Endeavor LCD UPS
In today’s 24/7, “always-on” business world, downtime is not an option. Minuteman’s Endeavor LCD 1-3kVA UPS Series is engineered to provide the best features that demanding users require for supporting critical applications, while also offering unmatched reliability in a true online UPS. This premium-level product provides true sine wave output with versatile builds, perfect for protecting large networks, enterprise communications, servers, and large-scale security systems.
The Endeavor LCD 1-3kVA delivers continuous power conditioning through Minuteman’s double conversion online technology, providing emergency backup power with zero transfer time. It is also designed to protect servers, data storage, switches, and routers used in data centers or network closets, DAS and small cell systems, light industrial applications, telecom, and VOIP systems, plus security systems. Offering premium protection that meets critical application needs, users can confidently rely on Minuteman to provide complete power protection when reliability matters.
Extended Runtime
For extended runtime applications, these products allow the connection of optional external battery packs for long backup times required in certain applications, along with being generator friendly. Minuteman has made ordering easy by bundling units together in parallel configurations.
Communication Features
Ethernet Connection
Simultaneous RS-232, USB, and Ethernet communications: The Endeavor LCD UPS provides users with the ability to communicate with the UPS simultaneously through three separate protocols: RS-232, USB, and Ethernet. Users can now directly connect and manage the UPS from multiple stand-alone, or networked computers. By including concurrent Ethernet communications (SNMP or direct IP address), the Endeavor LCD UPS can provide detailed monitoring and management in many various environments.
Batteries
Battery Technology
All Endeavor LCD units and battery packs use valve-regulated lead-acid batteries (VRLA). All are safe for any type of freight transport: air, sea, or ground. For added protection, all Endeavor LCD UPS models ship with these batteries disconnected. A “Quick Installation Guide” is included in each Endeavor LCD box to detail how to connect the batteries before putting the units into service.
Extended Runtime Capability
All models in the Endeavor LCD Series come standard with internal batteries. To protect critical devices through extended blackouts, the Endeavor LCD Series utilizes external battery packs that can be daisy-chained in unlimited quantities to provide a virtually unlimited amount of runtime.
Fast Battery Recharge
With independent chargers in each battery pack (XL models only) offered for the Endeavor LCD Series, the recharge time is 8 hours to 90% capacity after a full load discharge, no matter how many battery packs are installed on a UPS. Without these chargers, if more than one battery pack is used battery recharging could take more than an entire day.
Hot-Swappable Batteries
All models in the Endeavor LCD line offer battery replacement, through the front panel of the UPS, without having to remove the UPS from service. Connected loads are protected from voltage anomalies and spikes and surges while the batteries are being replaced.
Self-Testing
The Endeavor LCD UPS is designed to proactively notify users of any impending faults or failures with the UPS. This allows for preemptive repair or replacement of components or batteries preventing unexpected downtime caused by the UPS.
The Endeavor line continues to be a popular choice for our customers looking to protect and extend runtime for high-density loads and larger applications.
Check out the Endeavor 1-3kVA Series to find the perfect solution for any application.
Endeavor LCD Rack Tower UPS
