PRO-RT2U® LINE INTERACTIVE UNINTERRUPTIBLE POWER SUPPLY
Line interactive simulated sine wave rack/tower convertible UPSs Designed to support network servers, small rack environments, security CCTV & DVR, Telecom & VoIP
The Minuteman PRO-RT2U Series UPS offers automatic voltage regulation, connected network management, and versatile configuration options for a range of small to medium load applications.
- Telecom
- VoIP Systems
- Network Servers
- Security Systems
Perfect Protection For Rack-Mount Systems
The PRO-RT2U Series is a value-priced, yet feature-rich UPS incorporating line-interactive technology that preserves battery power by providing voltage regulation during brownouts or voltage sags. The PRO-RT2U Series can be used to support servers, telecom or VoIP systems, security systems, plus many other applications.
The PRO-RT2U UPSs include many useful features such as load-shedding with two load banks, independent battery bypass, plus auto-re-start when power is restored after an extended power outage.
PRO-RT2U® Key Features
- Protection from Spikes, Surges, Brownouts, and Blackouts
- Buck and boost Automatic Voltage Regulation (AVR) function
- All outlets are battery and surge-protected
- RJ11 / RJ45 spike/surge protection for phone/fax/ modem/network connections (1Gb)
- Coax protection for satellite/cable
- Rack/Tower Installation
2U rack height or wall mounting with optional kit - Minuteman SentryHD Software
- Automatically saves and shuts down unfinished or open applications programs
- Power down your devices during blackouts
- Provides comprehensive power monitoring
- USB Communications
No special USB drivers are required. The USB is automatically recognized by Microsoft® Windows® as an HID-compliant device – similar to a mouse or a keyboard. - SNMP Compatible
Each PRO-RT2U unit can be managed on a network with the addition of an optional SNMP management card. (NC models include a pre-installed network card) - Fax/Modem/Network/Coax Line Protection
The PRO-RT2U UPS provides a low-cost means of protecting fax/modem/network lines. - Independent Battery Bypass
Provides voltage regulation with surge and spike protection even when batteries are weak or dead. - Auto-restart
When power returns after an extended outage and the batteries have been fully drained, the UPS automatically restarts and provides power to attached devices if acceptable AC is present. - Warranty
Each PRO-RT UPS system is covered by a three-year parts and labor warranty and a $100,000 Minuteman Platinum Protection Plan® (U.S.A. and Canada only). Five-year warranty options are available.
Tour The Front & Back Panels
- LCD Status Display
- Rackmount Brackets
- Input Circuit Breaker
- Input Power Cord
- Coax Surge Protection
- Emergency Power Off
- Fan
- USB Port
- RJ11/RJ45/Fax/Modem Network Protection
- Controllable Output Receptacles (6)
- Always On Receptacles (2) (Only one on the PRO2000RT2U)
- Option Card Slot
Communication Features
PRO-RT2U power management via SNMP Communications
Optional SNMP-NV6 card allow easy management of UPS without the need of a connected PC or server
Versatile Communications
Each PRO-RT2U model is compatible with Minuteman’s free downloadable SentryHD™ power management and diagnostic software. When installed on a workstation or server, the user gains complete control over monitoring and managing the UPS using a convenient web browser-based interface. The SentryHD software communicates via a built-in USB port on the UPS. In addition, managing the UPS within a Network Management System (NMS) is easy with the installation of an optional SNMP card.
Designed for versatility, the PRO-RT2U models can be mounted in a standard rack using the attached rackmount ears. All units can also be installed as a tower using the included feet. An optional kit is available for mounting the unit to a wall.
High-end Features - Budget Friendly Price
The PRO-RT offers many features normally found on higher-priced models, including an LCD status display that shows the following:
- Input / Output voltage and frequency
Monitor the status of your utility power - UPS and battery mode/status
Eliminate guesswork with a straightforward display of the unit’s status - Load capacity
The load indicator shows how much electrical load is being placed on the unit - Estimated runtime based on connected load
Find out how much backup time remains during a blackout right on the unit
Get ultimate control over your power with SentryHD
In today’s complex world of data, networks, and software, control and management of applications is vital, especially when it comes to the power that is supplied to these devices.
SentryHD, included free with all current Minuteman UPS systems, is the latest update to Minuteman’s popular Sentry monitoring and management software. This powerful tool provides users and network managers a range of monitoring & managment tools for their power, allowing total control before, during, and after power problems.
With a simple connection to the UPS via USB or RS-232, SentryHD provides the capability to configure UPSs, monitor power, and diagnose issues, all from secure connections on the network. This eliminates wasteful runs around the facility, saving time and money.
PRO-RT power management via SNMP Communications
Optional Programmable Relay Card:
- Monitors UPS events
- 6 programmable relay output contacts
- Configurable normal open or normal close for each relay contact
- Configurable UPS shutdown delay time
- Configurable input signal as shutdown UPS or battery test
- Has the ability to protect up to 6 computers unattended shutdown gracefully
Optional mounting brackets
- E BRKT WALL wall bracket for single unit
WARNING: This product can expose you to chemicals, including Nickel, which are known to the State of California to cause cancer and birth defects or other reproductive harm. For more information, go to: www.P65warnings.ca.gov/
Extended Warranty Plan
5 Full Years of Trouble-free Service – Guaranteed
For complete product information, brochures and manuals visit out Resource Library.
MODELS
| PRO750RT2U | PRO1000RT2U | PRO1500RT2U | PRO2000RT2U | |
| Load Capacity (Watts) | 525 Watts | 700 Watts | 1050 Watts | 1400 Watts |
| Power Factor | 0.7 |
| Topology | Line Interactive |
| Mounting/Installation | Rack/Tower/Wallmount (kit optional) |
| Output Receptacles | (8) NEMA 5-15R | (6) NEMA 5-15/20R / (1) L5-20R |
| Input Connection | 10' input power cord with NEMA 5-15P (models PRO750/1000/1500RT2U) / 10' input power cord with NEMA 5-20P (model PRO2000RT2U) |
| Load reduction settings | (2) Banks controlled independently of (3) outlets + (1) always active bank of (2) outlets {PRO2000RT2U (1) always on L5-20R Outlet} |
| Warranty | Three-year parts and labor warranty |
| Input | |
| Voltage Range | 90 to 150VAC |
| Frequency Range | 60Hz +/-6Hz |
| Output (non-battery operation) | |
| Voltage Range | 103 to 136VAC |
| Frequency | 60Hz +/- 6Hz. |
| Waveform | Sine Wave |
| Efficiency (AC-AC) | >96% a plena carga nominal |
| Output (battery operation) | |
| Voltage | 120VAC |
| Voltage Regulation | 120VAC +/-5% until low battery warning |
| Frequency | 60Hz +/-0.5Hz unless synchronized to line |
| Waveform | Simulated sine wave |
| Battery System | |
| Hot Swappable Battery | Yes |
| Battery Type | Sealed, non-spillable, maintenance free, valve regulated lead acid |
| Run Time at Half Full Nominal Load | 15 (5) minutes | 14 (4) minutes |
| Surge Protection | |
| Surge Power Rating | 960 Joules |
| Surge protection | RJ11 / RJ45 and Coax |
| Certifications | |
| Agency Approvals | cTUVus (Meets UL1778 and CSA 22.2), CE, RoHS2 and FCC Susceptibility Part 15 Class B |
| Environmental | |
| Temperature: Operation (storage) | 0º to +40ºC / +32º to +104ºF (-15º to +45ºC / +5º to 113ºF) |
| Humidity - Operation (Storage) | 5 to 95% non-condensing |
| Elevation: in Operation (storage) | 0 to +3,000 m / 0 to +10,000 ft (0 to +15,000 m / 0 to +50,000 ft) |
Physical
| Unit Size (L x W x H) (with rack ears installed) | 16.1 x 18.9 x 3.4 inches (409 x 480 x 86 mm) | 20.1 x 18.9 x 3.4 inches (510 x 480 x 86 mm) |
| Weight unit | 31.3 lbs 14.2 kgs | 35.7 lbs 16.2 kgs | 48.7 lbs 22.1 kgs | 62.8 lbs 28.5 kgs |
