This post is also available in: ENG (ENG) Français (Francés)
Power Cabinets
POWER CABINETS
The Minuteman Enclosure Populated Power Cabinet – Advanced Server Rack Solution
Pre-populated with UPS and READY FOR IMMEDIATE DEPLOYMENT. Equipped with reversible front and back doors and removable side panels, the Minuteman Power Cabinet prioritizes security with locking mechanisms operated by included keys, guarding against potential damage, tampering, or theft. The doors and side panels are designed for quick release, simplifying access to connected equipment and cabling effortlessly. Featuring top access ports and an open bottom, the cabinet facilitates easy cable routing, while vented doors promote generous front-to-rear airflow, optimizing equipment performance for this plug-and-play solution.
  • Robust Construction for Tough Environments: Crafted from powder-coated steel, the Minuteman Power Cabinet ensures durability and resilience, making it ideal for challenging environments.
  • Impressive Load Capacities: With a maximum stationary capacity of 3000 lb. (1361 kg) and a rolling load capacity of 2250 lb. (1021 kg), this cabinet can handle the demands of your critical IT infrastructure.
  • Enhanced Security Measures: Doors and side panels of the Minuteman Power Cabinet lock securely, providing an additional layer of protection against potential damage, tampering, or theft.
  • Ready for Immediate Deployment: Shipped fully assembled, the Minuteman Power Cabinet enables swift deployment and equipment mounting, saving valuable time and effort.
  • PCI DSS Compliance: Offering the physical equipment and media security required for PCI DSS compliance, this cabinet is a reliable choice for companies involved in credit card information processing, storage, and transmission.
  • 5-Year Limited Warranty: Backed by a 5-year limited warranty, the Minuteman Enclosure Series Power Cabinet provides peace of mind, assuring you of its quality and durability.
Customize Your Cabinet
The Minuteman Populated Power Cabinet – Your Plug-and-Play Solution Ready for Immediate Deployment Organizing and Safeguarding 19 in. Rack Equipment in Edge Micro Data Centers and Critical IT Applications.
The Minuteman Populated Power Cabinet comes ready for immediate deployment with a pre-installed Minuteman UPS, and is designed to efficiently house, organize, and secure your collection of Minuteman PDUs, Transformers, Battery Packs, and other standard-depth 19 in. rack equipment in edge micro data centers and other mission-critical IT environments. Constructed with durable powder-coated steel, this 42U rack excels in tough environments, offering maximum load capacities of 3000 lb. (1361 kg) in a stationary position and 2250 lb. (1021 kg) when rolling.
Key Features & User Benefits
  • 5-Year Limited Warranty: Backed by a 5-year limited warranty, the Minuteman Power Cabinet provides peace of mind, assuring you of its quality and durability.
Rack Enclosure
  • SR42UB 42U Server Rack
  • (4) Side panels
  • (4) Side panel locks
  • (2) Keys
  • (50) M6 screws
  • (50) M6 washers
  • (50) M6 cage nuts
  • Owner’s manual
WARNING: This product can expose you to chemicals, including Nickel, which are known to the State of California to cause cancer and birth defects or other reproductive harm. For more information, go to: www.P65warnings.ca.gov/product
For complete product information, brochures and manuals visit out Resource Library.
UPS Model
MM24UCAB-SD
MM42UCAB-SD
MM24UCAB-ED
MM42UCAB-ED
General Features
Rack Units
24U
42U
24U
42U
Load Max
3,300 lbs.
Dimensions (HxWxD)
46.9” x 23.6” x 42.1”
78.4” x 23.6” x 42.1”
46.9” x 23.6” x 47.2”
78.4” x 23.6” x 47.2”
Weight
178.6 lbs.
312.6 lbs.
196.2 lbs.
305.3 lbs.
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
Maximum Device Depth
37 in.
Minimum Device Depth
4 in.
Vertical Mounting Rails
4
Grounding Details
Front and back door frames
Built-in Cable Management
Yes
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
CE (Europe); EIA/ECA-310-E; RoHS
WARRANTY & SUPPORT
Product Warranty Period (Worldwide)
