OE Series Power Distribution Units
Minuteman Power Distribution Units offer 6-24 outlets, lengthy power cords, versatile configuration options, and premium features at a lower cost.
Minuteman offers high-quality power distribution solutions for IT equipment in network closets and data centers. The OE series features lengthy power cords, versatile configuration options, and a host of premium features, all at an incredible value.
Minuteman’s robust PDU line offers products ranging in capacity from 15 to 30 Amps, in both vertical and horizontal orientations. In addition, select models feature surge suppression and load metering. OEPD power cords are strain-relieved with molded plugs and use heavy-gauged cables. All models have an external ground stud.
Please visit the Resource Library for brochures, user manuals, and other materials.
Minuteman basic PDUs are available in a range of configurations, including versatile horizontal/vertical or horizontal-only mounting, a range of outlet configurations, and in both 15 and 20-amp load capacity.
| Models | OEPD615HV | OEPD815HV | OEPD1415HV | OEPD1415HV-HW | OEPD1815V48 | OEPD2415V62 | OEPD2415V62-HW |
| Max Input Capacity | 15 Amps | 15 Amps | 15 Amps | 15 Amps | 15 Amps | 15 Amps | 15 Amps |
| Outlets | 6 outlets | 8 outlets | 14 outlets | 14 outlets | 18 outlets | 24 outlets | 24 outlets |
| Features | |||||||
| All-metal case | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Power On/Off LED | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Input Power Cord Length | 15 feet | 15 feet | 15 feet | 15 feet | 15 feet | 15 feet | 15 feet |
| Input Circuit Breaker Protection | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Input Protection (Size) | Circuit Breaker (15A) | Circuit Breaker (15A) | Circuit Breaker (15A) | Circuit Breaker (15A) | Circuit Breaker (15A) | Circuit Breaker (15A) | Circuit Breaker (15A) |
| Surge-protection Joule Rating | - | - | - | - | - | - | - |
| Surge LED | - | - | - | - | - | - | - |
| Horizontal Installation | Yes | Yes | Yes | Yes | No | No | No |
| 0U Vertical Installation | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Maximum Output Rating | 12 Amps | 12 Amps | 12 Amps | 12 Amps | 12 Amps | 12 Amps | 12 Amps |
| Front Panel Receptacles | (6) 5-15R | (2) 5-15R | (6) 5-15R | (6) 5-15/20R | (18) 5-15R | (24) 5-15R | (24) 5-15R |
| Rear Panel Receptacles | - | (6) 5-15R | (8) 5-15R | (8) 5-15/20R | - | - | - |
| Input Connection | NEMA 5-15P | NEMA 5-15P | NEMA 5-15P | Hardwire | NEMA 5-15P | NEMA 5-15P | Hardwire |
| UL 62368-1 Certification | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Environmental Regulatory Compliance | RoHS2 | RoHS2 | RoHS2 | RoHS2 | RoHS2 | RoHS2 | RoHS2 |
| Models | OEPD1020HV-HW | OEPD2420V62 | OEPD2420V62L | OEPD2420V62-HW |
| Max Input Capacity | 20 Amps | 20 Amps | 20 Amps | 20 Amps |
| Outlets | 10 Outlets | 24 outlets | 24 outlets | 24 outlets |
| Features | ||||
| Horizontal Installation | Yes | No | No | No |
| Maximum Output Rating | 16 Amps | 16 Amps | 16 Amps | 16 Amps |
| Front Panel Receptacles | (2) 5-15/20R | (24) 5-15/20R | (24) 5-15/20R | (24) 5-15/20R |
| Rear Panel Receptacles | (8) 5-15/20R | - | - | - |
| Input Connection | Hardwire | NEMA 5-20P | NEMA 5-20P | Hardwire |
Minuteman surge-protected PDUs combine a wide range of configurations in both 15 and 20-amp load capacity with surge protection hardware. Defend connected equipment against damaging spikes and surges with up to 2000J of protection.
| Models | OES1015HV | OES1020HV |
| Max Input Capacity | 15 Amps | 20 Amps |
| Outlets | 10 Outlets | 10 outlets |
| Features | ||
| Surge-protection Joule Rating | 2000 | 2000 |
| Surge LED | Yes | Yes |
| Maximum Output Rating | 12 Amps | 16 Amps |
| Front Panel Receptacles | (2) 5-15/20R | (2) 5-15/20R |
| Rear Panel Receptacles | (8) 5-15/20R | (8) 5-15/20R |
| Input Connection | NEMA 5-15P | NEMA 5-20P |
Minuteman 208/240-volt PDUs for high-voltage equipment are available in 2 configurations, providing 20 or 30-amp load capacity with IEC320 receptacles. OEPD 208/240-volt options are the ideal pairing for large telecommunications, network, and security equipment installations.
| Models | OEPD202L620HVN | OEPD202L620HVHW | OEPD2024IECHVI | OEPD2024IECHW |
| Outlets | 2 Outlets | 2 Outlets | 24 outlets | 24 outlets |
| Features | ||||
| Power On/Off LED | - | - | - | - |
| Input Power Cord Length | 6 feet | 6 feet | 6 feet | 6 feet |
| Input Circuit Breaker Protection | No | No | Yes | Yes |
| Maximum Output Rating | 20 Amps | 20 Amps | 20 Amps | 20 Amps |
| Front Panel Receptacles | (2) L6-20R | (2) L6-20R | (10) C13 / (2) C19 | (10) C13 / (2) C19 |
| Rear Panel Receptacles | - | - | (10) C13 / (2) C19 | (10) C13 / (2) C19 |
| Input Connection | NEMA L6-20P | Hardwire | NEMA L6-20P | Hardwire |
| Models | OEPD302L630HVN | OEPD302L630HVHW | OEPD304L630HVN | OEPD304L630HVHW |
| Max Input Capacity | 30 Amps | 30 Amps | 30 Amps | 30 Amps |
| Outlets | 2 Outlets | 2 Outlets | 4 outlets | 4 outlets |
| Features | ||||
| Maximum Output Rating | 30 Amps | 30 Amps | 30 Amps | 30 Amps |
| Front Panel Receptacles | (2) L6-30R | (2) L6-30R | (2) L6-20R / (2) L6-30R | (2) L6-20R / (2) L6-30R |
| Rear Panel Receptacles | - | - | - | - |
| Input Connection | NEMA L6-30P | Hardwire | NEMA L6-30P | Hardwire |
“We are very impressed with Christian’s and Minuteman’s efforts to take care the batteries that were not hooked up with an order we had placed. Christian had reached out to…
“I had a problem at installation of MN 525 which was immediately addressed by Minuteman”, whereas “APC provided virtually no customer service.” – B. Walters, Mt Pleasant, SC
“Thank you for being so service oriented.” Not only will I “recommend Minuteman because of your service, but I will never buy any other UPS. And I will convert all…
