Whether you are a seasoned partner or new to the public sector, having a roadmap and a general sense of timelines for State, Local, and Education (SLED) cycles is a must. Though many plan for the essentials – racks, networking devices, telecommunications devices, and security, power is an essential function to maintain and keep active on these mission-critical devices.
SLED buyers are always actively planning, buying or implementing their latest IT programs.
Below is a SLED timeline reference to keep your team on track. Additionally, you will find a Power Protection Planning guide that will help you properly plan, purchase, and implement the right back up power and protection for any project.
BUYING CYCLE
July – September Planning for Organizational Needs
What does this mean?
Simply put, state legislators begin and review next year’s budget.
What does this mean for you?
This is an important time for you and your customer to discuss any upcoming needs to prepare for the buying season. Whether it is technical and financial challenges, or addressing procurement methods, laying and finalizing the groundwork between you and your customer will facilitate the buying process.
October – December Projects defined; Request for Pricing/Proposal (RFP) go out
Each state’s current year spending is identified, and budgets are defined. Most items are approved, and Request for Pricing/Proposal (RFP) is made public for bidding.
This is an opportunity to identify any potential project hurdles your customer may encounter, which may include financial obstacles, procurement strategies, potential funding gaps, and implementation plans for rollout schedules in the event supply chain delays exist.
January – March Final RFP submittals; Awarding process initiated
January is a busy month for many reseller partners, contractors, distributor partners, and vendors to submit their best pricing on open bids. The end of February through March is the period when award letters go out to those bidding on projects and announce who has won the bids. March also begins the procurement process with customers and all parties involved in the bidding process.
Winning time (hopefully) for you and your partners! If you receive the award letter, you get to prepare for the procurement and implementation process.
April – June Deployment and Installation Process
Deployments and installations of items begin for the SLED project(s).
Partners and vendors have confirmed availability, finalized deployment dates, and assisted with any logistical challenges to meet and fulfill customer target dates.
POWER PROTECTION PLANNING GUIDE
During the planning process your focus was probably on front end items: networking devices and peripherals, telecommunication devices, security hardware and software, racks, and cabling. Phew… that is a lot to plan for! So, how will you protect those hardware devices and make sure they are functioning? Well, fortunately, Minuteman Power has a simple guide outlining which questions to ask and find the right backup power solution for your customer.
KEY QUESTIONS TO ASK
- What type of equipment requires power protection and runtime backup?
- What are the total power load requirements? (Total load of attached equipment)
- What is the desired backup runtime?
- Mounting format – floor, wall, or rackmount?
- Input / Output wiring configuration – will the installation require a standard NEMA plug configuration, or will the installation require hardwire configuration?
- Accessories – Basic PDUs (Power Distribution Units) for additional outlets; networking cards for remote UPS management; Switched PDUs for remote management by individual outlet; Temperature or humidity monitoring.
Most Common Uninterruptible Power Supply (UPS) for SLED Projects
Line Interactive UPS
This type of UPS employs an automatic voltage regulator that corrects these voltage anomalies without accessing battery power, thus putting less strain on the battery and extending its life.
750VA – 3000VA (for small to medium sized applications)
On-line UPS
A true online UPS completely re-generates the incoming AC power to provide the best type of power protection available. This is accomplished by an internal inverter converting incoming power from AC to DC, and at the output, the DC signal is then converted back to AC.
Minuteman Power has several options:
1000VA – 3000VA (for small to medium sized applications)
Endeavor LCD (Rack/Tower format)
Encompass LCD * (Tower only)
Encompass * (Rack/Tower format)
*TAA Compliant UPS
5000VA – 20000VA (high density applications)
Endeavor 5-10kVA (Rack/Tower format)
Endeavor 6kVA & 10kVA (Tower only)
RECOMMENDED ACCESSORIES
Network card(s)
Power Distribution Units (PDUs)
Switched PDUs: RPM Series
EV6 & LCD series; 8 to 24 port Option
