This post is also available in: ENG (Anglais) ESP (Espagnol)
ENCOMPASS®
ENCOMPASS® ONLINE UNINTERRUPTIBLE POWER SUPPLY
True online sine wave rack/tower UPSs with LCD Display
Minuteman’s Encompass Series delivers comprehensive protection only offered by a true online UPS. By regenerating the incoming AC signal, through double conversion technology, an online UPS provides an impenetrable “electrical firewall,” providing the most fail-safe power protection available.
- High-Density Systems
- Network Servers
- Mission-Critical Devices
- Other Sensitive Electronic Devices
*Now TAA Compliant. Please contact Minuteman Power for more details
Designed to protect the most critical equipment used in data centers, voice and data communications, security systems, and light industrial applications, the Encompass Series is SNMP-capable (card optional) and allows full device management using Minuteman’s SentryHD power monitoring and control software. The Encompass product line is a value-priced online UPS solution that provides an outstanding set of features, true sine wave output, a three-year warranty (including batteries), generator compatibility, and is designed to meet the reliability expectations of even the most demanding critical applications.
Encompass Series Standard Features
- True online, double-conversion technology
- Compact case design, (only 2U for all models), for high density rack installations
- Flexible installation format: Rack/Tower
- Rackmount ears come attached to UPS
- Easy-to-read LCD display
- 0.9 output power factor
- Highly-efficient, Economy Mode option
- Output receptacle control with 2 banks
- Independent Battery Bypass – allows the UPS to provide voltage regulation and spike/surge protection either with dead batteries or without batteries
- Hot-swappable battery replacement
- Cold Start capable
- Automatic internal bypass
- Simultaneous USB and RS-232 communications
- Compatible with Minuteman’s SentryHD software
- SNMP compatible (with optional card)
- Dedicated EPO port
- Tool-less battery replacement design
- 1Gbit RJ45 network protection
- Full three-year warranty (including batteries)
- Green UPS design (RoHS2 compliant)
- $150,000 Platinum Protection Guarantee
Tour The LCD Panel
- The ON button is to turn the UPS on. Pressing the ON button during the Battery mode will silence the alarm.
- The OFF button is to turn the UPS off.
- The Utility Power (Green) LED illuminates when Utility Power is present and extinguishes during the Battery mode.
- The Load Bank 1 (Green) LED is illuminated when the Load Bank is on.
- The Load Bank 2 (Green) LED is illuminated when the Load Bank is on.
- The Bypass Active (Yellow) LED illuminates when the UPS is in the Bypass mode.
- The Weak/Bad Battery (Red) LED illuminates when the UPS detects a weak battery, bad battery or if the battery is disconnected. The Weak/Bad Battery icon is extinguished when the battery’s condition is good.
- The LCD displays the status of the UPS.
- Pressing the Enter button saves the changes made to the UPS settings.
- Pressing the Page Up button goes to the previous page or will change the UPS settings.
- Pressing the Page Down button goes to the next page.
- Pressing the Function button and then the Page Up button will initiate a 10- second battery test.
Electrical Characteristics
Output Power Factor
All Encompass models come with a 0.9 power factor of which increases the watt capacity of the units. Offering larger capacities in smaller UPS VA sizes reduces the overall cost of the UPS solution for a specific load requirement.
Output Voltage
All units in the Encompass Series produce an electrical signal that does not vary from nominal voltage by more than 2%. Tightly regulating the output voltage increases the quality of power to connected equipment adding to its life expectancy, which lowers the total cost of ownership to users.
Total Harmonic Distortion (THD)
THD is the distortion of a normal AC electrical signal commonly caused by non-linear loads. This distortion can cause internal heat to build up on sensitive equipment not designed to operate with these altered AC signals. The Endeavor LCD series provides power factor correction to reduce the THD and maintain a true sine wave output signal.
Output Receptacle Control:
The ability to extend the runtime of critical devices during an extended blackout is handled through the Encompass’s load shedding function. Each model in the Encompass UPS comes with two independently-circuited receptacle segments. Through the use of Minuteman’s SentryHD software or communication with the UPS through an Ethernet connection, users can either turn on, off, or reset each segment independently of the other. By reducing the load amount on the UPS, the runtime of critical devices on the UPS battery can be extended.
Communication Features
Simultaneous RS-232, USB and Ethernet communications: The Encompass UPS provides users with the ability to communicate with the UPS simultaneously through three separate protocols: RS-232, USB and Ethernet. Users can now directly connect and manage the UPS from multiple stand-alone, or networked computers. By including concurrent Ethernet communications (SNMP or direct IP address), the Encompass UPS can provide detailed monitoring and management to many various environments.
Other Features
RoHS 2 Compliance
Recognizing the benefit of being environmentally conscious, Para Systems developed the Encompass UPS Series to be compliant with the European Economic Unions directive on the reduction of hazardous substances (RoHS 2), in electronic equipment.
Manual and Automatic Self-Testing
The Encompass UPS is designed to proactively notify users of any impending faults or failures with the UPS. This allows for preemptive repair or replacement of components or batteries preventing unexpected downtime caused by the UPS.
Dedicated EPO Port
This direct access port allows users to perform an immediate remote shutdown of the UPS in cases of emergency or when access to the UPS is restricted or inconvenient.
Battery Technology
Battery Technology
All Encompass units use valve-regulated lead-acid batteries (VRLA). All are safe for any type of freight transport: air, sea or ground. For added protection, all Encompass UPS models ship with the batteries disconnected. A “Quick Installation Guide” is included in each Encompass box to detail how to connect the batteries before putting the units into service.
Hot-Swappable Batteries
All models in the Encompass line offer Tool-less battery replacement, through the front panel of the UPS, without having to remove the UPS from service. Connected loads are protected from voltage anomalies and spikes and surges while the batteries are being replaced.
Get ultimate control over your power with SentryHD
In today’s complex world of data, networks, and software, control and management of applications is vital, especially when it comes to the power that is supplied to these devices.
SentryHD, included free with all current Minuteman UPS systems, is the latest update to Minuteman’s popular Sentry monitoring and management software. This powerful tool provides users and network managers a range of monitoring & managment tools for their power, allowing total control before, during, and after power problems.
With a simple connection to the UPS via USB or RS-232, SentryHD provides the capability to configure UPSs, monitor power, and diagnose issues, all from secure connections on the network. This eliminates wasteful runs around the facility, saving time and money.
Optional mounting brackets
- E BRKT RAIL rail kit
Power management via SNMP Communications
Optional SNMP-NV6 and SNMP-NET cards allow easy management of UPS without the need for a connected PC or server
Optional Programmable Relay Card:
- Monitors UPS events
- 6 programmable relay output contacts
- Configurable normal open or normal close for each relay contact
- Configurable UPS shutdown delay time
- Configurable input signal as shutdown UPS or battery test
- Has the ability to protect up to 6 computers unattended shutdown gracefully
Extended Warranty
5 Full Years of Trouble-free Service – Guaranteed
For complete product information, brochures and manuals visit out Resource Library.
MODEL | EC1000RT2U | EC1500RT2U | EC2000RT2U | EC3000RT2U |
Maximum Power Capacity (VA/Watts) | 1000/900 | 1500/1350 | 2000/1800 | 3000/2700 |
Topology | On-line Uninterruptible Power Supply |
Power Factor | 0.9 |
Input Connection (with 10 ft power cord) | 5-15P | 5-20P | L5-30P |
Battery and Surge Protected Receptacles | [6]5-15R (controllable) | [6] 5-15/20R (controllable) | [6] 5-15/20R (controllable) & [1] L5-30R (always on) |
Mounting/Installation | Rackmount and tower |
Input | |
Nominal Voltage | 120VAC |
Voltage Range | 0-160VAC |
Frequency Range | 50/60Hz ±6Hz Auto-sensing |
Power Factor Correction | ≥99% at full load |
Output Non-battery Operation | |
Voltage /Frequency Range | Nominal ±2% / 60Hz: 54-66Hz or 50Hz: 44-56Hz |
Wave Form | True sine wave |
Efficiency (Line Mode) | >90% (full load) |
Output Battery Operation | |
Nominal Voltage | 120VAC, User selectable: 110VAC, 127VAC |
Voltage Regulation | Nominal ±2% until low battery warning |
Frequency | 50/60Hz ±0.2Hz unless synchronized to line |
Voltage Total Harmonic Distortion T.H.D. | ≤3% at full rated linear load |
Dynamic Response | ±5% at 100% load change in 30ms |
Transfer Time | 0ms Typical |
Runtime: Half Load/Full Load (minutes) | 10/2 | 15/5 | 10/3 | 10/3 |
Battery System | |
Battery Type | Sealed, non-spillable, maintenance free, value regulated lead acid |
Typical Recharge Time | 8 hours to 90% from total discharge |
Typical Battery Life | 3-5 years, depending on discharge cycles and ambient temperature |
Internal Battery Module | BM0069 | BM0070 | BM0071 |
System Voltage | 24VDC | 48VDC | 72VDC |
Surge Protection and Filtering | ||
Surge Energy Rating (Joules) | 140J | 254J |
Surge Current Capability | 6500Amps total |
Surge Response time | 0ns (instantaneous) normal mode; <5ns common mode |
Noise Filter | normal and common mode EMI/RFI suppression |
Audible Noise at 1 m (3 ft.) | <55dBA |
Environmental | |
Operating (max)/Storage Temperature | +32 to +104°F (0 to 40°C) / +14 to +122°F (-10 to +50°C) |
Operating/Storage Humidity | 10% to 90% non-condensing |
Operating/Storage Elevation | 0 to 10,000 ft (0 to 3,000 m) / 0 to 50,000 ft (0 to 15,000 m) |
Physical
Size - Shipping (L X W X H) mm | 570 x 544 x 228 mm | 650 x 544 x 228 mm | 785 x 590 x 228 mm |
Size - Shipping (L X W X H) in | 22.4 x 21.4 x 9.0 in | 25.6 x 21.4 x 9.0 in | 30.9 x 23.2 x 9.0 in |
Size - Net (L X W X H) mm | 407 x 479 x 88 mm | 487 x 479 x 88 mm | 602 x 479 x 88 mm |
Size - Net (L X W X H) in | 16.0 x 18.9 x 3.5 in | 19.2 x 18.9 x 3.5 in | 23.7 x 18.9 x 3.5 in |
Weight - Net/Shipping | 24.3/29.5 lb (11.0/13.4 kg) | 44.1/49.6 lb (20.0/22.5 kg) | 44.1/49.6 lb (20.0/22.5 kg) | 61.1/75.8 lb (27.7/34.4 kg) |
Regulatory Compliance | |
Safety and Approvals | cTUVus (Conforms to UL1778 5th Edition & CSA 22.2 no. 107.3-14 / R: 2014), FCC Class A, CE certified, RoHS2 (EU Directive 2011/65/EU) |
Warranty / Platinum Protection Plan | Three-year non-prorated warranty, including batteries / $150,000 (U.S. and Canada only) |
