ENSPIRE®
ENSPIRE® UNINTERRUPTIBLE POWER SUPPLY
Standby simulated sine wave desktop/floor/wall mount UPSs
The Minuteman Enspire Series UPS offers standby protection and a compact desktop/floor/wall mount profile perfect for a range of small to medium load applications.
- Desktop PCs
- Workstations
- Home Entertainment
- Routers & Modems
- Gaming Consoles
- Small Security Systems
(Not for sale in CO, VT, or WA)
Download Product Brochure
Download Product User Manual (EN350 & EN550) | Download Product User Manual (EN750LCD & EN900LCD)
Low-profile, High protection
The Minuteman Enspire Series UPS is a low-cost, high performance UPS line that provides the features needed to protect your valuable equipment. The EN350 and EN550 units each have eight outlets, four provide battery support along with spike and surge protection and four with spike and surge protection only.
The EN750LCD and EN900LCD each have five of the outlets described above for total protection of up to ten connected devices. In addition, all units have outlets which are specifically spaced to support transformer blocks.
Complete Protection for:
- Desktop Computers
- Standalone Servers
- Network Switches, Hubs, and Peripherals
- VoIP Communications
- Telephone Systems
- External Computer Accessories
- Security Cameras and DVRs
Enspire® Key Product Features
- Economical Standby Protection Hardware
Cost-effective surge and backup protection for small loads - Versatile Connection Options
8 (350 and 550) or 10 (750 and 900) outlets to ensure a connection for all of your devices - Compact, Wall-Mountable Case
- Tool-less, Hot-Swappable Battery Replacement
- USB Communications (HID Compliant)
Enspire UPS USB connections are automatically recognized by Microsoft Windows (550/750/900 models) - Single Line Phone / Fax / Network Protection
The Enspire UPS provides a low cost means of protecting telephone/fax/network lines - Independent Battery Bypass
Provides surge and spike protection, even when batteries are weak or dead
Features on 750VA and 900VA Models:
- Easy to Read LCD Display
Real-time updates on system and power status, estimated runtime remaining based on attached load - Green Mode
Lower power consumption mode during off-time - Coax Protection
Protect coaxial cable for AV equipment from damaging spikes and surges - Industry Leading Product Protection
Standard 3-year parts and labor warranty with 2-year non-prorated battery coverage; $50,000 Platinum Protection Plan (US and Canada) - ECO Mode on EN900LCD
Other Features
Protects Against Spikes, Surges, Brownouts and Blackouts Feature-rich Design
- RJ11/45 Network/Phone/Fax protection
- RoHS 2 compliant
- Transformer-friendly receptacles
- DC Startup capability
- Built-in self-diagnostics testing
- Audio & Visual alarms
Get ultimate control over your power with SentryHD
In today’s complex world of data, networks, and software, control and management of applications is vital, especially when it comes to the power that is supplied to these devices.
SentryHD, included free with all current Minuteman UPS systems, is the latest update to Minuteman’s popular Sentry monitoring and management software. This powerful tool provides users and network managers a range of monitoring & managment tools for their power, allowing total control before, during, and after power problems.
With a simple connection to the UPS via USB or RS-232, SentryHD provides the capability to configure UPSs, monitor power, and diagnose issues, all from secure connections on the network. This eliminates wasteful runs around the facility, saving time and money.
Warranty
5 Full Years of Trouble-free Service – Guaranteed
For complete product information, brochures, and manuals visit our Media Resources Center.
MODELS
| EN350 | EN550 | EN750LCD | EN900LCD | |
| Out of Stock | Out of Stock | Limited Stock Available | Out of Stock | |
| VA Rating | 350VA | 550VA | 750VA | 900VA |
| Load Capacity (Watts) | 250W | 300W | 450W | 500W |
| Topology | Standby |
| Installation Format(s) | Desktop, Floor, or Wall-mount |
| INPUT | |
| Nominal Voltage Range | 95 - 140VAC |
| Frequency Range | 60HZ ±6Hz |
| Input Surge Protection | Circuit Breaker |
| Surge Joule Rating | 1000J |
| Input Plug Type (Cord Length) | NEMA 5-15P (5 ft.) | NEMA 5-15P (5 ft.) |
| Maximum Input Current | 10 Amps (350VA & 550VA) | 12 Amps (750VA & 900VA) |
| OUTPUT | |
| Output Voltage Range (Battery Mode) | 95 - 140VAC (120VAC ±5% until low battery warning) |
| Output Frequency Range (Battery Mode) | 60Hz ±6Hz (60Hz ±0.5Hz unless synchronized to line) |
| Output Waveform (Battery Mode) | Sine wave (Step Wave) |
| Output Receptacles | (4) Surge-only / (4) Battery & Surge | (5) Surge-only / (5) Battery & Surge |
| BATTERIES | |
| Tool-less Replacement | Yes |
| Ind. Battery Bypass | Yes |
| DC Startup | Yes |
| Hot-swappable Batteries | Yes |
| Runtime (Full/Half Load) | 3 min. / 11 min. | 2 min. / 10 min. | 4 min. / 12 min. | 3 min. / 11 min. |
