This post is also available in: ENG (Anglais) ESP (Espagnol)
ENDEAVOR 208V
ENDEAVOR® 208V ONLINE UNINTERRUPTIBLE POWER SUPPLY
True online rack/tower/wall UPSs for sensitive electronic equipment and critical servers, network devices, and phone systems.
The Minuteman Endeavor Series UPS combines double-conversion technology and extended runtime capability in a versatile case design.
The Industry Leader
The Minuteman® Endeavor™ Series online uninterruptible power supply combines double-conversion technology with industry-leading features in a versatile case design that allows the units to be installed in many different formats and environments.
The Endeavor Series is rich in standard features and optional accessories allowing users to order “off the shelf” products and yet retain the flexibility previously only available as a special order product.
Extended Runtime Capability
All models in the Endeavor Series come standard with internal batteries. To protect critical devices through extended blackouts, the Endeavor Series utilizes external battery packs that can be daisy-chained in unlimited quantities to provide a virtually unlimited amount of runtime.
Fast Battery Recharge
With independent chargers in each battery pack offered for the Endeavor Series, the maximum recharge time for depleted batteries is 8 hours to 90% after full load discharge, no matter how many battery packs are installed on a UPS. Without these chargers, if more than one battery pack is used battery charging could take more than an entire day.
Endeavor® 208V Key Features
- 208V/240V capability
- Floor-standing tower, 19-inch rack and cabinet installation kits included
- 23-inch rack or cabinet installation kit optional
- Wallmount installation kit optional
- 3.5-inch (2U) rack/tower case style
- Up to a 0.8 power factor (in watts) for larger capacities
- Output receptacle control for non-critical load shedding capability
- Extended runtime using external battery packs
- Independent battery pack chargers to reduce battery recharge times
- Simultaneous RS-232, USB and SNMP communications
- Minuteman® SentryPlus™ UPS monitoring and control software
- Front panel display with load/battery meter and status indicators
- 3-year non-prorated warranty (including batteries)
- Dedicated remote Emergency Power Off (EPO) port
- Hot-swappable batteries
- RoHS compliant
- $200,000 Minuteman Platinum Protection Plan® (U.S. and Canada only)
Tour The LCD Panel
Indicators include:
ONLINE (green) constantly on when operating in on-line mode
LINE (green) on when unit is plugged in and acceptable utility voltage present
BYPASS (yellow) flashes when unit is in bypass mode
LOAD (yellow) constantly on when unit is operating in the On-line or Bypass mode. Percent of load capacity indicated (25, 50, 75 and 100% with green LEDs)
BATT (yellow) constantly on when the unit is operating On-Battery mode. Percent of available capacity displayed)100, 75, 50 and 25% with green LEDs
OVERLOAD (red) constantly on when unit senses an overload condition
FAULT (red) constantly on when unit has an internal fault and not functioning properly
BATT LOW (yellow) constantly on when unit reaches a low battery warning
REPLACE BATT (red) constantly on when unit senses a weak, bad or disconnected battery
ON-TEST button– Pressed to turn on unit or to test
OFF button – pressed to turn unit off
Electrical Characteristics
Output Power Factor
All Endeavor models up to 2000VA come with a 0.8 output power factor that increases the watt capacity of the units. Offering larger capacities in smaller UPS VA sizes reduces the overall cost of the UPS solution for a specific load requirement. The 3000VA model comes with a 0.7 power factor that provides 2,100 watts capacity in a 3.5” (2U) rack space.
Output Voltage
All units in the Endeavor Series produce an electrical signal that does not vary from nominal voltage by more than 2%. Tightly regulating the output voltage increases the quality of power to connected equipment adding to its life expectancy, which lowers the total cost of ownership to users.
Total Harmonic Distortion (THD)
THD is the distortion of a normal AC electrical signal commonly caused on UPS products when connected loads near the capacity of the units. This distortion can create internal heat build-up on sensitive equipment not designed to allow for these altered AC signals. The Endeavor Series maintains an output AC signal, at all times and with all loads, within 2% of a true sinewave.
Output Receptacle Control
The ability to extend the runtime of critical devices during an extended blackout is handled through the Endeavor’s load shedding function. Each model in the Endeavor Series comes with two independently-circuited receptacle segments. Through the use of Minuteman’s SentryPlus software or communication with the UPS through an Ethernet/SNMP connection, users can either turn on, off, or reset each segment independently of the other. By reducing the load amount on the UPS, the runtime of critical devices on the UPS battery can be extended.
Communication Features
Simultaneous RS232, USB and Ethernet/SNMP Communications
The Endeavor Series provides users with the ability to communicate with the UPS simultaneously through three separate protocols: RS232, USB and SNMP Users can now directly connect, and manage, the UPS from multiple stand-alone, or networked, computers. By including concurrent Ethernet communications, (SNMP or direct IP address), the Endeavor Series can provide detailed monitoring and management to many various environments.
Other Features
RoHS 2 Compliance
Recognizing the benefit of being environmentally conscious, Para Systems developed the Endeavor Series to be compliant with the European Economic Unions directive on the reduction of hazardous substances (RoHS 2), in electronic equipment.
Manual and Automatic Self-Testing
The Endeavor UPS is designed to proactively notify users of any impending faults or failures with the UPS. This allows for preemptive repair or replacement of components or batteries preventing unexpected downtime caused by the UPS.
Dedicated EPO Port
This direct access port allows users to perform an immediate remote shutdown of the UPS in cases of emergency or when access to the UPS is restricted or inconvenient.
Battery Technology
All models in the Endeavor Series come standard with internal batteries. To protect critical devices through extended blackouts, the Endeavor Series utilizes external battery packs that can be daisy-chained in unlimited quantities to provide a virtual unlimited amount of runtime.
With independent chargers in each battery pack offered for the Endeavor Series, the maximum recharge time for depleted batteries is 8-hours from a total discharge, no matter how many battery packs are installed on a UPS. Without these chargers, if more than one battery pack is used battery charging could take more than an entire day.
Battery Technology
All Endeavor units and battery packs use valve-regulated lead-acid batteries (VRLA). All are safe for any type of freight transport: air, sea or ground. For added protection, all Endeavor UPS models ship with these batteries disconnected. A “Quick Installation Guide” is included in each Endeavor box to detail how to connect the batteries before turning the units on.
Hot-Swappable Batteries
All models in the Endeavor line offer battery replacement, through the front panel of the UPS, without having to remove the UPS from service. Connected loads are protected from voltage anomalies and spikes and surges while the batteries are being replaced.
SentryPlus Power Monitoring and Management Software
SentryPlus is designed to provide end users the ability to take proactive steps to protect their equipment from power related damages. SentryPlus allows for automatic shutdowns, scheduled shutdowns and a variety of other features that will help you manage your system and its peripheral components.
External battery packs
- BP24RTXL external battery pack for ED1000RM2U and ED1000RMT2U
- BP48RTXL external battery pack for ED1500RM2U, ED1500RMT2U, ED2000RM2U and ED2000RMT2U
- BP72RTXL external battery pack for ED3000RM2U and ED3000RMT2U
- BP24V72RTEXL high-capacity external battery pack for ED1000RM2U and ED1000RMT2U
- BP48V36RTEXL high-capacity external battery pack for ED1500RM2U, ED1500RMT2U, ED2000RM2U and ED2000RMT2U
- BP72V24RTEXL high-capacity external battery pack for ED3000RM2U and ED3000RMT2U
Optional mounting brackets
- E BRKT WALL wall bracket for single unit
- E BRKT WALL x2 wall bracket for one UPS and one Battery Pack (XL model only)
- E BRKT 23 brackets for 23-inch rack
- E BRKT RAIL rail kit
Power management via SNMP Communications
Optional SNMP-NV6 and SNMP-NET cards allow easy management of UPS without the need of a connected PC or server
- SNMP-NV6
- SNMP-NET
Optional Programmable Relay Card:
- Monitors UPS events
- 6 programmable relay output contacts
- Configurable normal open or normal close for each relay contact
- Configurable UPS shutdown delay time
- Configurable input signal as shutdown UPS or battery test
- Has the ability to protect up to 6 computers unattended shutdown gracefully
WARNING: This product can expose you to chemicals, including Nickel, which are known to the State of California to cause cancer and birth defects or other reproductive harm. For more information, go to: www.P65warnings.ca.gov/
Extended Warranty Plan
For full warranty information, please visit our warranty page.
For complete product information, brochures and manuals visit our Media Resources Center.
MODEL | ED1000RMT2U | ED2000RMT2U | ED3000RMT2U |
Maximum Power Capacity (VA/Watts) | 1000/800 | 2000/1600 | 3000/2100 |
Topology | On-line Uninterruptible Power Supply |
Power Factor | 0.8 | 0.7 |
Input Connection (with 10 ft power cord) | 6-15P | L6-20P | L6-30P |
Battery and Surge Protected Receptacles | [4] 6-15R | [4] 6-15/20R & [1] L6-20R | [4] 6-15/20R & [1] L6-30R |
Mounting/Installation | Rackmount, tower and wallmount |
Input | |
Nominal Voltage | 208VAC |
Frequency Range | 50/60Hz +/-6Hz Auto-sensing |
Power Factor Correction | ≥97% at full load |
Voltage Range | 160-280VAC | 160-280VAC |
Output Non-battery Operation | |
Voltage /Frequency Range | 204 - 212VAC / 50/60Hz ±6Hz |
Wave Form | True sine wave |
Efficiency (Line Mode) | >87% (full load) |
Output Battery Operation | |
Nominal Voltage | 208VAC, User selectable: 240VAC |
Voltage Regulation | Nominal ±2% until low battery warning |
Frequency | 50/60Hz ±0.1Hz unless synchronized to line |
Voltage Total Harmonic Distortion T.H.D. | ≤3% at full rated linear load |
Dynamic Response | ±5% at 100% load change in 30ms |
Transfer Time | 0ms |
Runtime: Half Load/Full Load (minutes) | 13/4 | 15/5 |
Battery System | |
Battery Type | Sealed, non-spillable, maintenance free, value regulated lead acid |
Typical Recharge Time | 8 hours from total discharge |
Typical Battery Life | 3-5 years, depending on discharge cycles and ambient temperature |
System Voltage | 24VDC | 48VDC | 72VDC |
Internal Battery Module | BM0035 | BM0036 | BM0037 | BM0032 |
Surge Protection and Filtering | |
Surge Energy Rating (Joules) | 600J |
Surge Current Capability | 6500Amps total |
Surge Response time | 0ns (instantaneous) normal mode; 5ns common mode |
Noise Filter | normal and common mode EMI/RFI suppression |
Audible Noise at 1 m (3 ft.) | <45dBA | <60dBA |
Environmental | |
Operating (max)/Storage Temperature | +32 to +104°F (0 to 40°C) / +5 to +113°F (-15 to +45°C) |
Operating/Storage Humidity | 95% non-condensing |
Operating/Storage Elevation | 0 to 10,000 ft (0 to 3,000 m) / 0 to 50,000 ft (0 to 15,000 m) |
Physical
Size - Net (H x W x D) mm | 89 x 440 x 335 mm | 89 x 440 x 432 mm | 89 x 440 x 610 mm |
Size - Net (H x W x D) in | .5 x 17.3 x 13.1 in | 3.5 x 17.3 x 17.0 in | 3.5 x 17.3 x 24 in |
Size - Shipping (H x W x D) in | 9.0 x 20.0 x 23.6 in | 9.0 x 23.6 x 39.4 in |
Size - Shipping (H x W x D) mm | 230 x 508 x 600 mm | 230 x 600 x 1000 mm |
Weight - Net/Shipping 208VAC | 27.7/38.1 lb (12.6/17.3 kg) | 41.8/49.9 lb (19.0/22.7 kg) | 44.9/53.0 lb (20.4/24.1 kg) | 67.7/79.2 lb (30.7/35.9 kg) |
Battery Pack | BP24RTXL | BP48RTXL | BP72RTXL |
Typical Recharge Time | 8 hours maximum |
Size - Shipping (H x W x D) | 9.0 x 20.0 x 23.6 in (230 x 508 x 600 mm) |
Size - Net (H x W x D) | 3.5 x 17.3 x 13.1 in | 3.5 x 17.3 x 17.0 in |
Size - Net (H x W x D) | 89 x 440 x 335 mm | 89 x 440 x 432 mm |
Weight - Shipping | 48.4 lb (22.0 kg) | 74.8 lb (34.0 kg) | 63.8 lb (29.0 kg) |
Weight - Net | 39.6 lb (18.0 kg) | 66.0 lb (30.0 kg) | 55.0 lb (25.0 kg) |
Regulatory Compliance | |
Safety and Approvals | RoHS Compliant, UL 1778, cUL, FCC Class B for 1000VA, Class A for 1500, 2000, 3000VA and Battery Packs |
Warranty / Platinum Protection Plan | Three-year non-prorated warranty, including batteries / $200,000 (U.S. and Canada only) |
