart\/remove-coupon":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/remove-coupon"}]}},"\/wc\/store\/cart\/remove-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico (clave) del producto del carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/remove-item"}]}},"\/wc\/store\/cart\/select-shipping-rate":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"El ID del paquete a enviar. D\u00e9jalo en blanco para aplicarlo a todos los paquetes.","type":["integer","string","null"],"required":false},"rate_id":{"description":"El ID de la tarifa elegida para el paquete.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/select-shipping-rate"}]}},"\/wc\/store\/cart\/update-item":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico (clave) del producto del carrito a actualizar.","type":"string","required":false},"quantity":{"description":"Nueva cantidad del producto en el carrito.","type":"number","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/update-item"}]}},"\/wc\/store\/cart\/update-customer":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/cart\/update-customer"}]}},"\/wc\/store\/checkout":{"namespace":"wc\/store","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Datos a pasar con el m\u00e9todo de pago al procesar el pago.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Contrase\u00f1a del cliente para cuentas nuevas, si procede.","type":"string","required":false},"expected_total":{"description":"El total del pedido que el comprador confirm\u00f3 en el cliente, como una cadena en la unidad m\u00e1s peque\u00f1a de la moneda de la tienda (por ejemplo, c\u00e9ntimos), que coincide con el formato `totals.total_price` del carrito. Cuando se proporciona, el pedido se rechaza si el total calculado en el servidor ya no coincide, protegiendo al comprador de que se le cobre un importe inesperado.","type":"string","pattern":"^[0-9]+$","required":false},"customer_note":{"description":"Nota a\u00f1adida al pedido por el cliente durante el pago.","type":"string","required":false},"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"El ID del m\u00e9todo de pago que se est\u00e1 usando para procesar el pago.","type":"string","enum":["","bacs","cheque","cod","acceptbluecard","acceptbluecard_ach"],"required":false},"create_account":{"description":"Crear una nueva cuenta de usuario como parte del proceso del pedido.","type":"boolean","required":false},"additional_fields":{"description":"Campos adicionales que deben permanecer en el pedido.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"rcfwc":{"description":"Datos de extensi\u00f3n registrados por rcfwc","type":["object","null"],"context":["view","edit"],"properties":{"token":{"description":"reCaptcha token.","type":"string","readonly":false}}},"woocommerce\/order-attribution":{"description":"Datos de extensi\u00f3n registrados por woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Campo de atribuci\u00f3n de pedidos: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Campo de atribuci\u00f3n de pedidos: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Campo de atribuci\u00f3n de pedidos: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Campo de atribuci\u00f3n de pedidos: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Campo de atribuci\u00f3n de pedidos: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Campo de atribuci\u00f3n de pedidos: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Campo de atribuci\u00f3n de pedidos: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Campo de atribuci\u00f3n de pedidos: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Campo de atribuci\u00f3n de pedidos: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Campo de atribuci\u00f3n de pedidos: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Campo de atribuci\u00f3n de pedidos: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Campo de atribuci\u00f3n de pedidos: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Campo de atribuci\u00f3n de pedidos: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Campo de atribuci\u00f3n de pedidos: user_agent","type":["string","null"],"context":[]}}}},"default":{"rcfwc":[],"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Campos adicionales que deben permanecer en el pedido.","type":"object","properties":[],"required":false},"payment_method":{"description":"El ID del m\u00e9todo de pago que se est\u00e1 usando para procesar el pago.","type":"string","enum":["","bacs","cheque","cod","acceptbluecard","acceptbluecard_ach"],"required":false},"order_notes":{"description":"Notas de pedidos.","type":"string","required":false},"customer_note":{"description":"Nota a\u00f1adida al pedido por el cliente durante el pago.","type":"string","required":false},"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Crear una nueva cuenta de usuario como parte del proceso del pedido.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"rcfwc":{"description":"Datos de extensi\u00f3n registrados por rcfwc","type":["object","null"],"context":["view","edit"],"properties":{"token":{"description":"reCaptcha token.","type":"string","readonly":false}}},"woocommerce\/order-attribution":{"description":"Datos de extensi\u00f3n registrados por woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Campo de atribuci\u00f3n de pedidos: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Campo de atribuci\u00f3n de pedidos: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Campo de atribuci\u00f3n de pedidos: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Campo de atribuci\u00f3n de pedidos: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Campo de atribuci\u00f3n de pedidos: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Campo de atribuci\u00f3n de pedidos: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Campo de atribuci\u00f3n de pedidos: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Campo de atribuci\u00f3n de pedidos: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Campo de atribuci\u00f3n de pedidos: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Campo de atribuci\u00f3n de pedidos: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Campo de atribuci\u00f3n de pedidos: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Campo de atribuci\u00f3n de pedidos: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Campo de atribuci\u00f3n de pedidos: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Campo de atribuci\u00f3n de pedidos: user_agent","type":["string","null"],"context":[]}}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/checkout"}]}},"\/wc\/store\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Datos a pasar con el m\u00e9todo de pago al procesar el pago.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Nota a\u00f1adida al pedido por el cliente durante el pago.","type":"string","required":false},"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"El ID del m\u00e9todo de pago que se est\u00e1 usando para procesar el pago.","type":"string","enum":["","bacs","cheque","cod","acceptbluecard","acceptbluecard_ach"],"required":false},"additional_fields":{"description":"Campos adicionales que deben permanecer en el pedido.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"rcfwc":{"description":"Datos de extensi\u00f3n registrados por rcfwc","type":["object","null"],"context":["view","edit"],"properties":{"token":{"description":"reCaptcha token.","type":"string","readonly":false}}},"woocommerce\/order-attribution":{"description":"Datos de extensi\u00f3n registrados por woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Campo de atribuci\u00f3n de pedidos: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Campo de atribuci\u00f3n de pedidos: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Campo de atribuci\u00f3n de pedidos: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Campo de atribuci\u00f3n de pedidos: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Campo de atribuci\u00f3n de pedidos: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Campo de atribuci\u00f3n de pedidos: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Campo de atribuci\u00f3n de pedidos: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Campo de atribuci\u00f3n de pedidos: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Campo de atribuci\u00f3n de pedidos: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Campo de atribuci\u00f3n de pedidos: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Campo de atribuci\u00f3n de pedidos: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Campo de atribuci\u00f3n de pedidos: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Campo de atribuci\u00f3n de pedidos: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Campo de atribuci\u00f3n de pedidos: user_agent","type":["string","null"],"context":[]}}}},"default":{"rcfwc":[],"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/products\/attributes":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products\/attributes"}]}},"\/wc\/store\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"__experimental_visual":{"description":"Si es true, incluye datos experimentales de muestra visual para t\u00e9rminos de atributos wc-visual.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/products\/categories":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products\/categories"}]}},"\/wc\/store\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/products\/brands":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products\/brands"}]}},"\/wc\/store\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/products\/collection-data":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"slug":{"description":"Limita el resultado a productos con slug(s) espec\u00edfico(s). Usa comas para separarlos.","type":"string","required":false},"after":{"description":"Limitar la respuesta a recursos creados despu\u00e9s de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a recursos creados antes de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"date_column":{"description":"Al limitar la respuesta usando antes\/despu\u00e9s, contra qu\u00e9 columnas de fecha comparar.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de categor\u00edas, separados por comas.","type":"string","required":false},"category_operator":{"description":"Operador para comparar los t\u00e9rminos de categor\u00edas de producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de marca, separados por comas.","type":"string","required":false},"brand_operator":{"description":"Operador para comparar los t\u00e9rminos de la marca del producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs de etiquetas o slugs, separados por comas.","type":"string","required":false},"tag_operator":{"description":"Operador para comparar etiquetas de productos.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00ednimo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"max_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00e1ximo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limitar el resultado a productos con los atributos globales seleccionados.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nombre del atributo de la taxonom\u00eda.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Lista de IDs del t\u00e9rmino del atributo.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Lista de slug(s) del\/los atributo(s). Si se facilita un ID del t\u00e9rmino esto se ignorar\u00e1.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operador para comparar los t\u00e9rminos de los atributos del producto.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"La relaci\u00f3n l\u00f3gica entre atributos al filtrar entre varios a la vez.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determina si se muestran o no los productos del cat\u00e1logo ocultos o visibles.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limitar el resultado establecido a productos con una cierta valoraci\u00f3n media.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"related":{"description":"Limitar resultados a productos asignados al ID de un producto espec\u00edfico.","type":"integer","required":false},"calculate_price_range":{"description":"Si es true, calcula los precios m\u00ednimo y m\u00e1ximo de los productos de la colecci\u00f3n.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"Si es true, calcula el contador de inventario de los productos de la colecci\u00f3n.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"Si se solicita, calcula la cantidad del t\u00e9rmino del atributo de los productos de la colecci\u00f3n.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Nombre de la taxonom\u00eda.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Condici\u00f3n de filtro \t en marcha que podr\u00eda afectar al contador. Los valores v\u00e1lidos incluyen \u00aband\u00bb y \u00abor\u00bb.","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"maxItems":25,"required":false},"calculate_rating_counts":{"description":"Si es true, calcula el contador de valoraciones de los productos de la colecci\u00f3n.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"Si se solicita, calcula los recuentos de t\u00e9rminos de taxonom\u00eda en los productos de la colecci\u00f3n.","type":"array","items":{"type":"string","description":"Nombre de la taxonom\u00eda."},"default":[],"maxItems":25,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products\/collection-data"}]}},"\/wc\/store\/products\/reviews":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Limita el conjunto de resultados a las valoraciones de IDs de categor\u00edas espec\u00edficas.","type":"string","required":false},"product_id":{"description":"Limita el conjunto de resultados a las valoraciones de IDs de productos espec\u00edficos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products\/reviews"}]}},"\/wc\/store\/products\/tags":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products\/tags"}]}},"\/wc\/store\/products":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"slug":{"description":"Limita el resultado a productos con slug(s) espec\u00edfico(s). Usa comas para separarlos.","type":"string","required":false},"after":{"description":"Limitar la respuesta a recursos creados despu\u00e9s de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a recursos creados antes de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"date_column":{"description":"Al limitar la respuesta usando antes\/despu\u00e9s, contra qu\u00e9 columnas de fecha comparar.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de categor\u00edas, separados por comas.","type":"string","required":false},"category_operator":{"description":"Operador para comparar los t\u00e9rminos de categor\u00edas de producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de marca, separados por comas.","type":"string","required":false},"brand_operator":{"description":"Operador para comparar los t\u00e9rminos de la marca del producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs de etiquetas o slugs, separados por comas.","type":"string","required":false},"tag_operator":{"description":"Operador para comparar etiquetas de productos.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00ednimo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"max_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00e1ximo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limitar el resultado a productos con los atributos globales seleccionados.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nombre del atributo de la taxonom\u00eda.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Lista de IDs del t\u00e9rmino del atributo.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Lista de slug(s) del\/los atributo(s). Si se facilita un ID del t\u00e9rmino esto se ignorar\u00e1.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operador para comparar los t\u00e9rminos de los atributos del producto.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"La relaci\u00f3n l\u00f3gica entre atributos al filtrar entre varios a la vez.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determina si se muestran o no los productos del cat\u00e1logo ocultos o visibles.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limitar el resultado establecido a productos con una cierta valoraci\u00f3n media.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"related":{"description":"Limitar resultados a productos asignados al ID de un producto espec\u00edfico.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/products"}]}},"\/wc\/store\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/store\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1"}]}},"\/wc\/store\/v1\/batch":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/batch"}]}},"\/wc\/store\/v1\/cart":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart"}]}},"\/wc\/store\/v1\/cart\/add-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"El ID del producto o la variaci\u00f3n en el carrito.","type":"integer","required":false},"quantity":{"description":"Cantidad de este art\u00edculo para a\u00f1adir en el carrito.","type":"number","required":false},"variation":{"description":"Atributos elegidos (para variaciones).","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nombre del atributo de la variaci\u00f3n.","type":"string","context":["view","edit"]},"value":{"description":"Valor del atributo de la variaci\u00f3n.","type":"string","context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/add-item"}]}},"\/wc\/store\/v1\/cart\/apply-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/apply-coupon"}]}},"\/wc\/store\/v1\/cart\/coupons":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"El c\u00f3digo \u00fanico del cup\u00f3n.","type":"string","required":false},"discount_type":{"description":"El tipo de descuento del cup\u00f3n (p.ej.: porcentaje o cantidad fija)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/coupons"}]}},"\/wc\/store\/v1\/cart\/coupons\/(?P<code>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/cart\/extensions":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"namespace":{"description":"Nombre de la extensi\u00f3n - ser\u00e1 usado para garantizar que los datos de la solicitud se dirijan adecuadamente.","type":"string","required":false},"data":{"description":"Datos adicionales para pasar a la extensi\u00f3n","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/extensions"}]}},"\/wc\/store\/v1\/cart\/items":{"namespace":"wc\/store\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"extensions":{"type":"object","properties":{"woocommerce_google_analytics_integration":{"description":"Datos de extensi\u00f3n registrados por woocommerce_google_analytics_integration","type":["object","null"],"context":["view","edit"],"properties":{"identifier":{"description":"El identificador de producto formateado que se utilizar\u00e1 en los eventos de Google Analytics.","type":"string","readonly":true}}}},"default":{"woocommerce_google_analytics_integration":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/items"}]}},"\/wc\/store\/v1\/cart\/items\/(?P<key>[\\w-]{32})":{"namespace":"wc\/store\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico para el art\u00edculo en el carrito.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico para el art\u00edculo en el carrito.","type":"string","required":false},"extensions":{"type":"object","properties":{"woocommerce_google_analytics_integration":{"description":"Datos de extensi\u00f3n registrados por woocommerce_google_analytics_integration","type":["object","null"],"context":["view","edit"],"properties":{"identifier":{"description":"El identificador de producto formateado que se utilizar\u00e1 en los eventos de Google Analytics.","type":"string","readonly":true}}}},"required":false},"quantity":{"description":"Nueva cantidad del producto en el carrito.","type":"number","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico para el art\u00edculo en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/cart\/remove-coupon":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"code":{"description":"Identificador \u00fanico para el cup\u00f3n en el carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/remove-coupon"}]}},"\/wc\/store\/v1\/cart\/remove-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico (clave) del producto del carrito.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/remove-item"}]}},"\/wc\/store\/v1\/cart\/select-shipping-rate":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"package_id":{"description":"El ID del paquete a enviar. D\u00e9jalo en blanco para aplicarlo a todos los paquetes.","type":["integer","string","null"],"required":false},"rate_id":{"description":"El ID de la tarifa elegida para el paquete.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/select-shipping-rate"}]}},"\/wc\/store\/v1\/cart\/update-item":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"key":{"description":"Identificador \u00fanico (clave) del producto del carrito a actualizar.","type":"string","required":false},"quantity":{"description":"Nueva cantidad del producto en el carrito.","type":"number","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/update-item"}]}},"\/wc\/store\/v1\/cart\/update-customer":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/cart\/update-customer"}]}},"\/wc\/store\/v1\/checkout":{"namespace":"wc\/store\/v1","methods":["GET","POST","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Datos a pasar con el m\u00e9todo de pago al procesar el pago.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_password":{"description":"Contrase\u00f1a del cliente para cuentas nuevas, si procede.","type":"string","required":false},"expected_total":{"description":"El total del pedido que el comprador confirm\u00f3 en el cliente, como una cadena en la unidad m\u00e1s peque\u00f1a de la moneda de la tienda (por ejemplo, c\u00e9ntimos), que coincide con el formato `totals.total_price` del carrito. Cuando se proporciona, el pedido se rechaza si el total calculado en el servidor ya no coincide, protegiendo al comprador de que se le cobre un importe inesperado.","type":"string","pattern":"^[0-9]+$","required":false},"customer_note":{"description":"Nota a\u00f1adida al pedido por el cliente durante el pago.","type":"string","required":false},"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"El ID del m\u00e9todo de pago que se est\u00e1 usando para procesar el pago.","type":"string","enum":["","bacs","cheque","cod","acceptbluecard","acceptbluecard_ach"],"required":false},"create_account":{"description":"Crear una nueva cuenta de usuario como parte del proceso del pedido.","type":"boolean","required":false},"additional_fields":{"description":"Campos adicionales que deben permanecer en el pedido.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"rcfwc":{"description":"Datos de extensi\u00f3n registrados por rcfwc","type":["object","null"],"context":["view","edit"],"properties":{"token":{"description":"reCaptcha token.","type":"string","readonly":false}}},"woocommerce\/order-attribution":{"description":"Datos de extensi\u00f3n registrados por woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Campo de atribuci\u00f3n de pedidos: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Campo de atribuci\u00f3n de pedidos: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Campo de atribuci\u00f3n de pedidos: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Campo de atribuci\u00f3n de pedidos: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Campo de atribuci\u00f3n de pedidos: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Campo de atribuci\u00f3n de pedidos: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Campo de atribuci\u00f3n de pedidos: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Campo de atribuci\u00f3n de pedidos: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Campo de atribuci\u00f3n de pedidos: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Campo de atribuci\u00f3n de pedidos: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Campo de atribuci\u00f3n de pedidos: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Campo de atribuci\u00f3n de pedidos: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Campo de atribuci\u00f3n de pedidos: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Campo de atribuci\u00f3n de pedidos: user_agent","type":["string","null"],"context":[]}}}},"default":{"rcfwc":[],"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"additional_fields":{"description":"Campos adicionales que deben permanecer en el pedido.","type":"object","properties":[],"required":false},"payment_method":{"description":"El ID del m\u00e9todo de pago que se est\u00e1 usando para procesar el pago.","type":"string","enum":["","bacs","cheque","cod","acceptbluecard","acceptbluecard_ach"],"required":false},"order_notes":{"description":"Notas de pedidos.","type":"string","required":false},"customer_note":{"description":"Nota a\u00f1adida al pedido por el cliente durante el pago.","type":"string","required":false},"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":false},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"create_account":{"description":"Crear una nueva cuenta de usuario como parte del proceso del pedido.","type":"boolean","required":false},"extensions":{"type":"object","properties":{"rcfwc":{"description":"Datos de extensi\u00f3n registrados por rcfwc","type":["object","null"],"context":["view","edit"],"properties":{"token":{"description":"reCaptcha token.","type":"string","readonly":false}}},"woocommerce\/order-attribution":{"description":"Datos de extensi\u00f3n registrados por woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Campo de atribuci\u00f3n de pedidos: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Campo de atribuci\u00f3n de pedidos: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Campo de atribuci\u00f3n de pedidos: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Campo de atribuci\u00f3n de pedidos: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Campo de atribuci\u00f3n de pedidos: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Campo de atribuci\u00f3n de pedidos: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Campo de atribuci\u00f3n de pedidos: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Campo de atribuci\u00f3n de pedidos: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Campo de atribuci\u00f3n de pedidos: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Campo de atribuci\u00f3n de pedidos: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Campo de atribuci\u00f3n de pedidos: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Campo de atribuci\u00f3n de pedidos: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Campo de atribuci\u00f3n de pedidos: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Campo de atribuci\u00f3n de pedidos: user_agent","type":["string","null"],"context":[]}}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/checkout"}]}},"\/wc\/store\/v1\/checkout\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"payment_data":{"description":"Datos a pasar con el m\u00e9todo de pago al procesar el pago.","type":"array","items":{"type":"object","properties":{"key":{"type":"string"},"value":{"type":["string","boolean"]}}},"required":false},"customer_note":{"description":"Nota a\u00f1adida al pedido por el cliente durante el pago.","type":"string","required":false},"billing_address":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true},"email":{"description":"Correo electr\u00f3nico","type":"string","context":["view","edit"],"required":true}},"required":true},"shipping_address":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre","type":"string","context":["view","edit"],"required":true},"last_name":{"description":"Apellidos","type":"string","context":["view","edit"],"required":true},"company":{"description":"Empresa","type":"string","context":["view","edit"],"required":true},"address_1":{"description":"Direcci\u00f3n","type":"string","context":["view","edit"],"required":true},"address_2":{"description":"Apartamento, habitaci\u00f3n, escalera, etc.","type":"string","context":["view","edit"],"required":true},"city":{"description":"Ciudad","type":"string","context":["view","edit"],"required":true},"state":{"description":"C\u00f3digo de provincia\/condado, o nombre de la provincia, condado, o distrito.","type":"string","context":["view","edit"],"required":true},"postcode":{"description":"C\u00f3digo postal","type":"string","context":["view","edit"],"required":true},"country":{"description":"C\u00f3digo de pa\u00eds\/regi\u00f3n en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"],"required":true},"phone":{"description":"Tel\u00e9fono","type":"string","maxLength":100,"context":["view","edit"],"required":true}},"required":false},"payment_method":{"description":"El ID del m\u00e9todo de pago que se est\u00e1 usando para procesar el pago.","type":"string","enum":["","bacs","cheque","cod","acceptbluecard","acceptbluecard_ach"],"required":false},"additional_fields":{"description":"Campos adicionales que deben permanecer en el pedido.","type":"object","properties":[],"required":false},"extensions":{"type":"object","properties":{"rcfwc":{"description":"Datos de extensi\u00f3n registrados por rcfwc","type":["object","null"],"context":["view","edit"],"properties":{"token":{"description":"reCaptcha token.","type":"string","readonly":false}}},"woocommerce\/order-attribution":{"description":"Datos de extensi\u00f3n registrados por woocommerce\/order-attribution","type":["object","null"],"context":["view","edit"],"properties":{"source_type":{"description":"Campo de atribuci\u00f3n de pedidos: source_type","type":["string","null"],"context":[]},"referrer":{"description":"Campo de atribuci\u00f3n de pedidos: referrer","type":["string","null"],"context":[]},"utm_campaign":{"description":"Campo de atribuci\u00f3n de pedidos: utm_campaign","type":["string","null"],"context":[]},"utm_source":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source","type":["string","null"],"context":[]},"utm_medium":{"description":"Campo de atribuci\u00f3n de pedidos: utm_medium","type":["string","null"],"context":[]},"utm_content":{"description":"Campo de atribuci\u00f3n de pedidos: utm_content","type":["string","null"],"context":[]},"utm_id":{"description":"Campo de atribuci\u00f3n de pedidos: utm_id","type":["string","null"],"context":[]},"utm_term":{"description":"Campo de atribuci\u00f3n de pedidos: utm_term","type":["string","null"],"context":[]},"utm_source_platform":{"description":"Campo de atribuci\u00f3n de pedidos: utm_source_platform","type":["string","null"],"context":[]},"utm_creative_format":{"description":"Campo de atribuci\u00f3n de pedidos: utm_creative_format","type":["string","null"],"context":[]},"utm_marketing_tactic":{"description":"Campo de atribuci\u00f3n de pedidos: utm_marketing_tactic","type":["string","null"],"context":[]},"session_entry":{"description":"Campo de atribuci\u00f3n de pedidos: session_entry","type":["string","null"],"context":[]},"session_start_time":{"description":"Campo de atribuci\u00f3n de pedidos: session_start_time","type":["string","null"],"context":[]},"session_pages":{"description":"Campo de atribuci\u00f3n de pedidos: session_pages","type":["string","null"],"context":[]},"session_count":{"description":"Campo de atribuci\u00f3n de pedidos: session_count","type":["string","null"],"context":[]},"user_agent":{"description":"Campo de atribuci\u00f3n de pedidos: user_agent","type":["string","null"],"context":[]}}}},"default":{"rcfwc":[],"woocommerce\/order-attribution":[]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/order\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/products\/attributes":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products\/attributes"}]}},"\/wc\/store\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count","menu_order","name_num","id"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"__experimental_visual":{"description":"Si es true, incluye datos experimentales de muestra visual para t\u00e9rminos de atributos wc-visual.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/products\/categories":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products\/categories"}]}},"\/wc\/store\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/products\/brands":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products\/brands"}]}},"\/wc\/store\/v1\/products\/brands\/(?P<identifier>[\\w-]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"identifier":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/products\/collection-data":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"slug":{"description":"Limita el resultado a productos con slug(s) espec\u00edfico(s). Usa comas para separarlos.","type":"string","required":false},"after":{"description":"Limitar la respuesta a recursos creados despu\u00e9s de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a recursos creados antes de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"date_column":{"description":"Al limitar la respuesta usando antes\/despu\u00e9s, contra qu\u00e9 columnas de fecha comparar.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de categor\u00edas, separados por comas.","type":"string","required":false},"category_operator":{"description":"Operador para comparar los t\u00e9rminos de categor\u00edas de producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de marca, separados por comas.","type":"string","required":false},"brand_operator":{"description":"Operador para comparar los t\u00e9rminos de la marca del producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs de etiquetas o slugs, separados por comas.","type":"string","required":false},"tag_operator":{"description":"Operador para comparar etiquetas de productos.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00ednimo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"max_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00e1ximo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limitar el resultado a productos con los atributos globales seleccionados.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nombre del atributo de la taxonom\u00eda.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Lista de IDs del t\u00e9rmino del atributo.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Lista de slug(s) del\/los atributo(s). Si se facilita un ID del t\u00e9rmino esto se ignorar\u00e1.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operador para comparar los t\u00e9rminos de los atributos del producto.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"La relaci\u00f3n l\u00f3gica entre atributos al filtrar entre varios a la vez.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determina si se muestran o no los productos del cat\u00e1logo ocultos o visibles.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limitar el resultado establecido a productos con una cierta valoraci\u00f3n media.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"related":{"description":"Limitar resultados a productos asignados al ID de un producto espec\u00edfico.","type":"integer","required":false},"calculate_price_range":{"description":"Si es true, calcula los precios m\u00ednimo y m\u00e1ximo de los productos de la colecci\u00f3n.","type":"boolean","default":false,"required":false},"calculate_stock_status_counts":{"description":"Si es true, calcula el contador de inventario de los productos de la colecci\u00f3n.","type":"boolean","default":false,"required":false},"calculate_attribute_counts":{"description":"Si se solicita, calcula la cantidad del t\u00e9rmino del atributo de los productos de la colecci\u00f3n.","type":"array","items":{"type":"object","properties":{"taxonomy":{"description":"Nombre de la taxonom\u00eda.","type":"string","context":["view","edit"],"readonly":true},"query_type":{"description":"Condici\u00f3n de filtro \t en marcha que podr\u00eda afectar al contador. Los valores v\u00e1lidos incluyen \u00aband\u00bb y \u00abor\u00bb.","type":"string","enum":["and","or"],"context":["view","edit"],"readonly":true}}},"default":[],"maxItems":25,"required":false},"calculate_rating_counts":{"description":"Si es true, calcula el contador de valoraciones de los productos de la colecci\u00f3n.","type":"boolean","default":false,"required":false},"calculate_taxonomy_counts":{"description":"Si se solicita, calcula los recuentos de t\u00e9rminos de taxonom\u00eda en los productos de la colecci\u00f3n.","type":"array","items":{"type":"string","description":"Nombre de la taxonom\u00eda."},"default":[],"maxItems":25,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products\/collection-data"}]}},"\/wc\/store\/v1\/products\/reviews":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","date_gmt","id","rating","product"],"required":false},"category_id":{"description":"Limita el conjunto de resultados a las valoraciones de IDs de categor\u00edas espec\u00edficas.","type":"string","required":false},"product_id":{"description":"Limita el conjunto de resultados a las valoraciones de IDs de productos espec\u00edficos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products\/reviews"}]}},"\/wc\/store\/v1\/products\/tags":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de productos a mostrar en el conjunto de resultados. Por defecto no hay l\u00edmite si se deja en blanco.","type":"integer","minimum":0,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar en ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar por propiedad del t\u00e9rmino.","type":"string","default":"name","enum":["name","slug","count"],"required":false},"hide_empty":{"description":"Si es true, no se mostrar\u00e1n los t\u00e9rminos vac\u00edos.","type":"boolean","default":true,"required":false},"parent":{"description":"Limitar los resultados a t\u00e9rminos con un superior espec\u00edfico (solo taxonom\u00edas jer\u00e1rquicas).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products\/tags"}]}},"\/wc\/store\/v1\/products":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"slug":{"description":"Limita el resultado a productos con slug(s) espec\u00edfico(s). Usa comas para separarlos.","type":"string","required":false},"after":{"description":"Limitar la respuesta a recursos creados despu\u00e9s de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a recursos creados antes de una fecha compatible con ISO8601 dada.","type":"string","format":"date-time","required":false},"date_column":{"description":"Al limitar la respuesta usando antes\/despu\u00e9s, contra qu\u00e9 columnas de fecha comparar.","type":"string","default":"date","enum":["date","date_gmt","modified","modified_gmt"],"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","modified","id","include","title","slug","price","popularity","rating","menu_order","comment_count"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable","variation"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de categor\u00edas, separados por comas.","type":"string","required":false},"category_operator":{"description":"Operador para comparar los t\u00e9rminos de categor\u00edas de producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"brand":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs o slugs de marca, separados por comas.","type":"string","required":false},"brand_operator":{"description":"Operador para comparar los t\u00e9rminos de la marca del producto.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"tag":{"description":"Limitar el conjunto de resultados a productos asignados a un conjunto de IDs de etiquetas o slugs, separados por comas.","type":"string","required":false},"tag_operator":{"description":"Operador para comparar etiquetas de productos.","type":"string","enum":["in","not_in","and"],"default":"in","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00ednimo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"max_price":{"description":"Limita el conjunto de resultados a productos basados en un precio m\u00e1ximo, facilitado usando la unidad m\u00e1s peque\u00f1a de la moneda.","type":"string","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"array","items":{"type":"string","enum":["instock","outofstock","onbackorder"],"sanitize_callback":"sanitize_text_field","validate_callback":"rest_validate_request_arg"},"default":[],"required":false},"attributes":{"description":"Limitar el resultado a productos con los atributos globales seleccionados.","type":"array","items":{"type":"object","properties":{"attribute":{"description":"Nombre del atributo de la taxonom\u00eda.","type":"string","sanitize_callback":"wc_sanitize_taxonomy_name"},"term_id":{"description":"Lista de IDs del t\u00e9rmino del atributo.","type":"array","items":{"type":"integer"},"sanitize_callback":"wp_parse_id_list"},"slug":{"description":"Lista de slug(s) del\/los atributo(s). Si se facilita un ID del t\u00e9rmino esto se ignorar\u00e1.","type":"array","items":{"type":"string"},"sanitize_callback":"wp_parse_slug_list"},"operator":{"description":"Operador para comparar los t\u00e9rminos de los atributos del producto.","type":"string","enum":["in","not_in","and"]}}},"default":[],"required":false},"attribute_relation":{"description":"La relaci\u00f3n l\u00f3gica entre atributos al filtrar entre varios a la vez.","type":"string","enum":["in","and"],"default":"and","required":false},"catalog_visibility":{"description":"Determina si se muestran o no los productos del cat\u00e1logo ocultos o visibles.","type":"string","enum":["any","visible","catalog","search","hidden"],"required":false},"rating":{"description":"Limitar el resultado establecido a productos con una cierta valoraci\u00f3n media.","type":"array","items":{"type":"integer","enum":[1,2,3,4,5]},"default":[],"required":false},"related":{"description":"Limitar resultados a productos asignados al ID de un producto espec\u00edfico.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/store\/v1\/products"}]}},"\/wc\/store\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/store\/v1\/products\/(?P<slug>[\\S]+)":{"namespace":"wc\/store\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito bajo la cual se realiza la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/private":{"namespace":"wc\/private","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/private","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/private"}]}},"\/wc\/private\/patterns":{"namespace":"wc\/private","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/private\/patterns"}]}},"\/wc\/v3\/pickup-locations":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"pickup_location_settings":{"description":"Ajustes del m\u00e9todo de recogida local.","type":"object","required":false},"pickup_locations":{"description":"Lista de ubicaciones de recogida local.","type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/pickup-locations"}]}},"\/wp-smush\/v1":{"namespace":"wp-smush\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-smush\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp-smush\/v1"}]}},"\/wp-smush\/v1\/preset_configs":{"namespace":"wp-smush\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp-smush\/v1\/preset_configs"}]}},"\/hub-connector\/v1":{"namespace":"hub-connector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hub-connector\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/hub-connector\/v1"}]}},"\/hub-connector\/v1\/sync":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"force":{"description":"Should do a force sync.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/hub-connector\/v1\/sync"}]}},"\/hub-connector\/v1\/logout":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/hub-connector\/v1\/logout"}]}},"\/wc\/v2":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2"}]}},"\/wc\/v2\/products\/brands":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"default":"default","description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/brands"}]}},"\/wc\/v2\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/brands\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/brands\/batch"}]}},"\/wc\/v3\/products\/brands":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"default":"default","description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/brands"}]}},"\/wc\/v3\/products\/brands\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/brands\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/brands\/batch"}]}},"\/yoast\/v1\/prominent_words":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"word":{"type":"string","description":"The prominent word to retrieve","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/prominent_words"}]}},"\/yoast\/v1\/prominent_words_link\/(?P<id>[\\d]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"yst_prominent_words":{"type":"array","items":{"type":"integer"},"description":"The prominent words to link","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/yoast\/v1\/complete_recalculation":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/complete_recalculation"}]}},"\/yoast\/v1\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prominent_words":{"type":"array","description":"IDs of the prominent words we want link suggestions based on","items":{"type":"int"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/link_suggestions"}]}},"\/yoast\/v1\/redirects":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"integer","description":"The redirect type","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/redirects"}]}},"\/yoast\/v1\/redirects\/delete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"string","description":"The redirect format","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/redirects\/delete"}]}},"\/yoast\/v1\/post_data":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/yoast\/v1\/post_data"}]}},"\/jetpack\/v4\/activity-log":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"N\u00famero de elementos que se deben devolver por p\u00e1gina.","type":"integer","minimum":1,"maximum":1000,"required":false},"page":{"description":"N\u00famero de p\u00e1gina indexada 1.","type":"integer","minimum":1,"required":false},"sort_order":{"description":"Direcci\u00f3n de organizaci\u00f3n.","type":"string","enum":["asc","desc"],"required":false},"after":{"description":"L\u00edmite inferior de ISO 8601 en la marca de tiempo del evento.","type":"string","format":"date-time","required":false},"before":{"description":"L\u00edmite superior de ISO 8601 en la marca de tiempo del evento.","type":"string","format":"date-time","required":false},"group":{"description":"Devuelve solo los eventos de estos grupos.","type":"array","items":{"type":"string"},"required":false},"not_group":{"description":"Excluye eventos de estos grupos.","type":"array","items":{"type":"string"},"required":false},"text_search":{"description":"Cadena de b\u00fasqueda de texto completo.","type":"string","required":false},"actor":{"description":"Devuelve solo los eventos realizados por estos ID de actor.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/activity-log"}]}},"\/jetpack\/v4\/activity-log\/count\/group":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Limita el n\u00famero de eventos considerados al contar grupos.","type":"integer","minimum":1,"maximum":1000,"required":false},"after":{"description":"L\u00edmite inferior de ISO 8601 en la marca de tiempo del evento.","type":"string","format":"date-time","required":false},"before":{"description":"L\u00edmite superior de ISO 8601 en la marca de tiempo del evento.","type":"string","format":"date-time","required":false},"group":{"description":"Solo cuenta los eventos de estos grupos.","type":"array","items":{"type":"string"},"required":false},"not_group":{"description":"Excluye eventos de estos grupos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/activity-log\/count\/group"}]}},"\/jetpack\/v4\/activity-log\/actors":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"L\u00edmite del n\u00famero de eventos considerados al recopilar actores.","type":"integer","minimum":1,"maximum":1000,"required":false},"after":{"description":"L\u00edmite inferior de ISO 8601 en la marca de tiempo del evento.","type":"string","format":"date-time","required":false},"before":{"description":"L\u00edmite superior de ISO 8601 en la marca de tiempo del evento.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/activity-log\/actors"}]}},"\/spc\/v1":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"spc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1"}]}},"\/spc\/v1\/cache\/purge":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cache\/purge"}]}},"\/spc\/v1\/cache\/test":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cache\/test"}]}},"\/spc\/v1\/cache\/purge-varnish":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cache\/purge-varnish"}]}},"\/spc\/v1\/logs\/clear":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/logs\/clear"}]}},"\/spc\/v1\/logs\/get":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/logs\/get"}]}},"\/spc\/v1\/preloader\/start":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/preloader\/start"}]}},"\/spc\/v1\/config\/import":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"settings":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/config\/import"}]}},"\/spc\/v1\/toggle-license":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"type":"string","required":false},"action":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/toggle-license"}]}},"\/spc\/v1\/settings\/reset":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/settings\/reset"}]}},"\/spc\/v1\/settings\/wizard":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/settings\/wizard"}]}},"\/spc\/v1\/settings\/update":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"settings":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/settings\/update"}]}},"\/spc\/v1\/cloudflare\/connect":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"auth_mode":{"required":true},"email":{"required":false},"api_key":{"required":false},"api_token":{"required":false},"domain_name":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cloudflare\/connect"}]}},"\/spc\/v1\/cloudflare\/disconnect":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cloudflare\/disconnect"}]}},"\/spc\/v1\/cloudflare\/confirm-zone-id":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"zone_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cloudflare\/confirm-zone-id"}]}},"\/spc\/v1\/database\/optimize":{"namespace":"spc\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"action":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/database\/optimize"}]}},"\/spc\/v1\/database\/optimize-counts":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/database\/optimize-counts"}]}},"\/spc\/v1\/cloudflare\/analytics":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cloudflare\/analytics"}]}},"\/spc\/v1\/cloudflare\/rule-status":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cloudflare\/rule-status"}]}},"\/spc\/v1\/cloudflare\/repair-rule":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cloudflare\/repair-rule"}]}},"\/spc\/v1\/notice\/dismiss":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/notice\/dismiss"}]}},"\/spc\/v1\/assets\/save-rules":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"assets_data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/assets\/save-rules"}]}},"\/spc\/v1\/optimizations":{"namespace":"spc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"d":{"type":"integer","required":true},"a":{"type":"array","required":true},"u":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/optimizations"}]}},"\/spc\/v1\/cached-pages":{"namespace":"spc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/spc\/v1\/cached-pages"}]}},"\/the7\/v1":{"namespace":"the7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"the7\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/the7\/v1"}]}},"\/the7\/v1\/send-mail":{"namespace":"the7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"security_token":{"type":"string","required":false},"send_message":{"type":"string","required":false},"fields":{"type":"array","required":false},"gcaptcha_token":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/the7\/v1\/send-mail"}]}},"\/jetpack\/v4\/blaze-app":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/blaze-app","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app"}]}},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/blaze\/posts(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app\/sites\/234862722\/blaze\/posts(\/?.*)\/?"}]}},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/sites\/234862722\/blaze\/posts(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/sites\/234862722\/blaze\/posts(\/?.*)\/?"}]}},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/checkout":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/checkout"}]}},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/credits(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/sites\/234862722\/media(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/sites\/234862722\/media":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/sites\/234862722\/media"}]}},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/wpcom\/media(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/experiments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1.1\/campaigns":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1.1\/campaigns"}]}},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/sites\/234862722\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/stats(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/stats(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/search(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/user(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/templates\/article\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/templates\/advise\/campaign\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/templates(?P<sub_path>[a-zA-Z0-9-_\\\/:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/advise\/campaign\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/advise(?P<sub_path>[a-zA-Z0-9-_\\\/:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/subscriptions(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/subscriptions(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/payments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/payments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/smart(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/smart(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/locations(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/woo(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/image(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/logs":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze-app\/sites\/234862722\/wordads\/dsp\/api\/v1\/logs"}]}},"\/jetpack\/v4\/blaze":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/blaze","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze"}]}},"\/jetpack\/v4\/blaze\/eligibility":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze\/eligibility"}]}},"\/jetpack\/v4\/blaze\/dashboard":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze\/dashboard"}]}},"\/jetpack\/v4\/blaze\/active-campaigns":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/blaze\/active-campaigns"}]}},"\/woocommerce-analytics\/v1":{"namespace":"woocommerce-analytics\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"woocommerce-analytics\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/woocommerce-analytics\/v1"}]}},"\/woocommerce-analytics\/v1\/track":{"namespace":"woocommerce-analytics\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/woocommerce-analytics\/v1\/track"}]}},"\/jetpack\/v4\/feature\/custom-content-types":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/feature\/custom-content-types"}]}},"\/jetpack\/v4\/hints":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"hint":{"default":"","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/hints"}]}},"\/the7\/v1\/fse-font":{"namespace":"the7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/the7\/v1\/fse-font"}]}},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/email-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"frequency":{"type":"string","enum":["weekly","monthly","quarterly"]},"subscribed":{"type":"boolean"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/email-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/email-reporting-next-report":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/email-reporting-next-report"}]}},"\/google-site-kit\/v1\/core\/user\/data\/initial-setup-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"hasSitePurposeAnswer":{"type":"boolean"},"isAnalyticsSetupComplete":{"type":"boolean"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/initial-setup-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"data":{"type":"object","description":"Ajustes para establecer.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"datapoint":{"type":"string","description":"Los datos del m\u00f3dulo apuntan a la direcci\u00f3n.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"datapoint":{"type":"string","description":"Los datos del m\u00f3dulo apuntan a la direcci\u00f3n.","default":null,"required":false},"data":{"type":"object","description":"Datos a configurar.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/intents\/data\/intent":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"","default":null,"required":true},"intent_code":{"type":"string","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/intents\/data\/intent"}]}},"\/google-site-kit\/v1\/core\/intents\/data\/complete-intent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"slug":{"type":"string","required":true},"intent_code":{"type":"string","required":true}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/intents\/data\/complete-intent"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/user\/data\/feedback":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"namespace":{"type":"string","required":true},"group":{"type":"string","required":true},"key":{"type":"string","required":true},"value":{"type":"string","required":true}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/feedback"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Contenido de texto por el que buscar.","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/wp-dashboard-widget-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/wp-dashboard-widget-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-eligible-subscribers":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","description":"","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","description":"","default":20,"minimum":1,"maximum":100,"required":false},"search":{"type":"string","description":"","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-eligible-subscribers"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-subscribed-users":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","description":"","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","description":"","default":20,"minimum":1,"maximum":100,"required":false},"search":{"type":"string","description":"","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-subscribed-users"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-unsubscribe-user":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"userID":{"type":"integer","required":true,"minimum":1}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-unsubscribe-user"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-errors":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-errors"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-invite-user":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"userID":{"type":"integer","required":true,"minimum":1}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-invite-user"}]}},"\/wc-admin\/blueprint\/export":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"steps":{"description":"Una lista de plugins para instalar","type":"object","properties":{"settings":{"type":"array","items":{"type":"string"}},"plugins":{"type":"array","items":{"type":"string"}},"themes":{"type":"array","items":{"type":"string"}}},"default":[],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/blueprint\/export"}]}},"\/wc-admin\/blueprint\/import-step":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step_definition":{"description":"La definici\u00f3n del paso que debe importarse","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/blueprint\/import-step"}]}},"\/wc-admin\/blueprint\/import-allowed":{"namespace":"wc-admin","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/blueprint\/import-allowed"}]}},"\/wpf\/v1\/filters-list":{"namespace":"wpf\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpf\/v1\/filters-list"}]}},"\/wc\/v1\/coupons":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Usar par\u00e1metros de WP Query para modificar la respuesta. Las variables de consulta privadas necesitan la autorizaci\u00f3n correspondiente.","required":false},"code":{"description":"Limitar los resultados a recursos con un c\u00f3digo espec\u00edfico.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":true},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":"string","required":false},"expiry_date":{"description":"Fecha y hora UTC de caducidad del cup\u00f3n.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":"string","required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":"string","required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/coupons"}]}},"\/wc\/v1\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":"string","required":false},"expiry_date":{"description":"Fecha y hora UTC de caducidad del cup\u00f3n.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":"string","required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":"string","required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/coupons\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":"string","required":false},"expiry_date":{"description":"Fecha y hora UTC de caducidad del cup\u00f3n.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":"string","required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":"string","required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/coupons\/batch"}]}},"\/wc\/v1\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/customers":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el resultado a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limitar resultados a recursos con un correo electr\u00f3nico determinado.","type":"string","format":"email","required":false},"role":{"description":"Limitar el conjunto de resultados a recursos con un perfil espec\u00edfico.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","give_manager","give_accountant","give_worker","give_donor","customer","shop_manager","wpseo_manager","wpseo_editor","wpc_client","wpc_client_staff","wpc_manager","wpc_admin"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Nueva direcci\u00f3n de correo electr\u00f3nico del usuario.","required":true},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nuevo nombre de usuario del usuario.","type":"string","required":false},"password":{"description":"Nueva contrase\u00f1a de usuario.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/customers"}]}},"\/wc\/v1\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico para el cliente.","type":"string","format":"email","required":false},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nombre de acceso del cliente.","type":"string","required":false},"password":{"description":"Contrase\u00f1a del cliente.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"reassign":{"default":0,"type":"integer","description":"ID al que reasignar las publicaciones.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/customers\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico para el cliente.","type":"string","format":"email","required":false},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nombre de acceso del cliente.","type":"string","required":false},"password":{"description":"Contrase\u00f1a del cliente.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/customers\/batch"}]}},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"note":{"type":"string","description":"Contenido de la nota del pedido.","required":true},"customer_note":{"default":false,"description":"Muestra\/define si la nota es solo para referencia o para el cliente (se avisar\u00e1 al usuario).","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Usar par\u00e1metros de WP Query para modificar la respuesta. Las variables de consulta privadas necesitan la autorizaci\u00f3n correspondiente.","required":false},"status":{"default":"any","description":"Limitar resultados a pedidos con un estado determinado.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limitar resultados a pedidos de un cliente determinado.","type":"integer","required":false},"product":{"description":"Limitar resultados a pedidos asignados con un producto determinado.","type":"integer","required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"amount":{"description":"Cantidad del reembolso.","type":"string","required":false},"reason":{"description":"Raz\u00f3n del reembolso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/orders":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Usar par\u00e1metros de WP Query para modificar la respuesta. Las variables de consulta privadas necesitan la autorizaci\u00f3n correspondiente.","required":false},"status":{"default":"any","description":"Limitar resultados a pedidos con un estado determinado.","type":"string","enum":["any","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limitar resultados a pedidos de un cliente determinado.","type":"integer","required":false},"product":{"description":"Limitar resultados a pedidos asignados con un producto determinado.","type":"integer","required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"status":{"default":"pending","description":"Estado del pedido.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"USD","description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"set_paid":{"default":false,"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Metadatos del art\u00edculo del pedido.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Clave meta.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Etiqueta meta.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/orders"}]}},"\/wc\/v1\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Metadatos del art\u00edculo del pedido.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Clave meta.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Etiqueta meta.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/orders\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1.","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2.","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta":{"description":"Metadatos del art\u00edculo del pedido.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"key":{"description":"Clave meta.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Etiqueta meta.","type":"string","context":["view","edit"],"readonly":true},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/orders\/batch"}]}},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/attributes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del recurso.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"default":"select","description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"default":"menu_order","description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/attributes"}]}},"\/wc\/v1\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/attributes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/attributes\/batch"}]}},"\/wc\/v1\/products\/categories":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"default":"default","description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/categories"}]}},"\/wc\/v1\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/categories\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/categories\/batch"}]}},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"review":{"type":"string","description":"Contenido de la valoraci\u00f3n.","required":true},"date_created":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"name":{"type":"string","description":"Nombre de quien dej\u00f3 la valoraci\u00f3n.","required":true},"email":{"type":"string","description":"Correo electr\u00f3nico de quien dej\u00f3 la valoraci\u00f3n.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"date_created":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"name":{"description":"Nombre de quien valora.","type":"string","required":false},"email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/shipping_classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/shipping_classes"}]}},"\/wc\/v1\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/shipping_classes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/shipping_classes\/batch"}]}},"\/wc\/v1\/products\/tags":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/tags"}]}},"\/wc\/v1\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la etiqueta.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/tags\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la etiqueta.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/tags\/batch"}]}},"\/wc\/v1\/products":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"filter":{"type":"object","description":"Usar par\u00e1metros de WP Query para modificar la respuesta. Las variables de consulta privadas necesitan la autorizaci\u00f3n correspondiente.","required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limitar resultados a productos con un atributo espec\u00edfico.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"sku":{"description":"Limitar los resultados a productos con un SKU determinado.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"type":{"default":"simple","description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha de inicio del precio de oferta.","type":"string","required":false},"date_on_sale_to":{"description":"Fecha final del precio de oferta.","type":"string","required":false},"virtual":{"default":false,"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"download_type":{"default":"standard","description":"Tipo de descarga, esto controla el esquema en la tienda.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"default":true,"description":"Controla si el producto se muestra (o no) como \u00abhay existencias\u00bb o \u00abagotado\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Permitir valoraciones.","type":"boolean","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Lista de variaciones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la variaci\u00f3n.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"La fecha en la que la variaci\u00f3n fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la variaci\u00f3n fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"URL de la variaci\u00f3n.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Identificador \u00fanico.","type":"string","context":["view","edit"]},"price":{"description":"Precio actual de la variaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","context":["view","edit"]},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Fecha de inicio del precio de oferta.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Fecha final del precio de oferta.","type":"string","context":["view","edit"]},"on_sale":{"description":"Muestra si la variaci\u00f3n est\u00e1 rebajada.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Muestra si la variaci\u00f3n puede ser comprada.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Si es visible la variaci\u00f3n.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Lista de archivos descargables.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Estado del impuesto.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Controla si la variaci\u00f3n se muestra como \u00abhay existencias\u00bb o como \u00abagotada\u00bb en la tienda.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Muestra si se permiten reservas.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Muestra si la variaci\u00f3n est\u00e1 reservada.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","context":["view","edit"]},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"ID de la clase de env\u00edo.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","context":["view","edit"],"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Lista de atributos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products"}]}},"\/wc\/v1\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha de inicio del precio de oferta.","type":"string","required":false},"date_on_sale_to":{"description":"Fecha final del precio de oferta.","type":"string","required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"download_type":{"description":"Tipo de descarga, esto controla el esquema en la tienda.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"description":"Controla si el producto se muestra (o no) como \u00abhay existencias\u00bb o \u00abagotado\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Lista de variaciones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la variaci\u00f3n.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"La fecha en la que la variaci\u00f3n fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la variaci\u00f3n fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"URL de la variaci\u00f3n.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Identificador \u00fanico.","type":"string","context":["view","edit"]},"price":{"description":"Precio actual de la variaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","context":["view","edit"]},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Fecha de inicio del precio de oferta.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Fecha final del precio de oferta.","type":"string","context":["view","edit"]},"on_sale":{"description":"Muestra si la variaci\u00f3n est\u00e1 rebajada.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Muestra si la variaci\u00f3n puede ser comprada.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Si es visible la variaci\u00f3n.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Lista de archivos descargables.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Estado del impuesto.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Controla si la variaci\u00f3n se muestra como \u00abhay existencias\u00bb o como \u00abagotada\u00bb en la tienda.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Muestra si se permiten reservas.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Muestra si la variaci\u00f3n est\u00e1 reservada.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","context":["view","edit"]},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"ID de la clase de env\u00edo.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","context":["view","edit"],"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Lista de atributos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"description":"Si se ignora la papelera y se fuerza el borrado.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/products\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha de inicio del precio de oferta.","type":"string","required":false},"date_on_sale_to":{"description":"Fecha final del precio de oferta.","type":"string","required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"download_type":{"description":"Tipo de descarga, esto controla el esquema en la tienda.","type":"string","enum":["standard"],"required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"description":"Controla si el producto se muestra (o no) como \u00abhay existencias\u00bb o \u00abagotado\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"variations":{"description":"Lista de variaciones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la variaci\u00f3n.","type":"integer","context":["view","edit"],"readonly":true},"date_created":{"description":"La fecha en la que la variaci\u00f3n fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la variaci\u00f3n fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"permalink":{"description":"URL de la variaci\u00f3n.","type":"string","format":"uri","context":["view","edit"],"readonly":true},"sku":{"description":"Identificador \u00fanico.","type":"string","context":["view","edit"]},"price":{"description":"Precio actual de la variaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","context":["view","edit"]},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","context":["view","edit"]},"date_on_sale_from":{"description":"Fecha de inicio del precio de oferta.","type":"string","context":["view","edit"]},"date_on_sale_to":{"description":"Fecha final del precio de oferta.","type":"string","context":["view","edit"]},"on_sale":{"description":"Muestra si la variaci\u00f3n est\u00e1 rebajada.","type":"boolean","context":["view","edit"],"readonly":true},"purchasable":{"description":"Muestra si la variaci\u00f3n puede ser comprada.","type":"boolean","context":["view","edit"],"readonly":true},"visible":{"description":"Si es visible la variaci\u00f3n.","type":"boolean","context":["view","edit"]},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","default":false,"context":["view","edit"]},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","default":false,"context":["view","edit"]},"downloads":{"description":"Lista de archivos descargables.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}}},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","default":null,"context":["view","edit"]},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","default":null,"context":["view","edit"]},"tax_status":{"description":"Estado del impuesto.","type":"string","default":"taxable","enum":["taxable","shipping","none"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto.","type":"string","context":["view","edit"]},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"default":false,"context":["view","edit"]},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","context":["view","edit"]},"in_stock":{"description":"Controla si la variaci\u00f3n se muestra como \u00abhay existencias\u00bb o como \u00abagotada\u00bb en la tienda.","type":"boolean","default":true,"context":["view","edit"]},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","default":"no","enum":["no","notify","yes"],"context":["view","edit"]},"backorders_allowed":{"description":"Muestra si se permiten reservas.","type":"boolean","context":["view","edit"],"readonly":true},"backordered":{"description":"Muestra si la variaci\u00f3n est\u00e1 reservada.","type":"boolean","context":["view","edit"],"readonly":true},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","context":["view","edit"]},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","context":["view","edit"],"properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}}},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","context":["view","edit"]},"shipping_class_id":{"description":"ID de la clase de env\u00edo.","type":"integer","context":["view","edit"],"readonly":true},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","context":["view","edit"],"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"attributes":{"description":"Lista de atributos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}}}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/products\/batch"}]}},"\/wc\/v1\/reports\/sales":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Periodo del informe.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Devuelve las ventas para una fecha de inicio espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Devuelve las ventas para una fecha de fin espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/reports\/sales"}]}},"\/wc\/v1\/reports\/top_sellers":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Periodo del informe.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Devuelve las ventas para una fecha de inicio espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Devuelve las ventas para una fecha de fin espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/reports\/top_sellers"}]}},"\/wc\/v1\/reports":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/reports"}]}},"\/wc\/v1\/taxes\/classes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre de la clase de impuesto.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/taxes\/classes"}]}},"\/wc\/v1\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"slug":{"description":"Slug \u00fanico del recurso.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/taxes":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Ordenar por clase de impuesto.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"C\u00f3digo postal.","type":"string","required":false},"city":{"description":"Nombre de la ciudad.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"default":1,"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"default":false,"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"default":"standard","description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/taxes"}]}},"\/wc\/v1\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"C\u00f3digo postal.","type":"string","required":false},"city":{"description":"Nombre de la ciudad.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/taxes\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"C\u00f3digo postal.","type":"string","required":false},"city":{"description":"Nombre de la ciudad.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/taxes\/batch"}]}},"\/wc\/v1\/webhooks":{"namespace":"wc\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplaza el conjunto de resultados un n\u00famero espec\u00edfico de elementos. Tiene prioridad sobre el par\u00e1metro page.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limitar el conjunto de resultados a webhooks asignados a un estado espec\u00edfico.","type":"string","enum":["all","active","paused","disabled"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"default":"active","description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Tema del webhook.","required":true},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"delivery_url":{"type":"string","description":"URL de entrega del webhook.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/webhooks"}]}},"\/wc\/v1\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Tema del webhook.","type":"string","required":false},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/webhooks\/batch":{"namespace":"wc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Tema del webhook.","type":"string","required":false},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v1\/webhooks\/batch"}]}},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identificador \u00fanico del webhook.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v1\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identificador \u00fanico del webhook.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/coupons":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limitar los resultados a recursos con un c\u00f3digo espec\u00edfico.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":true},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/coupons"}]}},"\/wc\/v2\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/coupons\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/coupons\/batch"}]}},"\/wc\/v2\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/customers":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el resultado a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limitar resultados a recursos con un correo electr\u00f3nico determinado.","type":"string","format":"email","required":false},"role":{"description":"Limitar el conjunto de resultados a recursos con un perfil espec\u00edfico.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","give_manager","give_accountant","give_worker","give_donor","customer","shop_manager","wpseo_manager","wpseo_editor","wpc_client","wpc_client_staff","wpc_manager","wpc_admin"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Nueva direcci\u00f3n de correo electr\u00f3nico del usuario.","required":true},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nuevo nombre de usuario del usuario.","type":"string","required":false},"password":{"description":"Nueva contrase\u00f1a de usuario.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/customers"}]}},"\/wc\/v2\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico para el cliente.","type":"string","format":"email","required":false},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nombre de acceso del cliente.","type":"string","required":false},"password":{"description":"Contrase\u00f1a del cliente.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"reassign":{"default":0,"type":"integer","description":"ID al que reasignar las publicaciones.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/customers\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico para el cliente.","type":"string","format":"email","required":false},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nombre de acceso del cliente.","type":"string","required":false},"password":{"description":"Contrase\u00f1a del cliente.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/customers\/batch"}]}},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Limitar el resultado a notas de clientes o internas.","type":"string","enum":["any","customer","internal"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"note":{"type":"string","description":"Contenido de la nota del pedido.","required":true},"customer_note":{"default":false,"description":"Si es <em>true<\/em>, la nota se mostrar\u00e1 a los clientes y se les avisar\u00e1. Si es <em>false<\/em>, la nota solo ser\u00e1 de referencia para el administrador. ","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Mostrar solo los metadatos que deben aparecer en un pedido.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"amount":{"description":"Cantidad del reembolso.","type":"string","required":false},"reason":{"description":"Raz\u00f3n del reembolso.","type":"string","required":false},"refunded_by":{"description":"ID del usuario que cre\u00f3 el reembolso.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"Cuando sea <em>true<\/em>, la API de la pasarela de pago se utiliza para generar el reembolso.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/orders":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limitar resultados a pedidos con un estado determinado.","type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"customer":{"description":"Limitar resultados a pedidos de un cliente determinado.","type":"integer","required":false},"product":{"description":"Limitar resultados a pedidos asignados con un producto determinado.","type":"integer","required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Mostrar solo los metadatos que deben aparecer en un pedido.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"status":{"default":"pending","description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"USD","description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/orders"}]}},"\/wc\/v2\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/orders\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"]},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/orders\/batch"}]}},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/attributes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del recurso.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"default":"select","description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"default":"menu_order","description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/attributes"}]}},"\/wc\/v2\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/attributes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/attributes\/batch"}]}},"\/wc\/v2\/products\/categories":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"default":"default","description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/categories"}]}},"\/wc\/v2\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/categories\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"title":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/categories\/batch"}]}},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"review":{"type":"string","description":"Contenido de la valoraci\u00f3n.","required":true},"date_created":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, como GMT.","type":["null","string"],"required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"name":{"type":"string","description":"Nombre de quien dej\u00f3 la valoraci\u00f3n.","required":true},"email":{"type":"string","description":"Correo electr\u00f3nico de quien dej\u00f3 la valoraci\u00f3n.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"date_created":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, como GMT.","type":["null","string"],"required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"name":{"description":"Nombre de quien valora.","type":"string","required":false},"email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/reviews\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"date_created":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la valoraci\u00f3n, como GMT.","type":["null","string"],"required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"name":{"description":"Nombre de quien valora.","type":"string","required":false},"email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/shipping_classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/shipping_classes"}]}},"\/wc\/v2\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/shipping_classes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/shipping_classes\/batch"}]}},"\/wc\/v2\/products\/tags":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/tags"}]}},"\/wc\/v2\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la etiqueta.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/tags\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la etiqueta.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/tags\/batch"}]}},"\/wc\/v2\/products":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limita los resultados a productos asignados al ID de una marca espec\u00edfica.","type":"string","required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limita el resultado a productos con un atributo espec\u00edfico. Usa el slug del nombre\/atributo de la taxonom\u00eda.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limitar el resultado a productos con existencias o sin existencias.","type":"boolean","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"type":{"default":"simple","description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"default":false,"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha de finalizaci\u00f3n del precio rebajado, en GMT.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"default":true,"description":"Controla si el producto se muestra (o no) como \u00abhay existencias\u00bb o \u00abagotado\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"default":false,"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Permitir valoraciones.","type":"boolean","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Lista de IDs de productos agrupados.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha de finalizaci\u00f3n del precio rebajado, en GMT.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"description":"Controla si el producto se muestra (o no) como \u00abhay existencias\u00bb o \u00abagotado\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Lista de IDs de productos agrupados.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"description":"Si se ignora la papelera y se fuerza el borrado.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha de finalizaci\u00f3n del precio rebajado, en GMT.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"description":"Controla si el producto se muestra (o no) como \u00abhay existencias\u00bb o \u00abagotado\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","context":["view","edit"],"items":{"type":"string"}}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"grouped_products":{"description":"Lista de IDs de productos agrupados.","type":"array","items":{"type":"integer"},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/products\/batch"}]}},"\/wc\/v2\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limita el resultado a productos con un atributo espec\u00edfico. Usa el slug del nombre\/atributo de la taxonom\u00eda.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limitar el resultado a productos con existencias o sin existencias.","type":"boolean","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha de finalizaci\u00f3n del precio rebajado, en GMT.","type":["null","string"],"required":false},"visible":{"default":true,"description":"Define si la variaci\u00f3n es visible en la p\u00e1gina del producto.","type":"boolean","required":false},"virtual":{"default":false,"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"default":true,"description":"Controla si la variaci\u00f3n se muestra como \u00abhay existencias\u00bb o como \u00abagotada\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha de finalizaci\u00f3n del precio rebajado, en GMT.","type":["null","string"],"required":false},"visible":{"description":"Define si la variaci\u00f3n es visible en la p\u00e1gina del producto.","type":"boolean","required":false},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"description":"Controla si la variaci\u00f3n se muestra como \u00abhay existencias\u00bb o como \u00abagotada\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Identificador \u00fanico.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha de finalizaci\u00f3n del precio rebajado, en GMT.","type":["null","string"],"required":false},"visible":{"description":"Define si la variaci\u00f3n es visible en la p\u00e1gina del producto.","type":"boolean","required":false},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["null","object","string","number","boolean","integer","array"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"in_stock":{"description":"Controla si la variaci\u00f3n se muestra como \u00abhay existencias\u00bb o como \u00abagotada\u00bb en la tienda.","type":"boolean","required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n de la imagen. 0 significa que la imagen est\u00e1 destacada.","type":"integer","context":["view","edit"]}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/reports\/sales":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Periodo del informe.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Devuelve las ventas para una fecha de inicio espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Devuelve las ventas para una fecha de fin espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/reports\/sales"}]}},"\/wc\/v2\/reports\/top_sellers":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Periodo del informe.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Devuelve las ventas para una fecha de inicio espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Devuelve las ventas para una fecha de fin espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/reports\/top_sellers"}]}},"\/wc\/v2\/reports":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/reports"}]}},"\/wc\/v2\/settings":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/settings"}]}},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"value":{"description":"Valor del ajuste.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"value":{"description":"Valor del ajuste.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/shipping\/zones":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre de zona de env\u00edo.","required":true},"order":{"description":"Orden de zona de env\u00edo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/shipping\/zones"}]}},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de zona de env\u00edo.","type":"string","required":false},"order":{"description":"Orden de zona de env\u00edo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"code":{"description":"C\u00f3digo de ubicaci\u00f3n de la zona de env\u00edo.","type":"string","required":false},"type":{"description":"Tipo de ubicaci\u00f3n de la zona de env\u00edo.","type":"string","enum":["postcode","state","country","continent"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"order":{"description":"Orden de pedidos del m\u00e9todo de env\u00edo.","type":"integer","required":false},"enabled":{"description":"Estado de activaci\u00f3n del m\u00e9todo de env\u00edo.","type":"boolean","required":false},"settings":{"description":"Ajustes del m\u00e9todo de env\u00edo.","type":"object","properties":{"id":{"description":"Un identificador \u00fanico para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Una etiqueta legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Una descripci\u00f3n legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Tipo de ajuste.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valor del ajuste.","type":"string","context":["view","edit"]},"default":{"description":"Valor por defecto para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texto de ayuda adicional mostrado al usuario sobre el ajuste.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texto de muestra que se ver\u00e1 en los campos de introducci\u00f3n de texto.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"instance_id":{"description":"ID \u00fanico de la instancia.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"instance_id":{"description":"ID \u00fanico de la instancia.","type":"integer","required":false},"order":{"description":"Orden de pedidos del m\u00e9todo de env\u00edo.","type":"integer","required":false},"enabled":{"description":"Estado de activaci\u00f3n del m\u00e9todo de env\u00edo.","type":"boolean","required":false},"settings":{"description":"Ajustes del m\u00e9todo de env\u00edo.","type":"object","properties":{"id":{"description":"Un identificador \u00fanico para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Una etiqueta legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Una descripci\u00f3n legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Tipo de ajuste.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valor del ajuste.","type":"string","context":["view","edit"]},"default":{"description":"Valor por defecto para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texto de ayuda adicional mostrado al usuario sobre el ajuste.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texto de muestra que se ver\u00e1 en los campos de introducci\u00f3n de texto.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"instance_id":{"description":"ID \u00fanico de la instancia.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/taxes\/classes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre de la clase de impuesto.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/taxes\/classes"}]}},"\/wc\/v2\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Slug \u00fanico del recurso.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/taxes":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Ordenar por clase de impuesto.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"C\u00f3digo postal.","type":"string","required":false},"city":{"description":"Nombre de la ciudad.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"default":1,"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"default":false,"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"default":"standard","description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/taxes"}]}},"\/wc\/v2\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"C\u00f3digo postal.","type":"string","required":false},"city":{"description":"Nombre de la ciudad.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/taxes\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"C\u00f3digo postal.","type":"string","required":false},"city":{"description":"Nombre de la ciudad.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/taxes\/batch"}]}},"\/wc\/v2\/webhooks":{"namespace":"wc\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplaza el conjunto de resultados un n\u00famero espec\u00edfico de elementos. Tiene prioridad sobre el par\u00e1metro page.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limitar el conjunto de resultados a webhooks asignados a un estado espec\u00edfico.","type":"string","enum":["all","active","paused","disabled"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"default":"active","description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Tema del webhook.","required":true},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"delivery_url":{"type":"string","description":"URL de entrega del webhook.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/webhooks"}]}},"\/wc\/v2\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Tema del webhook.","type":"string","required":false},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/webhooks\/batch":{"namespace":"wc\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Tema del webhook.","type":"string","required":false},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/webhooks\/batch"}]}},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identificador \u00fanico del webhook.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/webhooks\/(?P<webhook_id>[\\d]+)\/deliveries\/(?P<id>[\\d]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"webhook_id":{"description":"Identificador \u00fanico del webhook.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/system_status":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/system_status"}]}},"\/wc\/v2\/system_status\/tools":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/system_status\/tools"}]}},"\/wc\/v2\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Un identificador \u00fanico para la herramienta.","type":"string","required":false},"name":{"description":"Nombre de la herramienta.","type":"string","required":false},"action":{"description":"Lo que har\u00e1 la herramienta en funcionamiento.","type":"string","required":false},"description":{"description":"Descripci\u00f3n de la herramienta.","type":"string","required":false},"success":{"description":"\u00bfSe ejecut\u00f3 correctamente la herramienta?","type":"boolean","required":false},"message":{"description":"Mensaje mostrado por la herramienta.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/shipping_methods":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/shipping_methods"}]}},"\/wc\/v2\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v2\/payment_gateways":{"namespace":"wc\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v2\/payment_gateways"}]}},"\/wc\/v2\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"title":{"description":"T\u00edtulo de la pasarela de pago en la p\u00e1gina de finalizar compra.","type":"string","required":false},"description":{"description":"Descripci\u00f3n de la pasarela de pago en la p\u00e1gina de finalizar compra.","type":"string","required":false},"order":{"description":"Orden de visualizaci\u00f3n de la pasarela de pago","type":"integer","required":false},"enabled":{"description":"Estado de activaci\u00f3n de la pasarela de pago.","type":"boolean","required":false},"settings":{"description":"Ajustes de la pasarela de pago.","type":"object","properties":{"id":{"description":"Un identificador \u00fanico para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Una etiqueta legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Una descripci\u00f3n legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Tipo de ajuste.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valor del ajuste.","type":"string","context":["view","edit"]},"default":{"description":"Valor por defecto para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texto de ayuda adicional mostrado al usuario sobre el ajuste.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texto de muestra que se ver\u00e1 en los campos de introducci\u00f3n de texto.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/coupons":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"code":{"description":"Limitar los resultados a recursos con un c\u00f3digo espec\u00edfico.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":true},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"default":"fixed_cart","description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"default":false,"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"default":false,"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"default":false,"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/coupons"}]}},"\/wc\/v3\/coupons\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/coupons\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"code":{"description":"C\u00f3digo del cup\u00f3n.","type":"string","required":false},"amount":{"description":"La cantidad de descuento. Siempre debe ser num\u00e9rico, aunque se defina un porcentaje.","type":["number","string"],"required":false},"status":{"description":"El estado del cup\u00f3n. Siempre debe ser borrador, publicado o pendiente de revisi\u00f3n","type":"string","required":false},"discount_type":{"description":"Determina el tipo de descuento que ser\u00e1 aplicado.","type":"string","enum":["percent","fixed_cart","fixed_product"],"required":false},"description":{"description":"Descripci\u00f3n del cup\u00f3n.","type":"string","required":false},"date_expires":{"description":"La fecha de caducidad del cup\u00f3n, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_expires_gmt":{"description":"La fecha de caducidad del cup\u00f3n, en GMT.","type":["null","string"],"required":false},"individual_use":{"description":"Si es <em>true<\/em> el cup\u00f3n solo se puede usar individualmente. El resto de cupones que se a\u00f1adan se borrar\u00e1n del carrito.","type":"boolean","required":false},"product_ids":{"description":"Lista de IDs de productos en los que se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_ids":{"description":"Lista de IDs de productos en los que no se puede utilizar el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"usage_limit":{"description":"Cu\u00e1ntas veces puede usarse en total el cup\u00f3n.","type":"integer","required":false},"usage_limit_per_user":{"description":"Cu\u00e1ntas veces puede usar el cup\u00f3n cada cliente.","type":"integer","required":false},"limit_usage_to_x_items":{"description":"N\u00famero m\u00e1ximo de art\u00edculos en el carrito en los que se puede aplicar el cup\u00f3n.","type":"integer","required":false},"free_shipping":{"description":"Si es <em>true<\/em> y el m\u00e9todo de env\u00edo gratuito requiere un cup\u00f3n este cup\u00f3n activar\u00e1 el env\u00edo gratuito.","type":"boolean","required":false},"product_categories":{"description":"Lista de IDs de categor\u00edas a los que se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"excluded_product_categories":{"description":"Lista de IDs de categor\u00edas a las que no se aplica el cup\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"exclude_sale_items":{"description":"Si es <em>true<\/em> este cup\u00f3n no se aplicar\u00e1 a los art\u00edculos que tengan precios rebajados.","type":"boolean","required":false},"minimum_amount":{"description":"Cantidad m\u00ednima de pedido que necesita estar en el carrito antes de que se aplique el cup\u00f3n.","type":["number","string"],"required":false},"maximum_amount":{"description":"Cantidad m\u00e1xima de pedido permitida cuando se utilice el cup\u00f3n.","type":["number","string"],"required":false},"email_restrictions":{"description":"Lista de direcciones de correo electr\u00f3nico que pueden utilizar este cup\u00f3n.","type":"array","items":{"type":"string"},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/coupons\/batch"}]}},"\/wc\/v3\/customers\/(?P<customer_id>[\\d]+)\/downloads":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"customer_id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/customers":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el resultado a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","include","name","registered_date"],"type":"string","required":false},"email":{"description":"Limitar resultados a recursos con un correo electr\u00f3nico determinado.","type":"string","format":"email","required":false},"role":{"description":"Limitar el conjunto de resultados a recursos con un perfil espec\u00edfico.","type":"string","default":"customer","enum":["all","administrator","editor","author","contributor","subscriber","give_manager","give_accountant","give_worker","give_donor","customer","shop_manager","wpseo_manager","wpseo_editor","wpc_client","wpc_client_staff","wpc_manager","wpc_admin"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"email":{"type":"string","description":"Nueva direcci\u00f3n de correo electr\u00f3nico del usuario.","required":true},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nuevo nombre de usuario del usuario.","type":"string","required":false},"password":{"description":"Nueva contrase\u00f1a de usuario.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/customers"}]}},"\/wc\/v3\/customers\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico para el cliente.","type":"string","format":"email","required":false},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nombre de acceso del cliente.","type":"string","required":false},"password":{"description":"Contrase\u00f1a del cliente.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"reassign":{"default":0,"type":"integer","description":"ID al que reasignar las publicaciones.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/customers\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico para el cliente.","type":"string","format":"email","required":false},"first_name":{"description":"Nombre del cliente.","type":"string","required":false},"last_name":{"description":"Apellidos del cliente.","type":"string","required":false},"username":{"description":"Nombre de acceso del cliente.","type":"string","required":false},"password":{"description":"Contrase\u00f1a del cliente.","type":"string","required":false},"billing":{"description":"Lista de los datos de la direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":"string","format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Lista de datos de direcciones de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo ISO del pa\u00eds.","type":"string","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/customers\/batch"}]}},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"type":{"default":"any","description":"Limitar el resultado a notas de clientes o internas.","type":"string","enum":["any","customer","internal"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"note":{"type":"string","description":"Contenido de la nota del pedido.","required":true},"customer_note":{"default":false,"description":"Si es <em>true<\/em>, la nota se mostrar\u00e1 a los clientes y se les avisar\u00e1. Si es <em>false<\/em>, la nota solo ser\u00e1 de referencia para el administrador. ","type":"boolean","required":false},"added_by_user":{"default":false,"description":"Si el valor es true esta nota se atribuir\u00e1 al usuario actual. -Si el valor es false la nota se atribuir\u00e1 al sistema.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/notes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Mostrar solo los metadatos que deben aparecer en un pedido.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"amount":{"description":"Cantidad del reembolso.","type":"string","required":false},"reason":{"description":"Raz\u00f3n del reembolso.","type":"string","required":false},"refunded_by":{"description":"ID del usuario que cre\u00f3 el reembolso.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"api_refund":{"default":true,"description":"Cuando sea <em>true<\/em>, la API de la pasarela de pago se utiliza para generar el reembolso.","type":"boolean","required":false},"api_restock":{"default":true,"description":"Si el valor es verdadero, se reponen los art\u00edculos reembolsados.","type":"boolean","required":false},"compute_totals":{"default":false,"description":"Cuando es verdadero, el servidor calcula los importes de reembolso por l\u00ednea a partir de las cantidades utilizando los precios e impuestos almacenados del pedido, validando la solicitud contra el historial de reembolsos del pedido. El valor predeterminado es falso, lo que preserva el comportamiento preexistente de este endpoint.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<order_id>[\\d]+)\/refunds\/preview":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"order_id":{"description":"El ID del pedido.","type":"integer","required":false},"line_items":{"description":"Partidas que se incluir\u00e1n en la vista previa del reembolso.","type":"array","minItems":1,"items":{"type":"object","required":["line_item_id"],"additionalProperties":false,"properties":{"line_item_id":{"description":"El ID original de la partida del pedido.","type":"integer","minimum":1},"quantity":{"description":"Cantidad por reembolsar. Obligatorio cuando se omite refund_total.","type":"integer","minimum":1},"refund_total":{"description":"Importe con impuestos incluidos para el reembolso de esta partida. Debe ser distinto de cero y coincidir con el signo de la l\u00ednea (negativo para las l\u00edneas de descuento o cr\u00e9dito, positivo en caso contrario). Obligatorio cuando se omite la cantidad.","type":["number","null"]}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"status":{"default":"any","description":"Limitar el resultado a los pedidos que tenga estados espec\u00edficos.","type":"array","items":{"type":"string","enum":["any","trash","auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"]},"required":false},"customer":{"description":"Limitar resultados a pedidos de un cliente determinado.","type":"integer","required":false},"product":{"description":"Limitar resultados a pedidos asignados con un producto determinado.","type":"integer","required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Mostrar solo los metadatos que deben aparecer en un pedido.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"created_via":{"description":"Limita el conjunto de resultados a los pedidos creados a trav\u00e9s de fuentes espec\u00edficas (por ejemplo, pago, administraci\u00f3n).","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"created_via":{"description":"Muestra d\u00f3nde fue creado el pedido.","type":"string","required":false},"status":{"default":"pending","description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"default":"USD","description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"default":0,"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"default":false,"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"manual_update":{"default":false,"description":"Define la acci\u00f3n como manual para que la nota del pedido se registre como \u00aba\u00f1adida por el usuario\u00bb.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/orders"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"created_via":{"description":"Muestra d\u00f3nde fue creado el pedido.","type":"string","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"manual_update":{"description":"Define la acci\u00f3n como manual para que la nota del pedido se registre como \u00aba\u00f1adida por el usuario\u00bb.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"parent_id":{"description":"ID del superior del pedido.","type":"integer","required":false},"created_via":{"description":"Muestra d\u00f3nde fue creado el pedido.","type":"string","required":false},"status":{"description":"Estado del pedido.","type":"string","enum":["auto-draft","pending","processing","on-hold","completed","cancelled","refunded","failed","checkout-draft"],"required":false},"currency":{"description":"Moneda en la que el pedido fue creado, en formato ISO.","type":"string","enum":["AED","AFN","ALL","AMD","ANG","AOA","ARS","AUD","AWG","AZN","BAM","BBD","BDT","BGN","BHD","BIF","BMD","BND","BOB","BRL","BSD","BTC","BTN","BWP","BYR","BYN","BZD","CAD","CDF","CHF","CHW","CLP","CNY","COP","CRC","CUC","CUP","CVE","CZK","DJF","DKK","DOP","DZD","EGP","ERN","ETB","EUR","FJD","FKP","GBP","GEL","GGP","GHS","GIP","GMD","GNF","GTQ","GYD","HKD","HNL","HRK","HTG","HUF","IDR","ILS","IMP","INR","IQD","IRR","IRT","ISK","JEP","JMD","JOD","JPY","KES","KGS","KHR","KMF","KPW","KRW","KWD","KYD","KZT","LAK","LBP","LKR","LRD","LSL","LYD","MAD","MDL","MGA","MKD","MMK","MNT","MOP","MRU","MUR","MVR","MWK","MXN","MYR","MZN","NAD","NGN","NIO","NOK","NPR","NZD","OMR","PAB","PEN","PGK","PHP","PKR","PLN","PRB","PYG","QAR","RON","RSD","RUB","RWF","SAR","SBD","SCR","SDG","SEK","SGD","SHP","SLL","SOS","SRD","SSP","STN","SYP","SZL","THB","TJS","TMT","TND","TOP","TRY","TTD","TWD","TZS","UAH","UGX","USD","UYU","UZS","VEF","VES","VND","VUV","WST","XAF","XCD","XOF","XPF","YER","ZAR","ZMW"],"required":false},"customer_id":{"description":"ID del usuario que ha hecho el pedido. 0 para invitados.","type":"integer","required":false},"customer_note":{"description":"Nota dejada por el cliente durante el pago.","type":"string","required":false},"billing":{"description":"Direcci\u00f3n de facturaci\u00f3n.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]},"email":{"description":"Correo electr\u00f3nico.","type":["string","null"],"format":"email","context":["view","edit"]},"phone":{"description":"N\u00famero de tel\u00e9fono.","type":"string","context":["view","edit"]}},"required":false},"shipping":{"description":"Direcci\u00f3n de env\u00edo.","type":"object","properties":{"first_name":{"description":"Nombre.","type":"string","context":["view","edit"]},"last_name":{"description":"Apellidos.","type":"string","context":["view","edit"]},"company":{"description":"Nombre de la empresa.","type":"string","context":["view","edit"]},"address_1":{"description":"Direcci\u00f3n, l\u00ednea 1","type":"string","context":["view","edit"]},"address_2":{"description":"Direcci\u00f3n, l\u00ednea 2","type":"string","context":["view","edit"]},"city":{"description":"Nombre de la ciudad.","type":"string","context":["view","edit"]},"state":{"description":"C\u00f3digo ISO o nombre del estado, provincia o distrito.","type":"string","context":["view","edit"]},"postcode":{"description":"C\u00f3digo postal.","type":"string","context":["view","edit"]},"country":{"description":"C\u00f3digo del pa\u00eds en formato ISO 3166-1 alpha-2.","type":"string","context":["view","edit"]}},"required":false},"payment_method":{"description":"ID del m\u00e9todo de pago.","type":"string","required":false},"payment_method_title":{"description":"T\u00edtulo del m\u00e9todo de pago.","type":"string","required":false},"transaction_id":{"description":"ID \u00fanico de la transacci\u00f3n.","type":"string","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"line_items":{"description":"Datos de los art\u00edculos de la l\u00ednea.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"parent_name":{"description":"Nombre del producto principal, si el producto es una variaci\u00f3n.","type":["string","null"],"context":["view","edit"]},"product_id":{"description":"ID del producto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"variation_id":{"description":"ID de la variaci\u00f3n, si es aplicable.","type":"integer","context":["view","edit"]},"quantity":{"description":"Cantidad pedida.","type":"integer","context":["view","edit"]},"tax_class":{"description":"Clase de impuesto del producto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal por l\u00ednea, sin impuestos (antes de descuentos).","type":"string","context":["view","edit"]},"subtotal_tax":{"description":"Subtotal de impuestos de la l\u00ednea (antes de descuentos).","type":"string","context":["view","edit"],"readonly":true},"total":{"description":"Total por l\u00ednea, sin impuestos (despu\u00e9s de descuentos).","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos de la l\u00ednea (despu\u00e9s de descuentos).","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"]},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"]},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"]}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"display_key":{"description":"Clave meta para la visualizaci\u00f3n de la interfaz.","type":"string","context":["view","edit"],"readonly":true},"display_value":{"description":"Valor meta para la visualizaci\u00f3n en la interfaz. Puede ser una cadena o, cuando refleja un valor meta complejo, un array u objeto.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"],"readonly":true}}}},"sku":{"description":"SKU del producto.","type":"string","context":["view","edit"],"readonly":true},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","context":["view","edit"],"readonly":true},"price":{"description":"Precio del producto.","type":"number","context":["view","edit"],"readonly":true},"image":{"description":"Propiedades de la imagen principal del producto.","type":"object","context":["view","edit"],"readonly":true,"properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]}}}}},"required":false},"shipping_lines":{"description":"Datos de las l\u00edneas de env\u00edo.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"method_title":{"description":"Nombre del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"instance_id":{"description":"ID de la instancia de env\u00edo.","type":"string","context":["view","edit"]},"total":{"description":"Total del env\u00edo, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Impuestos totales sobre el env\u00edo.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"fee_lines":{"description":"Datos de las l\u00edneas de cuota.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"name":{"description":"Nombre de la cuota.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"tax_class":{"description":"Clase de impuesto de la cuota.","type":"string","context":["view","edit"]},"tax_status":{"description":"Estado del impuesto de la cuota.","type":"string","context":["view","edit"],"enum":["taxable","none"]},"total":{"description":"Total de comisiones, sin impuestos.","type":"string","context":["view","edit"]},"total_tax":{"description":"Total de impuestos sobre la comisi\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"taxes":{"description":"Impuestos de la l\u00ednea.","type":"array","context":["view","edit"],"readonly":true,"items":{"type":"object","properties":{"id":{"description":"ID de la tasa de impuestos.","type":"integer","context":["view","edit"],"readonly":true},"total":{"description":"Total de impuesto.","type":"string","context":["view","edit"],"readonly":true},"subtotal":{"description":"Subtotal de impuestos.","type":"string","context":["view","edit"],"readonly":true}}}},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"coupon_lines":{"description":"Datos de las l\u00edneas de cupones.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del art\u00edculo.","type":"integer","context":["view","edit"],"readonly":true},"code":{"description":"C\u00f3digo del cup\u00f3n.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]},"discount":{"description":"Descuento total.","type":"string","context":["view","edit"],"readonly":true},"discount_tax":{"description":"Impuesto total del descuento.","type":"string","context":["view","edit"],"readonly":true},"discount_type":{"description":"Tipo de descuento.","type":"string","context":["view"],"readonly":true},"nominal_amount":{"description":"Importe del descuento que aparece en el cup\u00f3n (valor absoluto o un porcentaje, seg\u00fan el tipo de descuento).","type":"number","context":["view"],"readonly":true},"free_shipping":{"description":"Si el cup\u00f3n ofrece o no env\u00edo gratis.","type":"boolean","context":["view"],"readonly":true},"meta_data":{"description":"Metadatos.","type":"array","context":["view","edit"],"items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}}}},"required":false},"set_paid":{"description":"Definir si el pedido est\u00e1 pagado. Establecer\u00e1 el estado a procesando y reducir\u00e1 el inventario de los art\u00edculos.","type":"boolean","required":false},"manual_update":{"description":"Define la acci\u00f3n como manual para que la nota del pedido se registre como \u00aba\u00f1adida por el usuario\u00bb.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/orders\/batch"}]}},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/attributes\/(?P<attribute_id>[\\d]+)\/terms\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attribute_id":{"description":"Identificador \u00fanico del atributo de los t\u00e9rminos.","type":"integer","required":false},"name":{"description":"Nombre del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para aplicar un orden personalizado al recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/attributes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del recurso.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"default":"select","description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"default":"menu_order","description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"default":false,"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/attributes"}]}},"\/wc\/v3\/products\/attributes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":true,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/attributes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del atributo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"type":{"description":"Tipo de atributo.","type":"string","enum":["select","the7_echanced"],"required":false},"order_by":{"description":"Orden por defecto.","type":"string","enum":["menu_order","name","name_num","id"],"required":false},"has_archives":{"description":"Activar\/Desactivar los archivos de atributo.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/attributes\/batch"}]}},"\/wc\/v3\/products\/categories":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"default":"default","description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/categories"}]}},"\/wc\/v3\/products\/categories\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/categories\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la categor\u00eda.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"parent":{"description":"El ID para el superior del recurso.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"display":{"description":"Tipo de visualizaci\u00f3n del archivo de categor\u00eda.","type":"string","enum":["default","products","subcategories","both"],"required":false},"image":{"description":"Datos de la imagen.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/categories\/batch"}]}},"\/wc\/v3\/products\/custom-fields\/names":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"order":{"description":"Ordena los elementos de forma ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/custom-fields\/names"}]}},"\/wc\/v3\/products\/reviews":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a valoraciones publicadas antes de una fecha dada compatible con ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el resultado a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","product"],"required":false},"reviewer":{"description":"Limitar el resultado a las valoraciones asignadas a IDs de usuario espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"reviewer_exclude":{"description":"Asegura que el resultado establecido excluye las valoraciones asignadas a IDs de usuario espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"reviewer_email":{"default":null,"description":"Limita el resultado a los del correo electr\u00f3nico de un autor espec\u00edfico.","format":"email","type":"string","required":false},"product":{"default":[],"description":"Limita el resultado a valoraciones asignadas a IDs de producto espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approved","description":"Limita el resultado a las valoraciones asignadas a un estado espec\u00edfico.","type":"string","enum":["all","hold","approved","spam","trash"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto.","type":"integer","required":true},"product_name":{"description":"Nombre del producto.","type":"string","required":false},"status":{"default":"approved","description":"Estado de la valoraci\u00f3n.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"type":"string","description":"Nombre de quien dej\u00f3 la valoraci\u00f3n.","required":true},"reviewer_email":{"type":"string","description":"Correo electr\u00f3nico de quien dej\u00f3 la valoraci\u00f3n.","required":true},"review":{"type":"string","description":"Contenido de la valoraci\u00f3n.","required":true},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/reviews"}]}},"\/wc\/v3\/products\/reviews\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"product_id":{"description":"Identificador \u00fanico del producto al que pertenece la valoraci\u00f3n.","type":"integer","required":false},"product_name":{"description":"Nombre del producto.","type":"string","required":false},"status":{"description":"Estado de la valoraci\u00f3n.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nombre de quien valora.","type":"string","required":false},"reviewer_email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","format":"email","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/reviews\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto al que pertenece la valoraci\u00f3n.","type":"integer","required":false},"product_name":{"description":"Nombre del producto.","type":"string","required":false},"status":{"description":"Estado de la valoraci\u00f3n.","type":"string","enum":["approved","hold","spam","unspam","trash","untrash"],"required":false},"reviewer":{"description":"Nombre de quien valora.","type":"string","required":false},"reviewer_email":{"description":"Correo electr\u00f3nico de quien valora.","type":"string","format":"email","required":false},"review":{"description":"El contenido de la valoraci\u00f3n.","type":"string","required":false},"rating":{"description":"Puntuaci\u00f3n de la valoraci\u00f3n (de 0 a 5).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/reviews\/batch"}]}},"\/wc\/v3\/products\/shipping_classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/shipping_classes"}]}},"\/wc\/v3\/products\/shipping_classes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/shipping_classes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/shipping_classes\/batch"}]}},"\/wc\/v3\/products\/shipping_classes\/slug-suggestion":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nombre de la clase de env\u00edo.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/shipping_classes\/slug-suggestion"}]}},"\/wc\/v3\/products\/tags":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados en un n\u00famero espec\u00edfico de elementos. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo del recurso.","type":"string","default":"name","enum":["id","include","name","slug","term_group","description","count"],"required":false},"hide_empty":{"description":"Ocultar o no los recursos que no est\u00e9n asignados a ning\u00fan producto.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a los recursos asignados a un superior espec\u00edfico. Se aplica solo a taxonom\u00edas jer\u00e1rquicas.","type":"integer","required":false},"product":{"description":"Limitar los resultados a los recursos asignados a un producto espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a recursos con un slug determinado. ","type":["string","array"],"items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre del recurso.","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/tags"}]}},"\/wc\/v3\/products\/tags\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de la etiqueta.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/tags\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre de la etiqueta.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el recurso \u00fanico de su tipo.","type":"string","required":false},"description":{"description":"Descripci\u00f3n HTML del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/tags\/batch"}]}},"\/wc\/v3\/products":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order","price","popularity","rating"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limita los resultados a productos asignados al ID de una marca espec\u00edfica.","type":"string","required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limita el resultado a productos con un atributo espec\u00edfico. Usa el slug del nombre\/atributo de la taxonom\u00eda.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"search_sku":{"description":"Limita los resultados a aquellos con un SKU que coincida parcialmente con una cadena. Este argumento tiene prioridad sobre 'sku'.","type":"string","required":false},"search_name_or_sku":{"description":"Limita los resultados a los que tengan un nombre o SKU que coincidan parcialmente con una cadena. Este argumento tiene prioridad sobre 'search', 'sku' y 'search_sku'.","type":"string","required":false},"search_fields":{"description":"Limita la b\u00fasqueda a campos espec\u00edficos cuando se usa con un par\u00e1metro de b\u00fasqueda. Campos disponibles: name, sku, global_unique_id, description y short_description. Este argumento tiene prioridad sobre todos los dem\u00e1s par\u00e1metros de b\u00fasqueda.","type":"array","items":{"type":"string","enum":["name","global_unique_id","description","short_description","sku"]},"default":[],"required":false},"include_status":{"description":"Limitar el resultado a productos con cualquiera de los estados.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluir productos con cualquiera de los estados del conjunto de resultados.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"include_types":{"description":"Limitar el conjunto de resultados a los productos con cualquiera de los tipos.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"exclude_types":{"description":"Excluir productos con cualquiera de los tipos del conjunto de resultados.","type":"array","items":{"type":"string","enum":["simple","grouped","external","variable"]},"required":false},"downloadable":{"description":"Limitar el resultado a productos que se pueden descargar.","type":"boolean","required":false},"virtual":{"description":"Limitar el resultado a productos virtuales.","type":"boolean","required":false},"pos_products_only":{"description":"Limitar el resultado a los productos visibles en el punto de venta.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"default":"simple","description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"default":"publish","description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"default":false,"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"default":"visible","description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"default":false,"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"default":false,"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"default":true,"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"description":"Si se ignora la papelera y se fuerza el borrado.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/batch"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/related":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/suggested-products":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"brand":{"description":"Limita los resultados a productos asignados al ID de una marca espec\u00edfica.","type":"string","required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"type":{"description":"Limitar resultados a productos de un tipo determinado.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"featured":{"description":"Limitar el resultado a productos destacados.","type":"boolean","required":false},"category":{"description":"Limitar resultados a productos asignados al ID de una categor\u00eda espec\u00edfica.","type":"string","required":false},"tag":{"description":"Limitar resultados a productos asignados al ID de una etiqueta espec\u00edfica.","type":"string","required":false},"shipping_class":{"description":"Limitar resultados a productos asignados al ID de una clase de env\u00edo espec\u00edfica.","type":"string","required":false},"attribute":{"description":"Limita el resultado a productos con un atributo espec\u00edfico. Usa el slug del nombre\/atributo de la taxonom\u00eda.","type":"string","required":false},"attribute_term":{"description":"Limitar los resultados a productos con un ID de t\u00e9rmino de atributo espec\u00edfico (requiere un atributo asignado).","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"in_stock":{"description":"Limitar el resultado a productos con existencias o sin existencias.","type":"boolean","required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"categories":{"description":"Limita el resultado establecido a ID de categor\u00edas de productos espec\u00edficas.","type":"array","items":{"type":"integer"},"default":[],"required":false},"tags":{"description":"Limita el resultado establecido a ID de etiquetas de productos espec\u00edficas.","type":"array","items":{"type":"integer"},"default":[],"required":false},"limit":{"description":"Limita el resultado establecido a una cantidad espec\u00edfica de productos recomendados.","type":"integer","default":5,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/products\/suggested-products"}]}},"\/wc\/v3\/products\/(?P<id>[\\d]+)\/duplicate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre del producto.","type":"string","required":false},"slug":{"description":"Slug del producto.","type":"string","required":false},"date_created":{"description":"La fecha en la que el producto fue creado, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_created_gmt":{"description":"La fecha de creaci\u00f3n del producto, en GMT.","type":["null","string"],"required":false},"type":{"description":"Tipo de producto.","type":"string","enum":["simple","grouped","external","variable"],"required":false},"status":{"description":"Estado del producto (estado de la entrada).","type":"string","enum":["draft","pending","private","publish","future","auto-draft","trash"],"required":false},"featured":{"description":"Producto destacado.","type":"boolean","required":false},"catalog_visibility":{"description":"Visibilidad del cat\u00e1logo.","type":"string","enum":["visible","catalog","search","hidden"],"required":false},"description":{"description":"Descripci\u00f3n del producto.","type":"string","required":false},"short_description":{"description":"Descripci\u00f3n corta del producto.","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal del producto.","type":"string","required":false},"sale_price":{"description":"Precio de oferta del producto.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"virtual":{"description":"Si el producto es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si el producto es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"external_url":{"description":"URL externa del producto. Solo para productos externos.","type":"string","format":"uri","required":false},"button_text":{"description":"Texto del bot\u00f3n externo del producto. Solo para productos externos.","type":"string","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de producto.","type":"boolean","required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias del producto.","type":["integer","null"],"required":false},"sold_individually":{"description":"Permitir que un art\u00edculo sea comprado en un \u00fanico pedido.","type":"boolean","required":false},"weight":{"description":"Peso del producto (lbs)","type":"string","required":false},"dimensions":{"description":"Dimensiones del producto.","type":"object","properties":{"length":{"description":"Longitud del producto (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura del producto (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura del producto (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"reviews_allowed":{"description":"Permitir valoraciones.","type":"boolean","required":false},"post_password":{"description":"Contrase\u00f1a de la entrada.","type":"string","required":false},"upsell_ids":{"description":"Lista de IDs de productos de ventas dirigidas.","type":"array","items":{"type":"integer"},"required":false},"cross_sell_ids":{"description":"Lista de IDs de productos de ventas cruzadas.","type":"array","items":{"type":"integer"},"required":false},"parent_id":{"description":"ID del producto superior.","type":"integer","required":false},"purchase_note":{"description":"Nota opcional a enviar al cliente despu\u00e9s de la compra.","type":"string","required":false},"categories":{"description":"Lista de categor\u00edas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la categor\u00eda.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la categor\u00eda.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de categor\u00eda.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"brands":{"description":"Lista de marcas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de marca.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de marca.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de marca.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"tags":{"description":"Lista de etiquetas.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de etiqueta.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre de la etiqueta.","type":"string","context":["view","edit"],"readonly":true},"slug":{"description":"Slug de etiqueta.","type":"string","context":["view","edit"],"readonly":true}}},"required":false},"images":{"description":"Lista de im\u00e1genes.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"position":{"description":"Posici\u00f3n del atributo.","type":"integer","context":["view","edit"]},"visible":{"description":"Definir si el atributo es visible en la pesta\u00f1a de \u00abInformaci\u00f3n adicional\u00bb en la p\u00e1gina del producto.","type":"boolean","default":false,"context":["view","edit"]},"variation":{"description":"Definir si el atributo puede ser usado como variaci\u00f3n.","type":"boolean","default":false,"context":["view","edit"]},"options":{"description":"Lista de nombres de t\u00e9rmino del atributo disponibles.","type":"array","items":{"type":"string"},"context":["view","edit"]}}},"required":false},"default_attributes":{"description":"Atributos de la variaci\u00f3n por defecto.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios.","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras.","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122.","type":["string","null"],"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Usa un tama\u00f1o de imagen registrado espec\u00edfico para el src de la imagen de variaci\u00f3n devuelta. Vuelve al tama\u00f1o completo si el tama\u00f1o solicitado no est\u00e1 registrado.","type":"string","default":"full","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limita el conjunto de resultados a productos con o sin precio.","type":"boolean","required":false},"attributes":{"description":"Limitar resultados a productos con atributos espec\u00edficos.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Slug del atributo."},"term":{"type":"string","description":"T\u00e9rmino del atributo."},"terms":{"type":"array","description":"T\u00e9rminos del atributo."}}},"required":false},"virtual":{"description":"Limitar el resultado a variaciones de productos.","type":"boolean","required":false},"downloadable":{"description":"Limitar el resultado a las variaciones de productos que se pueden descargar.","type":"boolean","required":false},"include_status":{"description":"Limitar el resultado a las variaciones de productos con cualquiera de los estados.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluir variaciones de productos con cualquiera de los estados del conjunto de resultados.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limitar el resultado a las variaciones visibles en el punto de venta.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"image_size":{"description":"Tama\u00f1o de la imagen a devolver. Acepta cualquier tama\u00f1o de imagen de WordPress registrado.","type":"string","default":"full","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico de la variaci\u00f3n.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/products\/(?P<product_id>[\\d]+)\/variations\/generate":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product_id":{"description":"Identificador \u00fanico del producto variable.","type":"integer","required":false},"delete":{"description":"Borra las variaciones sin utilizar.","type":"boolean","required":false},"default_values":{"description":"Valores por defecto para las variaciones generadas.","type":"object","properties":{"description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Descripci\u00f3n de la variaci\u00f3n","type":"string"},"sku":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Unidad de salvaguarda de inventario.","type":"string"},"global_unique_id":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"GTIN, UPC, EAN o ISBN.","type":"string"},"regular_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Precio normal de la variaci\u00f3n.","type":"string"},"sale_price":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Precio rebajado de la variaci\u00f3n.","type":"string"},"date_on_sale_from":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"]},"date_on_sale_from_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"]},"date_on_sale_to":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"]},"date_on_sale_to_gmt":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"]},"status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"]},"virtual":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variaci\u00f3n es virtual.","type":"boolean"},"downloadable":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si la variaci\u00f3n es descargable.","type":"boolean"},"downloads":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}}},"download_limit":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer"},"download_expiry":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer"},"tax_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"]},"tax_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Clase de impuesto.","type":"string"},"manage_stock":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"]},"stock_quantity":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Cantidad de inventario.","type":"integer"},"stock_status":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"]},"backorders":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"]},"low_stock_amount":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"]},"weight":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Peso de la variaci\u00f3n (lbs).","type":"string"},"dimensions":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}}},"shipping_class":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Slug de la clase de env\u00edo.","type":"string"},"image":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}}},"gallery_image_ids":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1}},"attributes":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}}},"menu_order":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer"},"meta_data":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}}},"customs_commodity_code":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"]},"customs_country_of_origin":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"]},"customs_description":{"validate_callback":"rest_validate_request_arg","sanitize_callback":"rest_sanitize_request_arg","description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"]}},"required":false},"description":{"description":"Descripci\u00f3n de la variaci\u00f3n","type":"string","required":false},"sku":{"description":"Unidad de salvaguarda de inventario.","type":"string","required":false},"global_unique_id":{"description":"GTIN, UPC, EAN o ISBN.","type":"string","required":false},"regular_price":{"description":"Precio normal de la variaci\u00f3n.","type":"string","required":false},"sale_price":{"description":"Precio rebajado de la variaci\u00f3n.","type":"string","required":false},"date_on_sale_from":{"description":"Fecha del inicio del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_from_gmt":{"description":"Fecha del inicio del descuento en el precio, en GMT.","type":["null","string"],"required":false},"date_on_sale_to":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"date_on_sale_to_gmt":{"description":"Fecha del fin del descuento en el precio, en la zona horaria del sitio.","type":["null","string"],"required":false},"status":{"default":"publish","description":"Estado de la variaci\u00f3n.","type":"string","enum":["draft","pending","private","publish"],"required":false},"virtual":{"default":false,"description":"Si la variaci\u00f3n es virtual.","type":"boolean","required":false},"downloadable":{"default":false,"description":"Si la variaci\u00f3n es descargable.","type":"boolean","required":false},"downloads":{"description":"Lista de archivos descargables.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID de archivo.","type":"string","context":["view","edit"]},"name":{"description":"Nombre del archivo.","type":"string","context":["view","edit"]},"file":{"description":"URL del archivo.","type":"string","context":["view","edit"]}}},"required":false},"download_limit":{"default":-1,"description":"N\u00famero de veces que se pueden descargar los archivos descargables despu\u00e9s de la compra.","type":"integer","required":false},"download_expiry":{"default":-1,"description":"N\u00famero de d\u00edas hasta que caduca el acceso a los archivos descargables.","type":"integer","required":false},"tax_status":{"default":"taxable","description":"Estado del impuesto.","type":"string","enum":["taxable","shipping","none"],"required":false},"tax_class":{"description":"Clase de impuesto.","type":"string","required":false},"manage_stock":{"default":false,"description":"Gesti\u00f3n del inventario a nivel de las variaciones.","type":["boolean","string"],"required":false},"stock_quantity":{"description":"Cantidad de inventario.","type":"integer","required":false},"stock_status":{"default":"instock","description":"Controla el estado del inventario del producto.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"backorders":{"default":"no","description":"Si se gestiona el inventario, esto controla si se permiten reservas.","type":"string","enum":["no","notify","yes"],"required":false},"low_stock_amount":{"description":"Cantidad de pocas existencias de la variaci\u00f3n.","type":["integer","null"],"required":false},"weight":{"description":"Peso de la variaci\u00f3n (lbs).","type":"string","required":false},"dimensions":{"description":"Dimensiones de la variaci\u00f3n.","type":"object","properties":{"length":{"description":"Largo de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"width":{"description":"Anchura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]},"height":{"description":"Altura de la variaci\u00f3n (in).","type":"string","context":["view","edit"]}},"required":false},"shipping_class":{"description":"Slug de la clase de env\u00edo.","type":"string","required":false},"image":{"description":"Datos de la imagen de la variaci\u00f3n.","type":"object","properties":{"id":{"description":"ID de la imagen.","type":"integer","context":["view","edit"]},"date_created":{"description":"La fecha en la que la imagen fue creada, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_created_gmt":{"description":"La fecha de creaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified":{"description":"La fecha en la que la imagen fue modificada por \u00faltima vez, en la zona horaria del sitio.","type":["null","string"],"context":["view","edit"],"readonly":true},"date_modified_gmt":{"description":"La fecha de la \u00faltima modificaci\u00f3n de la imagen, en GMT.","type":["null","string"],"context":["view","edit"],"readonly":true},"src":{"description":"URL de la imagen.","type":"string","format":"uri","context":["view","edit"]},"name":{"description":"Nombre de la imagen.","type":"string","context":["view","edit"]},"alt":{"description":"Texto alternativo de la imagen.","type":"string","context":["view","edit"]}},"required":false},"gallery_image_ids":{"description":"ID de las im\u00e1genes de la galer\u00eda de variaciones, excluida la imagen destacada (que se establece mediante \u00abimage\u00bb). Refleja el funcionamiento de las galer\u00edas en los productos superiores.","type":"array","items":{"type":"integer","minimum":1},"required":false},"attributes":{"description":"Lista de atributos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del atributo.","type":"integer","context":["view","edit"]},"name":{"description":"Nombre del atributo.","type":"string","context":["view","edit"]},"option":{"description":"Nombre del t\u00e9rmino del atributo seleccionado.","type":"string","context":["view","edit"]}}},"required":false},"menu_order":{"description":"Orden en el men\u00fa, utilizado para ordenar los productos de manera personalizada.","type":"integer","required":false},"meta_data":{"description":"Metadatos.","type":"array","items":{"type":"object","properties":{"id":{"description":"ID del meta.","type":"integer","context":["view","edit"],"readonly":true},"key":{"description":"Clave meta.","type":"string","context":["view","edit"]},"value":{"description":"Valor meta.","type":["null","object","string","number","boolean","integer","array"],"context":["view","edit"]}}},"required":false},"customs_commodity_code":{"description":"C\u00f3digo de mercanc\u00eda de aduanas que contiene de 6 a 14 d\u00edgitos. Se eliminan la puntuaci\u00f3n y los espacios. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_country_of_origin":{"description":"C\u00f3digo de pa\u00eds de origen de dos letras. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"customs_description":{"description":"Descripci\u00f3n de aduanas en texto plano, de hasta 35 caracteres, sin emoji ni s\u00edmbolos especiales como \u2122. En el contexto de visualizaci\u00f3n, un valor vac\u00edo hereda el valor del principal; en el contexto de edici\u00f3n, solo se devuelve el valor almacenado (null cuando se hereda).","type":["string","null"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/refunds":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"dp":{"default":2,"description":"N\u00famero de puntos decimales a usar en cada recurso.","type":"integer","required":false},"order_item_display_meta":{"default":false,"description":"Mostrar solo los metadatos que deben aparecer en un pedido.","type":"boolean","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/refunds"}]}},"\/wc\/v3\/reports\/sales":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Periodo del informe.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Devuelve las ventas para una fecha de inicio espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Devuelve las ventas para una fecha de fin espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/sales"}]}},"\/wc\/v3\/reports\/top_sellers":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"period":{"description":"Periodo del informe.","type":"string","enum":["week","month","last_month","year"],"required":false},"date_min":{"description":"Devuelve las ventas para una fecha de inicio espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"date_max":{"description":"Devuelve las ventas para una fecha de fin espec\u00edfica, la fecha tiene que estar en formato YYYY-MM-DD.","type":"string","format":"date","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/top_sellers"}]}},"\/wc\/v3\/reports\/orders\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/orders\/totals"}]}},"\/wc\/v3\/reports\/products\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/products\/totals"}]}},"\/wc\/v3\/reports\/customers\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/customers\/totals"}]}},"\/wc\/v3\/reports\/coupons\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/coupons\/totals"}]}},"\/wc\/v3\/reports\/reviews\/totals":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports\/reviews\/totals"}]}},"\/wc\/v3\/reports":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/reports"}]}},"\/wc\/v3\/settings":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/settings"}]}},"\/wc\/v3\/settings\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/settings\/batch"}]}},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"value":{"description":"Valor del ajuste.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/settings\/(?P<group_id>[\\w-]+)\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"group":{"description":"ID de ajustes del grupo.","type":"string","required":false},"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"value":{"description":"Valor del ajuste.","type":["null","object","string","number","boolean","integer","array"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/shipping\/zones":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"type":"string","description":"Nombre de zona de env\u00edo.","required":true},"order":{"description":"Orden de zona de env\u00edo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/shipping\/zones"}]}},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Nombre de zona de env\u00edo.","type":"string","required":false},"order":{"description":"Orden de zona de env\u00edo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<id>[\\d]+)\/locations":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID \u00fanico del recurso.","type":"integer","required":false},"code":{"description":"C\u00f3digo de ubicaci\u00f3n de la zona de env\u00edo.","type":"string","required":false},"type":{"description":"Tipo de ubicaci\u00f3n de la zona de env\u00edo.","type":"string","enum":["postcode","state","country","continent"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"order":{"description":"Orden de pedidos del m\u00e9todo de env\u00edo.","type":"integer","required":false},"enabled":{"description":"Estado de activaci\u00f3n del m\u00e9todo de env\u00edo.","type":"boolean","required":false},"settings":{"description":"Ajustes del m\u00e9todo de env\u00edo.","type":"object","properties":{"id":{"description":"Un identificador \u00fanico para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Una etiqueta legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Una descripci\u00f3n legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Tipo de ajuste.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Valor del ajuste.","type":"string","context":["view","edit"]},"default":{"description":"Valor por defecto para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texto de ayuda adicional mostrado al usuario sobre el ajuste.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texto de muestra que se ver\u00e1 en los campos de introducci\u00f3n de texto.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"method_id":{"description":"ID del m\u00e9todo de env\u00edo.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/shipping\/zones\/(?P<zone_id>[\\d]+)\/methods\/(?P<instance_id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"instance_id":{"description":"ID \u00fanico de la instancia.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"instance_id":{"description":"ID \u00fanico de la instancia.","type":"integer","required":false},"order":{"description":"Orden de pedidos del m\u00e9todo de env\u00edo.","type":"integer","required":false},"enabled":{"description":"Estado de activaci\u00f3n del m\u00e9todo de env\u00edo.","type":"boolean","required":false},"settings":{"description":"Ajustes del m\u00e9todo de env\u00edo.","type":"object","properties":{"id":{"description":"Un identificador \u00fanico para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Una etiqueta legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Una descripci\u00f3n legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Tipo de ajuste.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox","class","order"],"readonly":true},"value":{"description":"Valor del ajuste.","type":"string","context":["view","edit"]},"default":{"description":"Valor por defecto para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texto de ayuda adicional mostrado al usuario sobre el ajuste.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texto de muestra que se ver\u00e1 en los campos de introducci\u00f3n de texto.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"zone_id":{"description":"ID \u00fanico de la zona.","type":"integer","required":false},"instance_id":{"description":"ID \u00fanico de la instancia.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Si se ignora la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/taxes\/classes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Nombre de la clase de impuesto.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/taxes\/classes"}]}},"\/wc\/v3\/taxes\/classes\/(?P<slug>\\w[\\w\\s\\-]*)":{"namespace":"wc\/v3","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"description":"Slug \u00fanico del recurso.","type":"string","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/taxes":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"order","description":"Ordenar la colecci\u00f3n por el atributo del objeto.","enum":["id","order","priority"],"type":"string","required":false},"class":{"description":"Ordenar por clase de impuesto.","enum":["standard","reduced-rate","zero-rate"],"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"\u00abC\u00f3digo postal\/ZIP\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abc\u00f3digopostal\u00bb.","type":"string","required":false},"city":{"description":"\u00abNombre de la ciudad\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abciudades\u00bb.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"default":1,"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"default":false,"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"default":true,"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"default":"standard","description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista de c\u00f3digos postales. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista de nombres de ciudades. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/taxes"}]}},"\/wc\/v3\/taxes\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"\u00abC\u00f3digo postal\/ZIP\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abc\u00f3digopostal\u00bb.","type":"string","required":false},"city":{"description":"\u00abNombre de la ciudad\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abciudades\u00bb.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista de c\u00f3digos postales. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista de nombres de ciudades. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/taxes\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"country":{"description":"C\u00f3digo ISO 3166 del pa\u00eds.","type":"string","required":false},"state":{"description":"C\u00f3digo del estado.","type":"string","required":false},"postcode":{"description":"\u00abC\u00f3digo postal\/ZIP\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abc\u00f3digopostal\u00bb.","type":"string","required":false},"city":{"description":"\u00abNombre de la ciudad\u00bb no es compatible con valores multiples. Quedar\u00e1 obsoleto a partir de la versi\u00f3n 5.3 de WooCommerce, en su lugar debe usarse \u00abciudades\u00bb.","type":"string","required":false},"rate":{"description":"Tasa de impuestos.","type":"string","required":false},"name":{"description":"Nombre de la tasa de impuestos.","type":"string","required":false},"priority":{"description":"Prioridad de impuestos.","type":"integer","required":false},"compound":{"description":"Si se trata o no de una tarifa compuesta.","type":"boolean","required":false},"shipping":{"description":"Si esta tasa de impuesto se aplica tambi\u00e9n al env\u00edo o no.","type":"boolean","required":false},"order":{"description":"Indica el orden que aparecer\u00e1 en las peticiones.","type":"integer","required":false},"class":{"description":"Clase de impuesto.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"postcodes":{"description":"Lista de c\u00f3digos postales. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"cities":{"description":"Lista de nombres de ciudades. Presentado en la versi\u00f3n 5.3 de WooCommerce.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/taxes\/batch"}]}},"\/wc\/v3\/variations":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita los resultados a lo indicado en la cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita la respuesta a recursos modificados despu\u00e9s de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita la respuesta a los recursos modificados antes de una fecha dada conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"dates_are_gmt":{"description":"Si se deben considerar las fechas GMT de las entradas al limitar la respuesta por la fecha de publicaci\u00f3n o modificaci\u00f3n.","type":"boolean","default":false,"required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Anular el resultado establecido por un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","title","slug","modified","menu_order"],"required":false},"parent":{"description":"Limita el resultado establecido a los que tengan IDs superiores particulares.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"slug":{"description":"Limitar resultados a productos con un slug determinado.","type":"string","required":false},"status":{"default":"any","description":"Limitar resultados a productos asignados con un estado determinado.","type":"string","enum":["any","future","trash","draft","pending","private","publish"],"required":false},"sku":{"description":"Limita el resultado a productos con SKU(s) espec\u00edfico(s). Utiliza comas para separarlos.","type":"string","required":false},"tax_class":{"description":"Limitar el resultado a productos con una clase de impuestos espec\u00edfica.","type":"string","enum":["standard","reduced-rate","zero-rate"],"required":false},"on_sale":{"description":"Limitar el resultado a productos en oferta.","type":"boolean","required":false},"min_price":{"description":"Limitar el resultado a productos basados en un precio m\u00ednimo.","type":"string","required":false},"max_price":{"description":"Limitar el resultado a productos basados en un precio m\u00e1ximo.","type":"string","required":false},"include_meta":{"default":[],"description":"Limita meta_data a claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"exclude_meta":{"default":[],"description":"Asegura que meta_data excluye claves espec\u00edficas.","type":"array","items":{"type":"string"},"required":false},"image_size":{"description":"Usa un tama\u00f1o de imagen registrado espec\u00edfico para el src de la imagen de variaci\u00f3n devuelta. Vuelve al tama\u00f1o completo si el tama\u00f1o solicitado no est\u00e1 registrado.","type":"string","default":"full","required":false},"stock_status":{"description":"Limitar el resultado a productos con un estado de inventario espec\u00edfico.","type":"string","enum":["instock","outofstock","onbackorder"],"required":false},"has_price":{"description":"Limita el conjunto de resultados a productos con o sin precio.","type":"boolean","required":false},"attributes":{"description":"Limitar resultados a productos con atributos espec\u00edficos.","type":"array","items":{"type":"object","properties":{"attribute":{"type":"string","description":"Slug del atributo."},"term":{"type":"string","description":"T\u00e9rmino del atributo."},"terms":{"type":"array","description":"T\u00e9rminos del atributo."}}},"required":false},"virtual":{"description":"Limitar el resultado a variaciones de productos.","type":"boolean","required":false},"downloadable":{"description":"Limitar el resultado a las variaciones de productos que se pueden descargar.","type":"boolean","required":false},"include_status":{"description":"Limitar el resultado a las variaciones de productos con cualquiera de los estados.","type":"array","items":{"type":"string","enum":["any","future","trash","draft","pending","private","publish"]},"required":false},"exclude_status":{"description":"Excluir variaciones de productos con cualquiera de los estados del conjunto de resultados.","type":"array","items":{"type":"string","enum":["future","trash","draft","pending","private","publish"]},"required":false},"pos_products_only":{"description":"Limitar el resultado a las variaciones visibles en el punto de venta.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/variations"}]}},"\/wc\/v3\/webhooks":{"namespace":"wc\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a los recursos publicados despu\u00e9s de una determinada fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a los recursos publicados antes de una fecha conforme con la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Aseg\u00farate de que el conjunto de resultados excluya IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita el resultado establecido a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplaza el conjunto de resultados un n\u00famero espec\u00edfico de elementos. Tiene prioridad sobre el par\u00e1metro page.","type":"integer","required":false},"order":{"description":"Orden de la clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","title"],"required":false},"status":{"default":"all","description":"Limitar el conjunto de resultados a webhooks asignados a un estado espec\u00edfico.","type":"string","enum":["all","active","paused","disabled"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"default":"active","description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"type":"string","description":"Tema del webhook.","required":true},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"delivery_url":{"type":"string","description":"URL de entrega del webhook.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/webhooks"}]}},"\/wc\/v3\/webhooks\/(?P<id>[\\d]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Tema del webhook.","type":"string","required":false},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"integer","required":false},"force":{"default":false,"type":"boolean","description":"Tiene que ser verdadero, ya que el recurso no soporta ser movido a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/webhooks\/batch":{"namespace":"wc\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Un nombre amigable para el webhook.","type":"string","required":false},"status":{"description":"Estado del webhook.","type":"string","enum":["active","paused","disabled"],"required":false},"topic":{"description":"Tema del webhook.","type":"string","required":false},"secret":{"description":"Clave secreta utilizada para crear un hash del webhook emitido y ofrecido en las cabeceras de respuesta. Por defecto es un hash MD5 del ID del usuario actual | nombre de usuario si no lo tuviese.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/webhooks\/batch"}]}},"\/wc\/v3\/system_status":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/system_status"}]}},"\/wc\/v3\/system_status\/tools":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/system_status\/tools"}]}},"\/wc\/v3\/system_status\/tools\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Un identificador \u00fanico para la herramienta.","type":"string","required":false},"name":{"description":"Nombre de la herramienta.","type":"string","required":false},"action":{"description":"Lo que har\u00e1 la herramienta en funcionamiento.","type":"string","required":false},"description":{"description":"Descripci\u00f3n de la herramienta.","type":"string","required":false},"success":{"description":"\u00bfSe ejecut\u00f3 correctamente la herramienta?","type":"boolean","required":false},"message":{"description":"Mensaje mostrado por la herramienta.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/shipping_methods":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/shipping_methods"}]}},"\/wc\/v3\/shipping_methods\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/payment_gateways":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/payment_gateways"}]}},"\/wc\/v3\/payment_gateways\/(?P<id>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico del recurso.","type":"string","required":false},"title":{"description":"T\u00edtulo de la pasarela de pago en la p\u00e1gina de finalizar compra.","type":"string","required":false},"description":{"description":"Descripci\u00f3n de la pasarela de pago en la p\u00e1gina de finalizar compra.","type":"string","required":false},"order":{"description":"Orden de visualizaci\u00f3n de la pasarela de pago","type":"integer","required":false},"enabled":{"description":"Estado de activaci\u00f3n de la pasarela de pago.","type":"boolean","required":false},"settings":{"description":"Ajustes de la pasarela de pago.","type":"object","properties":{"id":{"description":"Un identificador \u00fanico para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"label":{"description":"Una etiqueta legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"description":{"description":"Una descripci\u00f3n legible del ajuste utilizado en las interfaces.","type":"string","context":["view","edit"],"readonly":true},"type":{"description":"Tipo de ajuste.","type":"string","context":["view","edit"],"enum":["text","email","number","color","password","textarea","select","multiselect","radio","image_width","checkbox"],"readonly":true},"value":{"description":"Valor del ajuste.","type":"string","context":["view","edit"]},"default":{"description":"Valor por defecto para el ajuste.","type":"string","context":["view","edit"],"readonly":true},"tip":{"description":"Texto de ayuda adicional mostrado al usuario sobre el ajuste.","type":"string","context":["view","edit"],"readonly":true},"placeholder":{"description":"Texto de muestra que se ver\u00e1 en los campos de introducci\u00f3n de texto.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/data":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/data"}]}},"\/wc\/v3\/data\/continents":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/data\/continents"}]}},"\/wc\/v3\/data\/continents\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"continent":{"description":"C\u00f3digo de 2 caracteres del continente.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/data\/countries":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/data\/countries"}]}},"\/wc\/v3\/data\/countries\/(?P<location>[\\w-]+)":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/data\/currencies":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/data\/currencies"}]}},"\/wc\/v3\/data\/currencies\/current":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/data\/currencies\/current"}]}},"\/wc\/v3\/data\/currencies\/(?P<currency>[\\w-]{3})":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"C\u00f3digo de moneda ISO4217.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/paypal-standard\/update-shipping":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/paypal-standard\/update-shipping"}]}},"\/wc\/v3\/paypal-webhooks":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/paypal-webhooks"}]}},"\/wc\/v3\/paypal-buttons\/create-order":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/paypal-buttons\/create-order"}]}},"\/wc\/v3\/paypal-buttons\/cancel-payment":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/paypal-buttons\/cancel-payment"}]}},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/receipt":{"namespace":"wc\/v3","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico del pedido.","type":"integer","required":false},"expiration_date":{"description":"Fecha de caducidad con formato aaaa-mm-dd.","type":"string","default":null,"required":false},"expiration_days":{"description":"N\u00famero de d\u00edas que hay que a\u00f1adir a la fecha actual para obtener la fecha de caducidad.","type":"integer","default":1,"required":false},"force_new":{"description":"Verdadero para forzar la creaci\u00f3n de un nuevo recibo aunque ya exista uno y a\u00fan no haya caducado.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del pedido.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/email_templates":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del pedido.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_email":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico del pedido.","type":"integer","required":false},"email":{"description":"Direcci\u00f3n de correo electr\u00f3nico a la que enviar los detalles del pedido.","type":"string","format":"email","required":false},"force_email_update":{"description":"Si se actualiza el correo electr\u00f3nico de facturaci\u00f3n del pedido, aunque ya haya uno.","type":"boolean","required":false},"template_id":{"description":"La plantilla de correo electr\u00f3nico que se utilizar\u00e1. Si se omite, la mejor plantilla se selecciona autom\u00e1ticamente en funci\u00f3n del estado del pedido.","type":"string","enum":["new_order","cancelled_order","customer_cancelled_order","failed_order","customer_failed_order","customer_on_hold_order","customer_processing_order","customer_completed_order","customer_refunded_order","customer_invoice","customer_note","customer_reset_password","customer_new_account","admin_payment_gateway_enabled","customer_pos_completed_order","customer_pos_refunded_order","customer_verify_email"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/(?P<id>[\\d]+)\/actions\/send_order_details":{"namespace":"wc\/v3","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico del pedido.","type":"integer","required":false},"email":{"description":"Direcci\u00f3n de correo electr\u00f3nico a la que enviar los detalles del pedido.","type":"string","format":"email","required":false},"force_email_update":{"description":"Si se actualiza el correo electr\u00f3nico de facturaci\u00f3n del pedido, aunque ya haya uno.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc\/v3\/orders\/statuses":{"namespace":"wc\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc\/v3\/orders\/statuses"}]}},"\/wc-admin\/settings\/payments\/country":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"location":{"description":"El c\u00f3digo de pa\u00eds ISO3166 alfa-2 que se guardar\u00e1 para el usuario actual.","type":"string","pattern":"[a-zA-Z]{2}","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/country"}]}},"\/wc-admin\/settings\/payments\/providers":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, utiliza el pa\u00eds de la ubicaci\u00f3n principal de WooCommerce.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/providers"}]}},"\/wc-admin\/settings\/payments\/providers\/order":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"order_map":{"description":"Una asignaci\u00f3n de ID de proveedor a valores enteros que representan el orden de clasificaci\u00f3n.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/providers\/order"}]}},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/attach":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<id>[\\w\\d\\-]+)\/hide":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/suggestion\/(?P<suggestion_id>[\\w\\d\\-]+)\/incentive\/(?P<incentive_id>[\\w\\d\\-]+)\/dismiss":{"namespace":"wc-admin","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"El ID de contexto para el que excluir el incentivo. Si no se proporciona, se excluir\u00e1 el incentivo para todos los contextos.","type":"string","required":false},"do_not_track":{"description":"Si es verdadero, el rechazo del incentivo ser\u00e1 ignorado por el seguimiento.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/start":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/save":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/check":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/(?P<step>[a-zA-Z0-9_-]+)\/clean":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/init"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/test_account\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/kyc_session\/finish"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Desde qu\u00e9 punto del flujo de incorporaci\u00f3n se ha activado esta solicitud.","type":"string","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/step\/business_verification\/test_account\/disable"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/preload"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Desde qu\u00e9 punto del flujo de incorporaci\u00f3n se ha activado esta solicitud.","type":"string","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/reset"}]}},"\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/woopay-eligibility"}]}},"\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"location":{"description":"C\u00f3digo de pa\u00eds ISO3166 alpha-2. Por defecto, es el c\u00f3digo de pa\u00eds de la ubicaci\u00f3n de la empresa de los proveedores guardados.","type":"string","pattern":"[a-zA-Z]{2}","required":false},"from":{"description":"Desde qu\u00e9 punto del flujo de incorporaci\u00f3n se ha activado esta solicitud.","type":"string","required":false},"source":{"description":"El punto de entrada m\u00e1s avanzado desde el que el vendedor entr\u00f3 en el flujo de incorporaci\u00f3n.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/settings\/payments\/woopayments\/onboarding\/test_account\/disable"}]}},"\/wc-admin-email":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-admin-email","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin-email"}]}},"\/wc-admin-email\/settings\/email\/send-preview":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"El tipo de correo electr\u00f3nico que se va a previsualizar.","type":"string","required":true},"email":{"description":"Direcci\u00f3n de correo electr\u00f3nico a la que enviar la vista previa del correo electr\u00f3nico.","type":"string","format":"email","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin-email\/settings\/email\/send-preview"}]}},"\/wc-admin-email\/settings\/email\/preview-subject":{"namespace":"wc-admin-email","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"El tipo de correo electr\u00f3nico del que se obtendr\u00e1 el asunto.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin-email\/settings\/email\/preview-subject"}]}},"\/wc-admin-email\/settings\/email\/save-transient":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"type":"string","description":"The key for the transient. Must be one of the allowed options.","required":true},"value":{"type":"string","description":"The value to be saved for the transient.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin-email\/settings\/email\/save-transient"}]}},"\/wc-admin-email\/settings\/email\/listing\/recreate-email-post":{"namespace":"wc-admin-email","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email_id":{"description":"El ID de correo electr\u00f3nico para el que recrear la entrada.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin-email\/settings\/email\/listing\/recreate-email-post"}]}},"\/wc-push-notifications":{"namespace":"wc-push-notifications","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-push-notifications","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-push-notifications"}]}},"\/wc-push-notifications\/status":{"namespace":"wc-push-notifications","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-push-notifications\/status"}]}},"\/wc-push-notifications\/push-tokens":{"namespace":"wc-push-notifications","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de art\u00edculos a devolver en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"user_id":{"description":"Limita los resultados a los tokens que pertenecen a este usuario.","type":"integer","minimum":1,"required":false},"device_uuid":{"description":"Limita los resultados a los tokens registrados por este dispositivo.","type":"string","maxLength":255,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"origin":{"description":"Origen","type":"string","enum":["browser","com.woocommerce.android","com.woocommerce.android:dev","com.automattic.woocommerce","com.automattic.woocommerce:dev"],"required":true},"device_uuid":{"description":"UUID del dispositivo","default":"","type":"string","required":false},"device_locale":{"description":"Configuraci\u00f3n regional del dispositivo","type":"string","required":true},"platform":{"description":"Plataforma","type":"string","enum":["apple","android","browser"],"required":true},"token":{"description":"Haz push del token","type":"string","required":true},"metadata":{"description":"Metadatos","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-push-notifications\/push-tokens"}]}},"\/wc-push-notifications\/push-tokens\/(?P<id>[\\d]+)":{"namespace":"wc-push-notifications","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"description":"ID del token push","type":"integer","minimum":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-push-notifications\/step-logs\/site":{"namespace":"wc-push-notifications","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"limit":{"description":"Filas que devolver, de la m\u00e1s reciente a la m\u00e1s antigua. Una p\u00e1gina incluye todas las filas de su \u00faltimo segundo, as\u00ed que puede superar esta cantidad.","type":"integer","default":100,"minimum":1,"maximum":500,"required":false},"from":{"description":"Marca de tiempo Unix m\u00e1s antigua que incluir. Por defecto, 48 horas antes de `to`, y se limita a 90 d\u00edas antes.","type":"integer","minimum":0,"required":false},"to":{"description":"Marca de tiempo Unix m\u00e1s reciente que incluir. Por defecto, ahora.","type":"integer","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-push-notifications\/step-logs\/site"}]}},"\/wc-push-notifications\/step-logs\/notifications\/(?P<type>[a-z_]+)\/(?P<resource_id>\\d+)":{"namespace":"wc-push-notifications","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","enum":["store_order","store_review","store_stock"],"required":true},"resource_id":{"type":"integer","minimum":1,"required":true},"limit":{"description":"Filas que devolver, de la m\u00e1s reciente a la m\u00e1s antigua. Una p\u00e1gina incluye todas las filas de su \u00faltimo segundo, as\u00ed que puede superar esta cantidad.","type":"integer","default":100,"minimum":1,"maximum":500,"required":false},"from":{"description":"Marca de tiempo Unix m\u00e1s antigua que incluir. Por defecto, 48 horas antes de `to`, y se limita a 90 d\u00edas antes.","type":"integer","minimum":0,"required":false},"to":{"description":"Marca de tiempo Unix m\u00e1s reciente que incluir. Por defecto, ahora.","type":"integer","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-push-notifications\/step-logs\/tokens\/(?P<token_id>\\d+)":{"namespace":"wc-push-notifications","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"token_id":{"type":"integer","minimum":1,"required":true},"limit":{"description":"Filas que devolver, de la m\u00e1s reciente a la m\u00e1s antigua. Una p\u00e1gina incluye todas las filas de su \u00faltimo segundo, as\u00ed que puede superar esta cantidad.","type":"integer","default":100,"minimum":1,"maximum":500,"required":false},"from":{"description":"Marca de tiempo Unix m\u00e1s antigua que incluir. Por defecto, 48 horas antes de `to`, y se limita a 90 d\u00edas antes.","type":"integer","minimum":0,"required":false},"to":{"description":"Marca de tiempo Unix m\u00e1s reciente que incluir. Por defecto, ahora.","type":"integer","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-push-notifications\/step-logs\/users\/(?P<user_id>\\d+)":{"namespace":"wc-push-notifications","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"type":"integer","minimum":1,"required":true},"limit":{"description":"Filas que devolver, de la m\u00e1s reciente a la m\u00e1s antigua. Una p\u00e1gina incluye todas las filas de su \u00faltimo segundo, as\u00ed que puede superar esta cantidad.","type":"integer","default":100,"minimum":1,"maximum":500,"required":false},"from":{"description":"Marca de tiempo Unix m\u00e1s antigua que incluir. Por defecto, 48 horas antes de `to`, y se limita a 90 d\u00edas antes.","type":"integer","minimum":0,"required":false},"to":{"description":"Marca de tiempo Unix m\u00e1s reciente que incluir. Por defecto, ahora.","type":"integer","minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wc-push-notifications\/preferences":{"namespace":"wc-push-notifications","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"store_order":{"description":"Preferencias para el tipo de aviso instant\u00e1neo store_order.","type":"object","properties":{"enabled":{"type":"boolean","description":"Indica si este tipo de aviso est\u00e1 activado."},"min_amount":{"type":["number","null"],"minimum":0,"exclusiveMinimum":true,"description":"Cantidad m\u00ednima de pedido necesaria para activar este aviso, o valor nulo para desactivar el umbral."}},"required":false},"store_review":{"description":"Preferencias para el tipo de aviso instant\u00e1neo store_review.","type":"object","properties":{"enabled":{"type":"boolean","description":"Indica si este tipo de aviso est\u00e1 activado."},"max_rating":{"type":["integer","null"],"minimum":1,"maximum":5,"description":"Puntuaci\u00f3n m\u00e1xima de estrellas que activa un aviso de valoraci\u00f3n (1-5), o valor nulo para desactivar el umbral."}},"required":false},"store_stock":{"description":"Preferencias para el tipo de aviso instant\u00e1neo store_stock.","type":"object","properties":{"enabled":{"type":"boolean","description":"Indica si este tipo de aviso est\u00e1 activado."},"low_stock":{"type":"boolean","description":"Indica si los avisos low_stock est\u00e1n activados para este tipo."},"out_of_stock":{"type":"boolean","description":"Indica si los avisos out_of_stock est\u00e1n activados para este tipo."},"on_backorder":{"type":"boolean","description":"Indica si los avisos on_backorder est\u00e1n activados para este tipo."}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-push-notifications\/preferences"}]}},"\/wc-telemetry":{"namespace":"wc-telemetry","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wc-telemetry","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-telemetry"}]}},"\/wc-telemetry\/tracker":{"namespace":"wc-telemetry","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"platform":{"description":"Plataforma a realizar seguimiento.","type":"string","required":true},"version":{"description":"Versi\u00f3n de plataforma a realizar seguimiento.","type":"string","required":true},"installation_date":{"description":"Fecha de instalaci\u00f3n de la aplicaci\u00f3n m\u00f3vil WooCommerce.","type":"string","format":"date-time","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-telemetry\/tracker"}]}},"\/wccom-site\/v3":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wccom-site\/v3","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3"}]}},"\/wccom-site\/v3\/installer\/(?P<product_id>\\d+)\/state":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"product_id":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wccom-site\/v3\/installer":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"run-until-step":{"type":"string","enum":["get_product_info","download_product","unpack_product","move_product","activate_product"],"required":true},"idempotency-key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3\/installer"}]}},"\/wccom-site\/v3\/installer\/reset":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"product-id":{"type":"integer","required":true},"idempotency-key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3\/installer\/reset"}]}},"\/wccom-site\/v3\/ssr":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3\/ssr"}]}},"\/wccom-site\/v3\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3\/status"}]}},"\/wccom-site\/v3\/connection\/disconnect":{"namespace":"wccom-site\/v3","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3\/connection\/disconnect"}]}},"\/wccom-site\/v3\/connection\/status":{"namespace":"wccom-site\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wccom-site\/v3\/connection\/status"}]}},"\/wc-push-notifications\/send":{"namespace":"wc-push-notifications","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-push-notifications\/send"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/wc-admin\/marketplace-promotions\/dismiss":{"namespace":"wc-admin","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wc-admin\/marketplace-promotions\/dismiss"}]}},"\/nps-survey\/v1":{"namespace":"nps-survey\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nps-survey\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/nps-survey\/v1"}]}},"\/nps-survey\/v1\/rating":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/nps-survey\/v1\/rating"}]}},"\/nps-survey\/v1\/dismiss-nps-survey":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/nps-survey\/v1\/dismiss-nps-survey"}]}},"\/wpcom\/v2":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2"}]}},"\/wpcom\/v2\/videopress\/meta":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El id de la entrada del adjunto.","type":"integer","required":true},"title":{"description":"El t\u00edtulo del v\u00eddeo.","type":"string","required":false},"description":{"description":"La descripci\u00f3n del v\u00eddeo.","type":"string","required":false},"caption":{"description":"La descripci\u00f3n del v\u00eddeo.","type":"string","required":false},"rating":{"description":"La valoraci\u00f3n del contenido del v\u00eddeo. Entre G, PG-13 o R-17","type":"string","required":false},"display_embed":{"description":"Muestra el men\u00fa de compartir en el reproductor.","type":"boolean","required":false},"allow_download":{"description":"Muestra la opci\u00f3n \u00abDescargar\u00bb y permite a los espectadores descargar este v\u00eddeo.","type":"boolean","required":false},"privacy_setting":{"description":"C\u00f3mo determinar si el v\u00eddeo deber\u00eda ser p\u00fablico o privado","type":"integer","enum":[0,1,2],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/videopress\/meta"}]}},"\/wpcom\/v2\/videopress\/(?P<video_guid>[A-Za-z0-9]{8})\/poster":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"video_guid":{"description":"GUID de VideoPress.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"video_guid":{"description":"GUID de VideoPress.","type":"string","required":true},"at_time":{"description":"Tiempo del v\u00eddeo para usarlo como fotograma de p\u00f3ster.","type":"integer","required":false},"is_millisec":{"description":"Ya sea el tiempo en milisegundos o segundos.","type":"boolean","required":false},"poster_attachment_id":{"description":"ID de adjunto de la imagen de p\u00f3ster.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/videopress\/(?P<video_guid>[A-Za-z0-9]{8})\/check-ownership\/(?P<post_id>\\d+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"video_guid":{"description":"GUID de VideoPress.","type":"string","required":true},"post_id":{"description":"El id de la entrada del adjunto.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/videopress\/upload-jwt":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/videopress\/upload-jwt"}]}},"\/wpcom\/v2\/videopress\/playback-jwt\/(?P<video_guid>[A-Za-z0-9]{8})":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"video_guid":{"description":"GUID de VideoPress.","type":"string","required":true},"post_id":{"description":"La entrada en la que est\u00e1 incrustado el v\u00eddeo, utilizada para autorizar el acceso.","type":"integer","required":false},"subscription_plan_id":{"description":"El plan de suscripci\u00f3n que utiliza el bloque de contenido premium que restringe el v\u00eddeo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/videopress\/settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"videopress_videos_private_for_site":{"description":"Si los v\u00eddeos de VideoPress deber\u00edan aparecer en privado por defecto","type":"boolean","required":false},"videopress_auto_subtitles_disabled":{"description":"Si hay que omitir los subt\u00edtulos generados autom\u00e1ticamente en los v\u00eddeos nuevos","type":"boolean","required":false},"videopress_player_preload_disabled":{"description":"Indica si los reproductores incrustados deben esperar a la reproducci\u00f3n antes de precargar los datos del v\u00eddeo","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/videopress\/settings"}]}},"\/wpcom\/v2\/videopress\/promote\/(?P<attachment_id>\\d+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attachment_id":{"description":"El ID del archivo adjunto del v\u00eddeo que se va a promocionar.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/videopress\/caption-tracks":{"namespace":"wpcom\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"guid":{"description":"GUID de VideoPress.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"guid":{"description":"GUID de VideoPress.","type":"string","required":false},"title":{"description":"T\u00edtulo de la pista de subt\u00edtulos.","type":"string","required":false},"content":{"description":"Contenido del bloque de marcas de subt\u00edtulos serializado.","type":"string","required":false},"status":{"description":"Estado de la pista de subt\u00edtulos.","type":"string","enum":["draft","publish"],"required":false},"meta":{"description":"Metadatos de la pista de subt\u00edtulos.","type":"object","properties":{"_videopress_guid":{"type":"string"},"_videopress_caption_kind":{"type":"string"},"_videopress_caption_src_lang":{"type":"string"},"_videopress_caption_label":{"type":"string"},"_videopress_source_track_kind":{"type":"string"},"_videopress_source_track_src_lang":{"type":"string"},"_videopress_source_track_src":{"type":"string"}},"additionalProperties":false,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/videopress\/caption-tracks"}]}},"\/wpcom\/v2\/videopress\/caption-tracks\/(?P<id>\\d+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID de la pista de subt\u00edtulos.","type":"integer","required":true},"guid":{"description":"GUID de VideoPress.","type":"string","required":false},"title":{"description":"T\u00edtulo de la pista de subt\u00edtulos.","type":"string","required":false},"content":{"description":"Contenido del bloque de marcas de subt\u00edtulos serializado.","type":"string","required":false},"status":{"description":"Estado de la pista de subt\u00edtulos.","type":"string","enum":["draft","publish"],"required":false},"meta":{"description":"Metadatos de la pista de subt\u00edtulos.","type":"object","properties":{"_videopress_guid":{"type":"string"},"_videopress_caption_kind":{"type":"string"},"_videopress_caption_src_lang":{"type":"string"},"_videopress_caption_label":{"type":"string"},"_videopress_source_track_kind":{"type":"string"},"_videopress_source_track_src_lang":{"type":"string"},"_videopress_source_track_src":{"type":"string"}},"additionalProperties":false,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID de la pista de subt\u00edtulos.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/jetpack\/v4\/stats\/blog":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/stats\/blog"}]}},"\/jetpack-boost\/v1":{"namespace":"jetpack-boost\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack-boost\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack-boost\/v1"}]}},"\/jetpack-boost\/v1\/speed-scores":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack-boost\/v1\/speed-scores"}]}},"\/jetpack-boost\/v1\/speed-scores\/refresh":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack-boost\/v1\/speed-scores\/refresh"}]}},"\/jetpack-boost\/v1\/speed-scores-history":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack-boost\/v1\/speed-scores-history"}]}},"\/my-jetpack\/v1":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"my-jetpack\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1"}]}},"\/my-jetpack\/v1\/site\/products":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"products":{"description":"Lista separada por comas de slugs de productos que deben obtenerse.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/products"}]}},"\/my-jetpack\/v1\/site\/products\/install":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Array de slugs de productos","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/products\/install"}]}},"\/my-jetpack\/v1\/site\/products\/activate":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Array de slugs de productos","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/products\/activate"}]}},"\/my-jetpack\/v1\/site\/products\/interstitials":{"namespace":"my-jetpack\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Pares clave-valor de slugs de productos y los estados de sus intersticiales.","type":"object","properties":{"anti-spam":{"type":"boolean"},"backup":{"type":"boolean"},"boost":{"type":"boolean"},"crm":{"type":"boolean"},"creator":{"type":"boolean"},"extras":{"type":"boolean"},"jetpack-ai":{"type":"boolean"},"ai":{"type":"boolean"},"scan":{"type":"boolean"},"search":{"type":"boolean"},"social":{"type":"boolean"},"security":{"type":"boolean"},"protect":{"type":"boolean"},"videopress":{"type":"boolean"},"stats":{"type":"boolean"},"growth":{"type":"boolean"},"complete":{"type":"boolean"},"newsletter":{"type":"boolean"},"site-accelerator":{"type":"boolean"},"related-posts":{"type":"boolean"},"jetpack-forms":{"type":"boolean"}},"additionalProperties":false,"minProperties":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/products\/interstitials"}]}},"\/my-jetpack\/v1\/site\/products\/deactivate":{"namespace":"my-jetpack\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"products":{"description":"Array de slugs de productos","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/products\/deactivate"}]}},"\/my-jetpack\/v1\/site\/products-ownership":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/products-ownership"}]}},"\/my-jetpack\/v1\/site\/purchases":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/purchases"}]}},"\/my-jetpack\/v1\/chat\/availability":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/chat\/availability"}]}},"\/my-jetpack\/v1\/chat\/authentication":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"test_mode":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/chat\/authentication"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"goals":{"description":"Lista de objetivos seleccionados por el usuario.","type":"array","items":{"type":"string"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"recommendations":{"description":"Slugs de m\u00f3dulos recomendados asignados a su puntuaci\u00f3n de evaluaci\u00f3n.","type":"object","additionalProperties":{"type":"number"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"showWelcomeBanner":{"description":"Indica si el aviso de bienvenida debe mostrarse de nuevo.","type":"string","enum":["true","false"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result"}]}},"\/my-jetpack\/v1\/site\/backup\/undo-event":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/backup\/undo-event"}]}},"\/my-jetpack\/v1\/site\/protect\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/protect\/data"}]}},"\/my-jetpack\/v1\/site\/videopress\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/videopress\/data"}]}},"\/my-jetpack\/v1\/site\/update-historically-active-modules":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/update-historically-active-modules"}]}},"\/my-jetpack\/v1\/jetpack-manage\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/jetpack-manage\/data"}]}},"\/my-jetpack\/v1\/jetpack-manage\/dismiss-banner":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/jetpack-manage\/dismiss-banner"}]}},"\/my-jetpack\/v1\/red-bubble-notifications":{"namespace":"my-jetpack\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dismissal_cookies":{"type":"array","description":"Array of dismissal cookies to set for the red bubble notifications.","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/red-bubble-notifications"}]}},"\/my-jetpack\/v1\/site":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site"}]}},"\/my-jetpack\/v1\/site\/dismiss-welcome-banner":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/my-jetpack\/v1\/site\/dismiss-welcome-banner"}]}},"\/jetpack\/v4\/explat":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/explat","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/explat"}]}},"\/jetpack\/v4\/explat\/assignments":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"experiment_name":{"type":"string","required":false},"anon_id":{"type":"string","required":false},"as_connected_user":{"type":"boolean","required":false},"platform":{"type":"string","enum":["jetpack","calypso","wpcom"],"default":"jetpack","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/explat\/assignments"}]}},"\/wpcom\/v2\/business-hours\/localized-week":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/business-hours\/localized-week"}]}},"\/wpcom\/v2\/admin-bar":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/admin-bar"}]}},"\/wpcom\/v2\/admin-color":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/admin-color"}]}},"\/wpcom\/v2\/admin-menu":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/admin-menu"}]}},"\/wpcom\/v2\/jetpack-ai\/feature-settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"master_enabled":{"type":"boolean","required":false},"features":{"type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/jetpack-ai\/feature-settings"}]}},"\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature"}]}},"\/wpcom\/v2\/app-media":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"N\u00famero de elementos multimedia en la solicitud","type":"number","default":20,"required":false},"page_handle":{"type":"number","default":1,"required":false},"after":{"description":"Marca de tiempo desde que el medio se subi\u00f3","type":"number","default":0,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/app-media"}]}},"\/wpcom\/v2\/application-password-extras\/abilities":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/application-password-extras\/abilities"}]}},"\/wpcom\/v2\/application-password-extras\/admin-ajax":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/application-password-extras\/admin-ajax"}]}},"\/wpcom\/v2\/editor-assets":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"exclude":{"description":"Lista separada por comas de tipos de activos a excluir de la respuesta. Valores compatibles: \"core\" (activos principales de WordPress), \"gutenberg\" (activos de plugins de Gutenberg) o prefijos de gesti\u00f3n de plugins (por ejemplo, \"contact-form-7\").","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/editor-assets"}]}},"\/wpcom\/v2\/blog-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"description":"ID de la entrada de la que obtener estad\u00edsticas.","type":["string","integer"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/blog-stats"}]}},"\/wpcom\/v2\/email-editor-bootstrap":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"template_slug":{"description":"Slug de la plantilla de correo electr\u00f3nico que se va a abrir en el editor.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"design":{"description":"El documento de dise\u00f1o de correo electr\u00f3nico que se va a almacenar.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/email-editor-bootstrap"}]}},"\/wpcom\/v2\/email-preview":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"access":{"description":"Acceder al nivel.","enum":["everybody","subscribers","paid_subscribers"],"default":"everybody","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/email-preview"}]}},"\/wpcom\/v2\/external-media\/list\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"description":"T\u00e9rmino de b\u00fasqueda de la recopilaci\u00f3n de elementos multimedia","type":"string","required":false},"number":{"description":"N\u00famero de elementos multimedia en la solicitud","type":"number","default":20,"required":false},"path":{"type":"string","required":false},"page_handle":{"type":"string","required":false},"session_id":{"description":"ID de sesi\u00f3n de un servicio; por el momento, solo para el selector de Google Fotos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/copy\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"media":{"description":"Datos multimedia que copiar.","items":{"type":"array","items":{"type":"object","required":true,"properties":{"caption":{"type":"string"},"guid":{"type":"object","properties":{"caption":{"type":"string"},"name":{"type":"string"},"title":{"type":"string"},"url":{"format":"uri","type":"string"}}},"title":{"type":"string"},"meta":{"type":"object","additionalProperties":false,"properties":{"vertical_id":{"type":"string","format":"text-field"},"pexels_object":{"type":"object"}}}}}},"type":"array","required":true},"post_id":{"description":"El ID de la entrada para adjuntar la subida.","type":"number","minimum":0,"required":false},"should_proxy":{"description":"Indica si la solicitud de medios debe realizarse mediante proxy.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)\/picker_status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)\/(?P<session_id>.*)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/external-media\/proxy\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"url":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/following\/mine":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ignore_user_blogs":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/following\/mine"}]}},"\/wpcom\/v2\/following\/recommendations":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"type":"number","default":5,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/following\/recommendations"}]}},"\/wpcom\/v2\/goodreads\/user-id":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de usuario de Goodreads","type":"integer","minimum":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/goodreads\/user-id"}]}},"\/wpcom\/v2\/checkGoogleDocVisibility":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/checkGoogleDocVisibility"}]}},"\/wpcom\/v2\/instagram-gallery\/connect-url":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/instagram-gallery\/connect-url"}]}},"\/wpcom\/v2\/instagram-gallery\/connections":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/instagram-gallery\/connections"}]}},"\/wpcom\/v2\/instagram-gallery\/gallery":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"access_token":{"description":"Un token de acceso al llavero de Instagram.","type":"integer","minimum":1,"required":true},"count":{"description":"\u00bfCu\u00e1ntas publicaciones de Instagram?","type":"integer","minimum":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/instagram-gallery\/gallery"}]}},"\/wpcom\/v2\/mailchimp":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/mailchimp"}]}},"\/wpcom\/v2\/mailchimp\/groups":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/mailchimp\/groups"}]}},"\/wpcom\/v2\/mailchimp\/settings":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/mailchimp\/settings"}]}},"\/wpcom\/v2\/jetpack-ai\/mcp-settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"mcp_abilities":{"type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/jetpack-ai\/mcp-settings"}]}},"\/wpcom\/v2\/newsletter-categories":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/newsletter-categories"}]}},"\/wpcom\/v2\/newsletter-categories\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term_ids":{"default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/newsletter-categories\/count"}]}},"\/wpcom\/v2\/newsletter-categories\/subscriptions\/(?P<subscription_id>[0-9]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"required":true},"type":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/newsletter-email-sent-status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/newsletter-email-sent-status"}]}},"\/wpcom\/v2\/podcast-player":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del feed RSS del podcast.","type":"string","required":true},"guids":{"description":"Una lista de identificadores \u00fanicos para recuperar episodios espec\u00edficos del podcast.","type":"array","required":true},"episode-options":{"description":"Si deber\u00edamos mostrar la lista de episodios para su uso en la IU de la selecci\u00f3n","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/podcast-player"}]}},"\/wpcom\/v2\/podcast-player\/track-quantity":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/podcast-player\/track-quantity"}]}},"\/wpcom\/v2\/profile":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/profile"}]}},"\/wpcom\/v2\/related-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/related-posts"}]}},"\/wpcom\/v2\/related-posts\/enable":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/related-posts\/enable"}]}},"\/wpcom\/v2\/related-posts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/resolve-redirect\/?(?P<url>.+)?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL en la que comprobar redirecciones.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/search":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/search"}]}},"\/wpcom\/v2\/send-email-preview":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"email":{"description":"Direcci\u00f3n del destinatario opcional. Por defecto es el usuario actual. Solo se acepta una direcci\u00f3n diferente de usuarios que puedan a\u00f1adir suscriptores y est\u00e1 sujeta a los mismos controles contra el abuso.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/send-email-preview"}]}},"\/wpcom\/v2\/subscribers\/add":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"emails":{"type":"array","items":{"type":"string"},"required":true},"categories":{"type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/add"}]}},"\/wpcom\/v2\/subscribers\/remove":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"integer","default":0,"minimum":0,"required":false},"email_subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"paid_subscription_ids":{"type":"array","items":{"type":"string"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/remove"}]}},"\/wpcom\/v2\/subscribers\/individual":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"user_id":{"type":"integer","default":0,"minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/individual"}]}},"\/wpcom\/v2\/subscribers\/individual-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"user_id":{"type":"integer","default":0,"minimum":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/individual-stats"}]}},"\/wpcom\/v2\/subscribers\/import":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/import"}]}},"\/wpcom\/v2\/subscribers\/import\/reset-state":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/import\/reset-state"}]}},"\/wpcom\/v2\/subscribers\/totals":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/totals"}]}},"\/wpcom\/v2\/subscribers\/list":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"sort":{"type":"string","default":"date_subscribed","enum":["date_subscribed","name","plan","subscription_status"],"required":false},"sort_order":{"type":"string","default":"desc","enum":["asc","desc"],"required":false},"search":{"type":"string","default":"","required":false},"filters":{"type":"array","items":{"type":"string"},"default":["all"],"required":false},"use_new_helper":{"type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/list"}]}},"\/wpcom\/v2\/subscribers\/products":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/products"}]}},"\/wpcom\/v2\/subscribers\/comp":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"integer","minimum":1,"required":true},"plan_id":{"type":"integer","minimum":1,"required":true},"no_expiration":{"type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/comp"}]}},"\/wpcom\/v2\/subscribers\/remove-comp":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"comp_id":{"type":"integer","minimum":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/remove-comp"}]}},"\/wpcom\/v2\/template-loader\/(?P<template_type>\\w+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"template_type":{"description":"El tipo de plantilla.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/post-types":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/post-types"}]}},"\/wpcom\/v2\/top-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"period":{"description":"Plazo para las estad\u00edsticas.","type":["string","integer"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/top-posts"}]}},"\/wpcom\/v2\/transients\/(?P<name>\\w{1,172})":{"namespace":"wpcom\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"name":{"description":"El nombre del dato transitorio a borrar.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v3":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v3","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v3"}]}},"\/wpcom\/v3\/blogging-prompts":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"after":{"description":"Mostrar sugerencias a continuaci\u00f3n de una fecha concreta.","type":"string","required":false},"before":{"description":"Mostrar sugerencias antes de una fecha concreta.","type":"string","required":false},"force_year":{"description":"Haz que las sugerencias que se muestran correspondan a un a\u00f1o concreto. Solo muestra una sugerencia para cada d\u00eda.","type":"integer","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v3\/blogging-prompts"}]}},"\/wpcom\/v3\/blogging-prompts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico de la sugerencia.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v3\/jitm":{"namespace":"wpcom\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"message_path":{"type":"string","description":"La ruta del mensaje para obtener JITM para","required":true},"query":{"type":"string","description":"Par\u00e1metros de consulta adicionales","required":false},"full_jp_logo_exists":{"type":"boolean","description":"Si existe el logotipo completo de Jetpack","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"type":"string","description":"El ID del JITM que se va a descartar","required":true},"feature_class":{"type":"string","description":"La clase de funci\u00f3n del JITM","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v3\/jitm"}]}},"\/wpcom\/v2\/gutenberg\/available-extensions":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/gutenberg\/available-extensions"}]}},"\/wpcom\/v2\/hello":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/hello"}]}},"\/wpcom\/v2\/memberships\/status\/?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"source":{"type":"string","required":false},"is_editable":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/memberships\/status"}]}},"\/wpcom\/v2\/memberships\/product\/?":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"title":{"type":"string","required":true},"price":{"type":"number","required":true},"currency":{"type":"string","required":true},"interval":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"buyer_can_change_amount":{"type":"boolean","required":false},"tier":{"type":"integer","required":false},"description":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/memberships\/product"}]}},"\/wpcom\/v2\/memberships\/products\/?":{"namespace":"wpcom\/v2","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"currency":{"type":"string","required":true},"type":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/memberships\/products"}]}},"\/wpcom\/v2\/memberships\/product\/(?P<product_id>[0-9]+)\/?":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"title":{"type":"string","required":true},"price":{"type":"number","required":true},"currency":{"type":"string","required":true},"interval":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"buyer_can_change_amount":{"type":"boolean","required":false},"tier":{"type":"integer","required":false},"description":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"cancel_subscriptions":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/publicize\/connection-test-results":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/publicize\/connection-test-results"}]}},"\/wpcom\/v2\/service-api-keys\/(?P<service>[a-z\\-_]+)":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"service_api_key":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wpcom\/v2\/subscribers\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/count"}]}},"\/wpcom\/v2\/subscribers\/counts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wpcom\/v2\/subscribers\/counts"}]}},"\/jetpack\/v4\/verify_registration":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/verify_registration"}]}},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/site":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/site"}]}},"\/jetpack\/v4\/connection\/test":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/test"}]}},"\/jetpack\/v4\/connection\/test-wpcom":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/test-wpcom"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"Al definirlo como \u00abfalse\u00bb, el sitio se desconectar\u00e1.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Indica d\u00f3nde se activ\u00f3 la acci\u00f3n de registro para fines de seguimiento o segmentaci\u00f3n","type":"string","required":false},"redirect_uri":{"description":"URI de la p\u00e1gina de administraci\u00f3n a la que se debe redirigir al usuario despu\u00e9s del proceso de conexi\u00f3n","type":"string","required":false},"plugin_slug":{"description":"Indica de qu\u00e9 plugin proviene la solicitud","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI de la p\u00e1gina de administraci\u00f3n a la que se debe redirigir al usuario despu\u00e9s del proceso de conexi\u00f3n","type":"string","required":false},"from":{"description":"Identificador de seguimiento\/segmentaci\u00f3n de esta solicitud de autorizaci\u00f3n de URL","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"Nuevo token de usuario","type":"string","required":true},"is_connection_owner":{"description":"Es propietario de la conexi\u00f3n","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"Nuevo propietario","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limitar el conjunto de resultados a elementos que sean fijos.","type":"boolean","required":false},"ignore_sticky":{"description":"Ignorar (o no) las entradas fijas.","type":"boolean","default":true,"required":false},"format":{"description":"Limita el conjunto de resultados a los elementos asignados a uno o varios formatos dados.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limitar los resultados a entradas con un valor espec\u00edfico `menu_order`.","type":"integer","required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"media_type":{"default":null,"description":"Limitar el conjunto de resultados a adjuntos de un tipo o tipos de medio en particular.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limitar el conjunto de resultados a adjuntos de un tipo o tipos MIME en particular.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"smush":{"description":"Datos de la reducci\u00f3n.","type":"string","required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Si se generan subtama\u00f1os de imagen.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Si se convierten formatos de imagen.","required":false},"url":{"type":"string","format":"uri","description":"URL de una imagen externa para cargar lateralmente en la biblioteca de medios, en lugar de subir un archivo.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"smush":{"description":"Datos de la reducci\u00f3n.","type":"string","required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para el adjunto.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL al archivo de la imagen editada.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array de las ediciones de la imagen.","type":"array","minItems":1,"items":{"description":"Edici\u00f3n de im\u00e1genes.","type":"object","required":["type","args"],"oneOf":[{"title":"Voltear","properties":{"type":{"description":"Tipo de volteo.","type":"string","enum":["flip"]},"args":{"description":"Argumentos del volteo.","type":"object","required":["flip"],"properties":{"flip":{"description":"Direcci\u00f3n de volteo.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Si se debe voltear en direcci\u00f3n horizontal.","type":"boolean"},"vertical":{"description":"Si se debe voltear en direcci\u00f3n vertical.","type":"boolean"}}}}}}},{"title":"Rotaci\u00f3n","properties":{"type":{"description":"Tipo de rotaci\u00f3n.","type":"string","enum":["rotate"]},"args":{"description":"Argumentos de rotaci\u00f3n.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u00c1ngulo a rotar en el sentido de las agujas del reloj en grados.","type":"number"}}}}},{"title":"Recortar","properties":{"type":{"description":"Tipo de recorte.","type":"string","enum":["crop"]},"args":{"description":"Argumentos de recorte.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posici\u00f3n horizontal desde la izquierda para iniciar el recorte como un porcentaje del ancho de la imagen.","type":"number"},"top":{"description":"Posici\u00f3n vertical desde la parte superior para iniciar el recorte como un porcentaje de la altura de la imagen.","type":"number"},"width":{"description":"Ancho del recorte como un porcentaje del ancho de la imagen.","type":"number"},"height":{"description":"Altura del recorte como un porcentaje de la altura de la imagen.","type":"number"}}}}}]},"required":false},"rotation":{"description":"La cantidad a girar la imagen en el sentido de las agujas del reloj en grados. OBSOLETO: Usa `modifiers` en su lugar.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Como un porcentaje de la imagen, la posici\u00f3n del eje X desde la que iniciar el recorte. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Como un porcentaje de la imagen, la posici\u00f3n del eje Y desde la que iniciar el recorte. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Como un porcentaje de la imagen, el ancho al que recortar la imagen. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Como un porcentaje de la imagen, la altura a la que recortar la imagen. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limitar los resultados a entradas con un valor espec\u00edfico `menu_order`.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"parent":{"default":0,"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"default":1,"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \u00abcategor\u00eda\u00bb, \u00abentrada\u00bb o \u00abadjunto\u00bb.","type":"string","required":false},"object_id":{"default":0,"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"parent":{"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \u00abcategor\u00eda\u00bb, \u00abentrada\u00bb o \u00abadjunto\u00bb.","type":"string","required":false},"object_id":{"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \u00abcategor\u00eda\u00bb, \u00abentrada\u00bb o \u00abadjunto\u00bb.","type":"string","required":false},"object_id":{"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar al ID de entrada especificado.","type":"integer","required":false},"area":{"description":"Limitar al \u00e1rea de la parte especificada de la plantilla.","type":"string","required":false},"post_type":{"description":"Tipo de contenido para el que obtener las plantillas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"default":"","description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"default":"publish","description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"El slug de la plantilla para conseguir una alternativa","type":"string","required":true},"is_custom":{"description":"Indica si es una plantilla personalizada o forma parte de la jerarqu\u00eda de plantillas","type":"boolean","required":false},"template_prefix":{"description":"El prefijo de la plantilla para la plantilla creada. Se usa para extraer el tipo de plantilla principal, p. ej. en `taxonomia-libros` extrae `taxonomia`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar al ID de entrada especificado.","type":"integer","required":false},"area":{"description":"Limitar al \u00e1rea de la parte especificada de la plantilla.","type":"string","required":false},"post_type":{"description":"Tipo de contenido para el que obtener las plantillas.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"default":"","description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"default":"publish","description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"El slug de la plantilla para conseguir una alternativa","type":"string","required":true},"is_custom":{"description":"Indica si es una plantilla personalizada o forma parte de la jerarqu\u00eda de plantillas","type":"boolean","required":false},"template_prefix":{"description":"El prefijo de la plantilla para la plantilla creada. Se usa para extraer el tipo de plantilla principal, p. ej. en `taxonomia-libros` extrae `taxonomia`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n de estilos globales.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n de estilos globales.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"El identificador del tema","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"El identificador del tema","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID de la configuraci\u00f3n de estilos globales.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Estilos globales.","type":["object"],"required":false},"settings":{"description":"Ajustes globales.","type":["object"],"required":false},"title":{"description":"T\u00edtulo de la variaci\u00f3n de estilos globales.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la variaci\u00f3n de estilos globales, tal y como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Declaraci\u00f3n font-family en formato theme.json, codificada como cadena.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Declaraci\u00f3n font-family en formato theme.json, codificada como cadena.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Declaraci\u00f3n font-face en formato theme.json, codificada como cadena.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para el font face.","type":"integer","required":true},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para el font face.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/clientspage":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/clientspage"}]}},"\/wp\/v2\/clientspage\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/clientspage\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/clientspage\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/clientspage\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/clientspage\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/portalhub":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/portalhub"}]}},"\/wp\/v2\/portalhub\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/portalhub\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/portalhub\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/portalhub\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/portalhub\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","popularity","rating","post__in","price","sales","menu_order","random","popularity","rating"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"product_brand":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda product_brand.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_brand_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda product_brand.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_cat":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda product_cat.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_cat_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda product_cat.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"product_tag":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda product_tag.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_tag_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda product_tag.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"brand":{"description":"Limita los resultados a productos asignados al ID de una marca espec\u00edfica.","type":"string","required":false},"wpf_price":{"description":"Product Filter price range \"min-max\".","type":"string","required":false},"wpf_stock":{"description":"Product Filter stock: in, out or backorder.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"product_brand":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_tag.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/product"}]}},"\/wp\/v2\/product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"product_brand":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_tag.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/product\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"product_brand":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_brand.","type":"array","items":{"type":"integer"},"required":false},"product_cat":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_cat.","type":"array","items":{"type":"integer"},"required":false},"product_tag":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda product_tag.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/product\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/feedback":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita el resultado establecido a todos los art\u00edculos excepto a los que tengan un ID superior particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"source":{"description":"Limitar el conjunto de resultados a los comentarios enviados desde un ID de entrada de origen determinado.","type":"integer","required":false},"is_unread":{"description":"Limitar el conjunto de resultados a elementos de comentarios le\u00eddos o no le\u00eddos.","type":"boolean","required":false},"is_test":{"description":"Limita el conjunto de resultados a respuestas de prueba de la vista previa del formulario, o excl\u00fayelas.","type":"boolean","required":false},"invalid_ids":{"description":"Lista de ID de elementos a incluir en los resultados independientemente de los filtros.","type":"array","items":{"type":"integer"},"default":[],"required":false},"fields_format":{"description":"Formato de los datos de los campos de la respuesta.","type":"string","enum":["label-value","collection"],"default":"label-value","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback"}]}},"\/wp\/v2\/feedback\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/feedback\/filters":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/filters"}]}},"\/wp\/v2\/feedback\/integrations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"version":{"type":"integer","default":1,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/integrations"}]}},"\/wp\/v2\/feedback\/integrations-metadata":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/integrations-metadata"}]}},"\/wp\/v2\/feedback\/integrations\/(?P<slug>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"slug":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/feedback\/bulk_actions":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","enum":["mark_as_spam","mark_as_not_spam"],"required":true},"post_ids":{"type":"array","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/bulk_actions"}]}},"\/wp\/v2\/feedback\/trash":{"namespace":"wp\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"status":{"type":"string","enum":["trash","spam"],"default":"trash","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/trash"}]}},"\/wp\/v2\/feedback\/config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/config"}]}},"\/wp\/v2\/feedback\/(?P<id>\\d+)\/read":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"type":"integer","required":true},"is_unread":{"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/feedback\/dismiss-classic-forms-notice":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/dismiss-classic-forms-notice"}]}},"\/wp\/v2\/feedback\/counts":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"parent":{"description":"Limit results to those of a specific parent ID.","type":"integer","required":false},"before":{"description":"Limit results to feedback published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"after":{"description":"Limit results to feedback published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"is_unread":{"description":"Limit results to read or unread feedback items.","type":"boolean","required":false},"is_test":{"description":"Limit results to test responses or exclude them.","type":"boolean","required":false},"source":{"description":"Limit results to feedback submitted from a specific source post ID.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/feedback\/counts"}]}},"\/wp\/v2\/jetpack-forms":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"jetpack_forms_context":{"description":"Solicitar contexto para los formularios de Jetpack. Usa \u00abescritorio\u00bb para incluir campos solo para el escritorio.","type":"string","default":"","enum":["","dashboard"],"required":false},"has_responses":{"description":"Filtra los formularios seg\u00fan si tienen respuestas. \"true\" devuelve solo los formularios con respuestas, \"false\" devuelve solo los formularios sin respuestas.","type":"string","enum":["","true","false"],"default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_jetpack_forms_source_post_id":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/jetpack-forms"}]}},"\/wp\/v2\/jetpack-forms\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_jetpack_forms_source_post_id":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<id>[\\d]+)\/preview-url":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico del formulario.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/jetpack-forms\/status-counts":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/jetpack-forms\/status-counts"}]}},"\/wp\/v2\/jetpack-forms\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_jetpack_forms_source_post_id":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_portfolio":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"dt_portfolio_category":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_portfolio_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"dt_portfolio_category_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_portfolio_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"dt_portfolio_tags":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_portfolio_tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"dt_portfolio_tags_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_portfolio_tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_portfolio_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_portfolio_category.","type":"array","items":{"type":"integer"},"required":false},"dt_portfolio_tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_portfolio_tags.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/dt_portfolio"}]}},"\/wp\/v2\/dt_portfolio\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_portfolio_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_portfolio_category.","type":"array","items":{"type":"integer"},"required":false},"dt_portfolio_tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_portfolio_tags.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_portfolio\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_portfolio\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_portfolio\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_portfolio_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_portfolio_category.","type":"array","items":{"type":"integer"},"required":false},"dt_portfolio_tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_portfolio_tags.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_portfolio\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_testimonials":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"dt_testimonials_category":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_testimonials_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"dt_testimonials_category_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_testimonials_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_testimonials_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_testimonials_category.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/dt_testimonials"}]}},"\/wp\/v2\/dt_testimonials\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_testimonials_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_testimonials_category.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_testimonials\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_testimonials_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_testimonials_category.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_testimonials\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_slideshow":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/dt_slideshow"}]}},"\/wp\/v2\/dt_slideshow\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_gallery":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"dt_gallery_category":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_gallery_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"dt_gallery_category_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda dt_gallery_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_gallery_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_gallery_category.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/dt_gallery"}]}},"\/wp\/v2\/dt_gallery\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_gallery_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_gallery_category.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_gallery\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_gallery\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_gallery\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"dt_gallery_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda dt_gallery_category.","type":"array","items":{"type":"integer"},"required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/dt_gallery\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/wpb_gutenberg_param":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","jp-temp-feedback","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","email_sent","email_failed","email_scheduled","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"yst_prominent_words":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"yst_prominent_words_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda yst_prominent_words.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/minutemanups.com\/es\/wp-json\/wp\/v2\/wpb_gutenberg_param"}]}},"\/wp\/v2\/wpb_gutenberg_param\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items":{"type":"integer"},"required":false},"jetpack_sharing_enabled":{"description":"\u00bfEst\u00e1n activados los botones para compartir?","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}}]},"\/wp\/v2\/wpb_gutenberg_param\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["en","fr","es"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private","wc-pending","wc-processing","wc-on-hold","wc-completed","wc-cancelled","wc-refunded","wc-failed","wc-checkout-draft","spam","tribe-ea-success","tribe-ea-failed","tribe-ea-schedule","tribe-ea-pending","tribe-ea-draft","tribe-ignored","fs-new","fs-created","fs-confirmed","fs-manifest","fs-failed"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"yst_prominent_words":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda yst_prominent_words.","type":"array","items"
